04-02-2019, 09:04 PM | #23 | |
2477
Rep 5,460
Drives: F30
04-02-2019, 11:51 PM | #24 |
David
787
Rep 2,009
04-03-2019, 03:09 PM | #25 | |
4042
Rep 3,549
Drives: 328d Wagon, M2 Comp, i4 eD35
I even made a log entry about how I tested proof of concept for stiffer springs and decided to move away from the standard Eibach fronts. |
sspade2476.50 |
04-03-2019, 06:52 PM | #26 | |
2477
Rep 5,460
Drives: F30
04-03-2019, 07:49 PM | #27 |
4042
Rep 3,549
I'm not anymore. I used them for a about a month and 1800mi before changing to the stiffer Eibach front spring. I wouldn't be worried about running them long term though. I'll likely play around with some for the rear in the near future.
sspade2476.50 |
04-03-2019, 08:03 PM | #28 | |
2477
Rep 5,460
Drives: F30
If you look at enough F30's youll notice that most if not all have a hair of reverse rake with OEM suspension set ups. Guess they are meant to be that way. Mine is no different currently with my aftermarket set up and Im wondering if a slight spacer in the rear would set me just right. Im also a bit concerned because Im going to be towing a small watercraft shortly this summer which is going to even further cause the rear end to sag a bit further when towing. |
04-05-2019, 07:35 PM | #29 | |
David
787
Rep 2,009
sspade2476.50 |
04-06-2019, 12:04 PM | #30 | ||
2477
Rep 5,460
Drives: F30
04-09-2019, 08:42 PM | #33 |
262
Rep 335
So... summarizing (I hope)... if I was looking for improved handling for daily driver duty with a mild drop (ie less than inch), B8 and the appropriate Eibach springs would be the ticket?
04-09-2019, 08:43 PM | #34 | |
David
787
Rep 2,009
That's what I'm currently considering.
CTMike262.00 |
04-09-2019, 11:57 PM | #35 |
Rep 8
spring spacers and higher than recommended coilover setting
I have the KW V3 on my 2013 335 xDrive and even adjusting the coils 1/2" higher than KW's max height recommendations it's still pretty low. Despite great care I still drag bottom panels on uneven roads.
The problem with adding spring spacers or screwing the spring seats higher is that you could start topping out the damper. They're not designed for this load. True, there's nothing to prevent topping out even at recommended ride heights. It'll just happen more often as the resting shock position gets closer to full extension. I'm following the "strong" recommendation of Chris Benny at Prova Motorsports in Seattle. He wasn't keen about going 1/2" higher. I made the SWAG that KW included that much safety margin in their design. After 40k miles they're OK so maybe I could have gone higher? The car handles so well with this setup that I'm not enticed to go back to stock ride height despite having needed to replace the underbody panels ahead of the rear wheels. Twice. (Fairly easy. About $80 per panel.) |
cfm56d7b5948.50 |
04-09-2019, 11:58 PM | #36 | |
David
787
Rep 2,009
04-29-2019, 09:31 AM | #37 |
AW M Addict
40
Rep 217
I installed H&R's on my wifes Diesel M-Sport and it was an enormous drop. Her car was fitted with the factory front lip and in Texas , nearly every driveway rubbed. I would not call the ride bouncy at all - it was non linear and very stiff. Ultimately she decided she wanted to sit up higher and we replaced her car with an E70 X5M. I was concerned about resale so I quickly reinstalled the existing springs.
Reinstalling the OEM M-Sport Springs was much more difficult than installing shorter springs obviously. If you plan on keeping the car, I would definitely suggest a full coilover setup - with the appropriate time spent adjusting.
1988 Alpine White M3 || 1998 AW M3 Sedan (Race)
2000 Alpine White M5 || 2001 Alpine White M3"T" 2008 Alpine White M5 || 2008 Alpine White M3 Cab 2010 Alpine White X5M || All 3 Pedals Sans X5M alpinewhitem.com //coming soon |
04-29-2019, 10:45 AM | #38 | |
David
787
Rep 2,009
04-30-2019, 04:31 PM | #40 |
David
787
Rep 2,009
They researched my situation and found it to be "normal". They did a further investigation as to why their springs sit that way on my car, and came up with another spring part number that is compatible and would lower the front end 10-15mm.
Had ACS U.S, actually Iocated here next to me In Irvine, the reps name is Eric Tsou told me the compatible ACS spring. That spring I did some research on what kit it's from, asked him to send me the TUV data and backtracked it to an existing Eibach part/spring set that was actually designed for the F31. So TL;DR ACS Germany told me the spring set to fix my reverse rake is the same exact set sold in Europe by Eibach, that Eibach designed for the car in the first place.
04-30-2019, 04:43 PM | #42 | |
David
787
Rep 2,009
I purchased off eBay from Poland and they arrived yesterday. Will be installed at the end of next week.
04-30-2019, 04:48 PM | #44 |
David
787
Rep 2,009
Here is his name. He's the only person that came up for me also. So it should be easy to find.
