07-19-2018, 09:48 AM | #23 |
3905
Rep 2,524
.75" conduit is sufficient, could get away with .5" as well if you only run the one cable. ( I recommend 2 cables cause if you are pulling 1 in, 2 is just as easy)
LB out the house, 90 into the ground. bury it 18" along the sidewalk. 90 up out of ground, LB into pool house. Slap connectors on and plug into routers. if you arent handy, or dont want to deal with it, it is a half to full day job for any competent electrician/handyman depending on distance and what is in the way. or you can try a powerful router in the closest openings to each other in the main and pool houses. should be enough to get you a signal to the pool house, and then the router in there will be able to spread throughout the pool house.
07-19-2018, 10:09 AM | #24 | |
5161
Rep 3,242
07-19-2018, 11:34 AM | #25 | |
3905
Rep 2,524
i agree though, not the best option, and not the cheapest. cheapest is running a cable yourself.
07-20-2018, 11:33 PM | #26 |
2JZ-GTE
3072
Rep 4,022
Run fiber or have att put cell station in backyard
07-20-2018, 11:48 PM | #27 |
Free Thinker
17322
Rep 7,457
Assuming your pool house is electrically wired to your main house, just use powerline Ethernet adapters. Plug one in wherever your main router/modem is and plug in the other end to the pool house, then run an Ethernet cable from that to an AP, like an Apple base station or Google wifi. I have a webcam in our shed that runs through Ethernet-over-powerline and the connection is rock solid.
Modem/router in main house => Ethernet-Over-Powerline => 2nd Ethernet-Over-Powerline in pool house => Wifi AP (Apple or Google wifi).
07-20-2018, 11:51 PM | #28 | |
3788
Rep 5,776
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-21-2018, 12:10 AM | #29 | ||
Long Time Admirer, First Time Owner
18177
Rep 9,389
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
07-22-2018, 12:53 AM | #30 |
28
Rep 84
The power line adapter did not work. There's is some sort of connection issue between the pool house and main house.
The power line adapters we're working together in the same room when I tested them but once I moved the 2nd unit to the pool house it just didn't work. My next option is to return this and buy the mesh system? I saw it at Best Buy for 350 to 500..... and I think google was one of the makers :/
///M
Current car: Mineral Gray 2018 M3 Exec Pack / Manual |
07-22-2018, 12:53 AM | #31 |
28
Rep 84
Running a wire seems difficult....
We have concrete, trees and walls in between the pool house and main house sadly....
///M
07-22-2018, 03:17 AM | #32 | |
904
Rep 1,004
Drives: 2008 BMW 135i (E88 N54 6AT)
is there line of site between the pool house and the house? |
07-22-2018, 08:57 AM | #33 |
4520
Rep 8,942
I would go with the Netgear one if I were you. The Google one is good I installed it at dad's house but it's less modular. Orbi seems more professional grade and you can add as many units as you want. If pool house to main house is a bit too far you could even put the all weather Orbi in between to bridge the gap.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-22-2018, 09:13 AM | #34 |
5161
Rep 3,242
That's nice you have the option to use 5GHz as the bridge frequency. Good to see enterprise features making their way into consumer grade equipment.
07-22-2018, 09:17 AM | #35 | |
5161
Rep 3,242
This is why mesh wireless systems are designed to not have another hop in between so every connection is only point to point; not point to point to point. |
Kilabyte3949.00 |
07-22-2018, 09:25 AM | #36 | ||
5161
Rep 3,242
If you've read my posts, getting any of the wireless mesh systems like Google WiFi, Netgear Orbi, Linksys Velop, Eero, etc, you're going to run into a problem of wireless performance between access points as they all use omnidirectional antennas. If you want to use a wireless mesh, you need to spend the money and buy access points which support wireless mesh and can use external antennas which you'll be using directional antennas. Quote:
As someone stated in a previous reply, if you have the financial means to have a home with a separate pool house, you should be able to afford to pay to get this done properly. |
Soul_Glo13398.00 |
07-22-2018, 11:28 AM | #37 |
157
Rep 637
Drives: e90 n54
Page 1 Chapter 1 of 1st world problems...
