01-17-2014, 05:07 PM | #24 |
BimmerPost Supporting Vendor
9607
Rep 10,891
I would also bet on 5W-30 or similar oil, and some sort of a 1,200 break in service being called for.
01-17-2014, 07:48 PM | #26 |
74
Rep 348
Um. This is going to be a 5w30 car.
WTB: 2016 M3 sedan, Black Sapphire, Extended Sakhir Lether, Ceramic Brakes, 19" black wheels, Lighting Package, HK sound, USB/Bluetooth
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust |
01-23-2014, 03:08 PM | #27 |
1259
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Break-in period of new F8x
Will it be the same as the e9x M3? from what I understand break-in period means you should not go high in the rpm range and should not press hard on the breaks for the first 1200 miles, correct?
Kind of sucks for us people doing ED or is there a way around it?
01-23-2014, 03:11 PM | #29 |
12
Rep 219
Not an NA engine, its more similar the the N54/55 which has no break in period.
Soooo I'm assuming let loose!
2013 BMW 650xi Gran Coupe
2012 ML63 AMG 2011 BMW 328xi Sold 2010 BMW X6 5.0 Sold |
01-23-2014, 03:14 PM | #30 |
Law Enforcer
25302
Rep 22,324
Drives: '22 Chalk Gray Porsche C2S
01-23-2014, 03:18 PM | #31 |
12
Rep 219
Never been a fan to listening to any of that on any car but thats just me lol
01-23-2014, 03:20 PM | #32 |
3471
Rep 4,986
01-23-2014, 03:23 PM | #34 |
3189
Rep 10,509
01-23-2014, 03:26 PM | #35 |
30
Rep 427
My X3 3.5 with twin scroll turbo had a 1200 mile break-in. It's an N55.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars 2005 S2000 2018 i3S |
01-23-2014, 03:27 PM | #36 | |
1259
Rep 3,688
01-23-2014, 03:29 PM | #37 |
1797
Rep 2,997
Break-in is mostly about piston ring seating and slipping friction surfaces seating as well and not glazing over (brakes, clutches). This applies to all vehicles.
It was also about keeping varying speeds so the cylinders broke in evenly. A boosted vehicle, some theorize, will seat the piston rings more quickly due to the higher pressure. Nevertheless, the above is what it's about. M vehicles have long had a factory recommended set of lubricant changes at 1200 miles. The belief being that break-in oil is incredibly filthy oil loaded with fine metals and assembly lube which has dissolved into the oil, and at 1200 miles the car is broken in (all metal filings are into the oil) so let's get it out of there before you go beat on the car as it was meant to be beaten on. So this is a long way for me to say: Yes, I'm sure the new M3/m4 will have the same break-in |
01-23-2014, 03:35 PM | #38 |
2362
Rep 4,255
2,000km.. then fluid changes. Whatever it says, if I were you, I'd do under 4500rpm for 2,000km and then engine/trans/diff fluids. Easy enough to do, and you'll be surprised what it looks like.
I'm on my fourth factory-turbo'ed car. Lots of little metal particulates in the oil after break-in. Regardless, it's a very expensive car and the fluid's cheap. Just do it.
///M Power
01-23-2014, 03:36 PM | #39 | |
555
Rep 2,633
We asked four top motorcycle engine builders what they do to ensure peak power output and optimum engine life. Here is a capsulation of their responses. "If the wrong type of oil is used initially, or the break-in is too easy, rings and cylinders could (read will) glaze and never seal properly. A fresh cylinder wall needs some medium to high engine loading to get the piston rings to seat properly for good compression but make sure you don't lug or overheat the engine. Use high quality, low viscosity oil (Valvoline 30 weight), no synthetics, too slippery. If synthetics are used during initial break in the rings are sure to glaze over." Makes sense |
01-23-2014, 04:02 PM | #41 |
23
Rep 290
01-23-2014, 04:47 PM | #42 |
178
Rep 467
01-23-2014, 05:23 PM | #43 |
22
Rep 290
Plan to do ED myself as well. Basically im planning to drive the 2000km in Germany, do the 1st break in service there and then straight on to the Nurburgring!
01-23-2014, 05:24 PM | #44 | |
34
Rep 421
Modern engines in this day and age are broken in from day 1. It takes very little to no time to seat the moly rings. The rest of the surfaces (cam, crank, rods) run on hydrodynamic oil waves and don't actually contact any metal surface. The engine is good to go from the day you fire it up. Most modern cars don't even require a break-in oil change. The AMG engines for example don't. Tires certainly need a little break-in to get rid of casting detritus. Same is true for brakes and clutches - the surfaces need to meet and wear in. What I keep reading is that the rear differential is the reason BMW has the 1200 mile break-in, requiring varying load and a limited top speed. The reasons I've read are that the differential actually has teeth sliding over other teeth, unlike in transmissions where they typically use involute gears. Because of this sliding, high spots etc are vulnerable in early days to excessive heat from high speed or high loads, which can change the properties of the metal. Proper wear and seating results in a surface which is mated and hard for the life of the car. I'll note that AMG cars require a differential fluid change early, well before any oil change. So I think your info about metal particles in the break-in oil is basically no longer true. Pat |
