Procede V5 11-01 Aggressive maps now available
11-03-2011, 02:40 PM | #23 | |
1750
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
11-03-2011, 02:57 PM | #25 |
3437
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Is the firmware for the 11-01 maps (pro5v109) the same firmware used for the 10-18 maps? Robert loaded 10-18 directly on to my unit when I upgraded to 2.5 so I have no idea which firmware controlled 10-18. Thanks.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
11-03-2011, 03:05 PM | #26 |
1750
Rep 17,960
Drives: A Lot
Nope. It is different. As always, we recommend updating the firmware along with the map.
11-03-2011, 03:05 PM | #27 |
142
Rep 2,661
kk im going to go for a spin tonight to see how things are
11-03-2011, 03:07 PM | #28 |
69
Rep 1,943
V5.30
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-03-2011, 03:30 PM | #29 | |
3442
Rep 79,211
11-03-2011, 03:53 PM | #33 |
3442
Rep 79,211
The internal hardware of the Rev2 cannot support what these new maps do. You must upgrade if you want to use these new maps.
In the user adjustable just switch from PWM (default) to PPS |
11-03-2011, 03:55 PM | #34 |
15
Rep 242
Yeah but Shiv stated before that the PPS system might not be good enough for his aggressive maps
11-03-2011, 03:59 PM | #35 | |
3442
Rep 79,211
The thing with new maps is your car must be up to par. You must have a reliable methanol system, flowing adequately with excellent atomization. He knows with the PWM kit you will have that but he cant speak for every PPS kit as they all differ a lot with many nozzle size differences, placement, flow, atomization, charge pipe design, ETC ETC Just run some logs and see where you are at. |
11-03-2011, 04:00 PM | #36 |
133
Rep 4,764
11-03-2011, 04:00 PM | #37 | |
1750
Rep 17,960
Drives: A Lot
Cheers, shiv |
11-03-2011, 04:09 PM | #38 | |
15
Rep 242
11-03-2011, 05:43 PM | #39 |
3442
Rep 79,211
M7 and M5 is plenty, farthest from the TB Post intercooler.
11-03-2011, 05:52 PM | #40 |
69
Rep 1,943
Im running pwm Kit and i dont know wa size of nozzles I got....
11-03-2011, 05:54 PM | #41 |
1750
Rep 17,960
Drives: A Lot
Lol.. You have dual 1.0mm nozzles. Just pick the appropriate stg map and set map2 values to 65% boost and 0% IC.
11-03-2011, 05:56 PM | #42 |
3442
Rep 79,211
Nozzle sizing is different for PWM VS PPS.
IF you have the PWM kit from vishnu these maps are set up for you. Just run stage 2 or 3 depending on your mods. Probably 3 as it seems you have full bolt ons. |
11-03-2011, 06:50 PM | #44 |
13
Rep 377
shiv..sorry but im a little confused with these new maps..one part of your read me file says map 2 start boost should be 65% and ignition 0% respectively...but further reading says that the scaling has all been changed..default user parameters following the update has map 1 and 2 on 14.9 start boost and 0 IC. are we or are we not supposed to change start boost for map 2 to 65% or leave it alone?
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
