07-20-2022, 02:09 AM | #23 |
1283
Rep 842
I was following that thread also and I'm considering MHD as well based off of the information there. I may reach out to the vendor directly for confirmation on the DME copying bit. Sadly, I also have an extra wall to overcome which is a locked DME for my '21.
We have similar goals; burble control first, then power gains second. More like quality of life mods than performance ones haha. |
07-20-2022, 07:45 AM | #24 |
42
Rep 36
This is news to me. Can anyone how has MHD confirm this?
07-20-2022, 07:48 AM | #25 | |
~Spyder
645
Rep 879
Drives: '19 M2C Hockenheim 6sp
Anywho, some interesting finds from the MHD User's Manual Flash Counter Reset / Freeze This flash option will reset your DME flash counter to 1, and also freeze it so that future flashes do not increment it any further. Return to Stock If you click the "Stock" tab, you will see three possible options. Flash Back to Stock To flash back to stock, select the tabStock>Flashback to stock. This option will uninstall MHD and completely revert your DME back to its original factory state. This can be useful if you wish to return your vehicle to stock before selling it, etc. An original backup file is not necessary for this process as [COLOR="DarkRed"]MHD can intelligently generate one exxactly for you based on unique identifiers in your DME.[/COLOR]
Skål från Sverige...via Texas y-all
07-20-2022, 08:10 AM | #26 |
~Spyder
645
Rep 879
YOLO…just purchased the MHD Flasher and Wi-Fi Adapter.
FYI - The standard flasher license has the GTS and CS maps included, thus no need for the additional map pack if you aren't after in multiple OTS maps that boast 20-30% bhp/tq gains. If y'all are interested, I'll post my impressions once I get the Wi-Fi adapter. Note: in my case, this ended up cheaper than BM3
(K)1282.50 |
07-20-2022, 09:38 AM | #27 |
~Spyder
645
Rep 879
Ok more info relevant to this thread. I reached out to MHD re: increasing concerns here stateside with smog testing due to the DME not having stock CalID and CVN values when other tunes reflash it to 'stock'…
Quote from MHD below: "Yes you will get a full stock BMW flash and DME will be also locked again" Kind of makes sense since MHD is in Europe and they have always been more stringent Re: emissions and all that…
(K)1282.50 |
07-20-2022, 04:22 PM | #29 | |
~Spyder
645
Rep 879
- MHD reflashes your DME akin to what/how BMW would do it - By comparison, a BM3 reflash to stock means it reduces the power/tq to stock levels by using a 'stock power map' Both options obviously would lock your DME.
07-20-2022, 05:11 PM | #30 |
414
Rep 336
Drives: 2018 BMW M2
F87 owner
I live in the DFW area and I passed on stage 1, albeit I only have an armytrix exhaust along with other mods (intake and intercooler n shit) What I will say is this...if you get the urge to mess with your downpipe, just don't do it |
07-20-2022, 08:43 PM | #31 |
509
Rep 533
Care to elaborate? Why not mess with downpipes? If you use a set of catted downpipes, what’s the issue?
07-23-2022, 12:33 PM | #32 | |
5873
Rep 6,638
No_curebimmer645.00 |
07-28-2022, 04:35 AM | #33 | |
~Spyder
645
Rep 879
Wanting instant validation however…I went MHD route. Should be installing it this weekend.
07-28-2022, 02:25 PM | #34 |
1717
Rep 1,899
BM3 does have a feature to read your DME and copy it. It's just not part of the standard process. The standard process just identifies your car and matches it to a copy of the OEM data they have on their servers.
Not sure if there are variances of the DME for different refrains or if they account for the variances either. Just letting you know that the DME copy isn't unique to MHD |
07-31-2022, 11:48 AM | #35 | |
~Spyder
645
Rep 879
11-03-2022, 01:21 PM | #37 | |
~Spyder
645
Rep 879
So, all signs are pointing that you should be good to go with MHD. I have not seen extensive empirical data on Bootmod3 that can point to zero emission test problems…
11-04-2022, 12:20 AM | #38 | |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Rep 302
Haven't had to prove it works, though. |
11-06-2022, 07:30 AM | #39 |
Rep 3
Thanks for the input. I just bought a 2021 without a tune and much closer than the car I was contemplating. Will probably wish I had the tuned car once the warranty period is up and I’m spending the money to tune, haha!
11-07-2022, 05:27 AM | #40 |
~Spyder
645
Rep 879
So perhaps I'm wrong but I keep seeing folks with BM3 continue having DME lock issues /not completely being able to go back to stock - and have CVN mismatch
https://www.bimmerpost.com/forums/sh...php?p=29474006 My experience with MHD is that I was able to completely uninstall the tune, return it to stock AND relock DME - my TX dealership then scanned it and passed state inspection w/o any issues. The performance delta between BM3 and MHD is negligible, thus if you're worried about state inspections, I would recommend MHD in a heartbeat based on my experience.
11-11-2022, 11:34 AM | #41 |
1558
Rep 2,505
BM3 flashes back to stock as well this was recently confirmed in the M3 forums. Originally the user couldn’t relock the DME but he contacted tech support and pro tuning freaks told him to use Chrome Browser. It was giving errors with Firefox. He relocked the DME successfully and passed smog. He verified that the cal id numbers matched as well.
11-14-2022, 03:13 AM | #42 | |
1309
Rep 775
BM3 downloads a 'stock image' from their server when you want to 'flash stock'. MHD retains the 'stock image' locally on their app. Even when you generate a backup file, it's a stock image from them, based on your DME parameters. Neither BM3 or MHD make an exact copy of 'your' DME bin file (the image is not unique to your car). At least, this is how I understand it from what I've witnessed having used them both. I wouldn't want to believe otherwise unless provided with proof/official statement from MHD. |
11-15-2022, 11:02 AM | #43 | |
670
Rep 1,074
Instagram: M2_Medusa
