05-05-2024, 03:36 PM | #23 |
2479
Rep 5,949
I’d check the strut top mounts and the anti-sway bar drop links. It’s definitely not a wheel hub because you’d hear it every time you turn.
jaylazy2020267.00 |
05-05-2024, 03:43 PM | #24 |
267
Rep 650
05-05-2024, 03:57 PM | #25 | |
2479
Rep 5,949
ASB drop links, with both front wheels (you can try it with one but the drop link will be heavily loaded due to the twisting of the ASB) and push-pull the drop link up and down as well as side by side. They should be quiet when you move them. You’re still running the stock suspension and springs, correct? If you’re lowered that can preload the ASB and the drop links won’t be 90 deg to their mounting bolts which can create noise and/or cause the drop links to fail. |