LOST BUT NOT FORGOTTEN 2009 E90 335i AW... Black grills/jb4/lux angel eyes/clear side reflectors/and a few more small mods
2011 e92 335iSSSS Black |
TS2984922828.00 |
07-22-2018, 10:20 PM | #38 |
799
Rep 2,494
TS2984922828.00 |
07-22-2018, 10:48 PM | #39 |
Free Thinker
17322
Rep 7,457
True. So true. But even the 1% need tech advice.
TS2984922828.00 |
07-22-2018, 10:52 PM | #40 |
Free Thinker
17322
Rep 7,457
The mesh wifi systems are awesome. I just set up my FIL's place with Google wifi so I could access admin services from several states away. But there are other options besides Google, and I don't blame anyone for wanting to shy away from Google branded stuff from a privacy standpoint. But check out the other mesh wifi devices.
TS2984922828.00 |
07-22-2018, 10:54 PM | #41 | |
5161
Rep 3,242
Things that affect WiFi performance: distance, objects (materials between the access point and the client), interference, loading of the access point, to name some off the top of my head. No one can provide any suggestions until you give more specifics about your environment such as how far is the wireless router from your master bedroom, how many walls are in between and what are the walls made of, how many other wireless networks are around you, etc. |
TS2984922828.00 |
07-22-2018, 10:58 PM | #42 | |
Free Thinker
17322
Rep 7,457
TS2984922828.00 |
07-22-2018, 11:30 PM | #43 | |
5161
Rep 3,242
The best thing to do is to pull cabling to points (or close to it) where an AP should be placed. And then use wireless equipment which function as a unified wireless network that are cabled. The second best thing would be a wireless mesh system. The third best is to use independent APs all set on the same SSID but each AP configured to use a non overlapping channel. And dead last would be using repeaters/range extenders. |
TS2984922828.00 |
07-23-2018, 12:53 AM | #44 | ||
904
Rep 1,004
First, just because someone has a fancy big house and hangs out on the BMW forums, doesn't mean they've got heaps of spare cash. While there's a fair whack of people on these foums clearing half-a-mil per annum; I've no doubt there's a fair few people here who've shelled out for the initial investment, but not left a lot of headroom for the higher expenses that come with such fancy "investments". Which is a long way of saying - just because OP has a Poolhouse, it's not really fair to assume they're flush with cash. Secondly, if this is a lavish mansion with a poolhouse, you're probably not talking a simple $300 trench & fill job. ... There's probably paving, and i dunno... maybe a pool in the way. Quote:
I'm trying to be polite about it, but a lot of people in this thread could pay to listen to what zx10guy is saying here. There are a lot of fancy, expensive, porcupine looking wireless routers on the market now, and a whole lot of brand name "mesh network" crap which you can feel free to spend thousands on getting your iPads hooked up to netflix around the house, but in reality are a single-radio wifi access point with some fancy management software. If you want to do a fast, reliable wireless connection in an outdoor area, you're best leaving those devices on the shelf. For outdoor building links, you want a wireless network to act as a pseudo-wire. If you need devices in the house or in the pool house to connect to a wireless network, that's a separate thing. For your outdoor link, you run a NETWORK CABLE from your Internet router to a specific point-to-point wireless access point which is mounted on the external wall of the house pointing toward the poolhouse. (ie. One of these ). You buy a SECOND ONE which is mounted on the external wall of the poolhouse, facing the one on the house, which will be the one and only wireless devices associated with the access point on your house. Either, you connect the computer in the poolhouse to the nanobeam using a network cable, or you get a cheap shitty indoor access point (or a sparkling new googe mesh system) for the WiFi network inside the poolhouse (something like this). If you don't have line of site from the poolhouse to the house, you find a third point which can be seen from both the poolhouse and the house, then you buy not one more, but TWO MORE nanobeams, connected with a network cable. One for the house link, one for the pool-house link. You can have as many hops as you need to connect the network without it causing any performance issues, as long as you do it right to start with using point-to-point directional wireless links. The Ubiquiti gear I've linked automatically finds free radio spectrum, is relatively easy to setup and is dirt cheap for the job it does. We use the nanobeams for sub 1km links, the powerbeams for 1-5km links and have an Airfibre link that's running more than 100Mbit/s over a 20km point to point link. |
TS2984922828.00 Kilabyte3949.00 |
