03-01-2022, 11:10 AM | #23 |
86
Rep 376
M3/M4 comes with 4 piston front / 2 piston back -> for track use / R compound / hard driving / medium to high demanding track this system will have excessive pad wear and pedal feel will change relatively fast as pads wear out.
M2C comes with 6 piston front / 4 piston back -> this system is much more robust due sizing and should handle track abuse much much better. The draw back is that front system is really heavy / no option for thicker pads / hard to replace pad at the track (caliper removal). The rear is perfect specially with better rotor (Girodisc). |
03-12-2022, 04:15 PM | #24 |
511
Rep 882
Installed a brake cooling kit on a BMW F82 M4 CS today. Couldn't use the hose holder on the control arm because of a different design on the sway bar so I only used the upright hose holder, worked out nicely anyway.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
03-19-2022, 11:49 PM | #25 |
Wing Chun Shifter Speed
36
Rep 181
We're you not getting enough cooling with the CCBs? Or the BBKs I mean
Current:F82 M4 | BM3 Stg 2 MultiMap FF | AA EL Midpipe + DP's | KW HAS
Totaled:F30 335i | ER Chargepipe | ER Down-Pipe | Wagner Intercooler | BMS Intake | Meisterschaft Exhaust | MHD BEF JB4 Map 3 / 30% e85 / 50/50 Meth |
03-21-2022, 01:51 PM | #26 |
1127
Rep 1,322
In thinking about this more, and given some people's concern over the potential downside of increased heat exposure of the control arms' ball joints without the stock heat shield, have you considered a design where the lower portion of the backing plate has a piece that extends towards the center so that the ball joint of the LCA gets some heat protection? See below:
03-21-2022, 02:14 PM | #27 |
511
Rep 882
The M4 CS isn't mine, but the owner had experienced brake fade towards the end of the sessions even with the CCB's. He liked the feel of the pads and that they are kind to the insanely expensive discs, so he's sticking with them. He have since changed to a racing brake fluid. That paired with the cooling will most likely be enough. I'll update when he's been on the track.
03-21-2022, 02:16 PM | #28 | |
511
Rep 882
jfritz271126.50 |
03-25-2022, 11:32 AM | #29 |
14
Rep 90
Following, Great design and method to Westersund
Westersund511.00 |
10-27-2022, 12:30 PM | #31 |
511
Rep 882
I've had a lot of people messaging me about the brake cooling kit and I really appreciate the interest! During summer I had a lot of problem with the printers and having a lot of other things to do I gave up on fixing them and ordered a new Prusa. The new printer was supposed to arrive during quarter 3 but it was post poned due to component shortage, the new estimated delivery is in January 2023.
With that said my patience with 3D-printing as a manufacturing process have reached it's end. Moving forward I will look into making my products in carbon fiber instead and only use 3D-printing for prototypes, one off's, moulds and complex parts. I can't give you an exact date when I'm gonna get there but I will update this thread when I know more.
12-07-2022, 04:28 PM | #32 | |
1040
Rep 927
12-08-2022, 02:01 AM | #33 |
511
Rep 882
Not yet, my hopes are that the new printer will arrive as annouced in january. It's just a generic neoprene hose in 2,5" bought by the meter, I think I used about 2 feet per side or slightly more. I bought it from a Swedish online shop so you'll probably find equally good and cheaper hose from the states.
FrankMstein1039.50 |
12-08-2022, 06:31 AM | #34 | |
1040
Rep 927
Will you be making the flange above the inlet thicker so it will not brake off as easily? I plan on using stainless hose clamps. Also is there any possibility of you sharing your model? I may have access to a printer here. |
12-08-2022, 07:43 AM | #35 | |
511
Rep 882
I've been asked about sharing my files many times and the answer is no I'm afraid. Even if I'm moving to carbon fiber doesn't mean someone else could pick up the torch if I release the files to the public. I've spent a lot of time in R&D. Sorry.
FrankMstein1039.50 Lienrocs704.50 |
04-17-2023, 09:03 AM | #36 |
1023
Rep 836
Have you monitored the temp on the PETG part on the dust shield? I'd be concerned it would get near the glass point so close to the brakes. Maybe not on track, but also right after and you have hot brakes and a non moving car.
04-25-2023, 11:10 AM | #37 |
511
Rep 882
I haven't, I've had a couple of people that got the brakes so hot that the funnels on the dust shield have distorted, probably happened when they went into the pits after a hard stint. Since then I've changed the design to a thicker base and support rib. I will also, once I get the new printer going, start to apply some kind of heat barrier between the dust shield and funnel to eliminate the problem altogether.
09-01-2023, 01:59 PM | #39 |
511
Rep 882
Just wanted to let you know that I cancelled the Prusa XL because I got tired of waiting (15 months now) and bought a Bambu Lab X1 Carbon Combo instead. The good news is that I'm back to printing and getting to know the printer. I will soon take orders again but I have to crunch the numbers first. There will be a slight price increase but all metal parts will be painted and hardware (stainless hose clamps, bolts, nuts, washers and zip ties) will be included but not the hose. I will offer the kit with 2" or 2,5" fittings and the backing plates will come pre-assembled. I will also make a small design revision of the air guide to direct the air a bit more towards the center of the disc.
The printer is a sweet machine so far, love it! One of the first test prints and it will improve quite a bit. I can start the printer from home or from my phone now as soon as I get an order for faster delivery. I'll make an update in a few days when I know more. But the printer is runing pretty much all the time.
09-02-2023, 01:19 AM | #41 |
511
Rep 882
I have to crunch the number first, but it will be a bit more then it is now, but everything except the hose will be included ready to install. It will be the same price for 2" and 2,5".
09-04-2023, 04:00 AM | #42 |
511
Rep 882
I've looked over the numbers and the new price for a complete kit is 380$ and with the added 30$ you get all hardware such as bolts/nuts/washers/zip ties and all metal parts come painted and the backing plates are pre-assembled and ready for install. The first 5 who order a complete kit will recieve an additional bonus consisting of meshes and winter covers or intake enlargers (no it's not what you think it is you pervert lol).
On the contratry to what I said earlier about the hose clamps, those will not be included. The reason is that a package to the US cost about 22$ if it's under 2 kg, if I add the hose clamps (6x stainless hose clamps weigh a bit) I'm not sure I can squeeze the package under 2 kg and an up to 3 kg package cost 50$. The added value will be lost so I think it's better you buy hose clamps separately. Also I made a small redesign of the air guides to more effectivelly guide the air towards the center of the rotor. Red is the old and green is the new. Just have to verify on my car that it doesn't hit anything, but I think it will work.
09-04-2023, 06:57 PM | #43 |
1040
Rep 927
That's a great price. I used 2.5" and it is TIGHT and rubs. I would go with 2". I also had to offset the side with the swaybar leveling mount. Also, the extra added .5" of the hose the wheel inner rim rubbed at the hose mount of the scoop rear and I run 15mm spacers on 19". 20" will probably not rub on 2.5 but its hard enough to find track tires in 19" let alone 20".
Westersund511.00 |
09-05-2023, 02:20 AM | #44 | |
511
Rep 882
