Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      11-01-2020, 12:48 PM   #23
sly1types
432
Drives: F80M3 and E46M3
You have to use something like the strut nut socket to hold the inner nut from spinning.
      11-01-2020, 04:13 PM   #24
9M71
1235
Drives: 2018 F80 M3 | 6MT
Originally Posted by Sahbatage View Post
can anyone help me. I'm using an 1/2 impact gun with 18mm 12point socket to undo the center strut bolt, but can't loosen the nut and I feel like it's just spinning. What am I missing!?
What he said. I would stop spinning it before you damage the strut lol
      11-01-2020, 05:51 PM   #25
TopJimmy
TopJimmy's Avatar
5535
Drives: 2023 M3 Comp xDrive
Gotta hold the middle with a 10mm and use the cutout 16mm to loosen. Soon as it turns the impacter will remove it the rest of the way.
Installing you MUST hand tighten. Pay attention to the direction of the connector, and use the 10mm to rotate if needed.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
      11-01-2020, 06:15 PM   #26
Sahbatage
Sahbatage's Avatar
504
Drives: 2016 IR BMW M4
Is that what he's using in the video? Looks like a regular socket.
Are we referring to the same thing? In the video he uses the impact gun to tighten also and says its bmw spec
"If you have everything under control, you're not moving fast enough"
      11-01-2020, 06:23 PM   #27
TopJimmy
TopJimmy's Avatar
5535
I think Tommy had it loose already, or he got lucky. Mine spun too, so I had to look up the proper steps. I saw how the impacter was used to re-tighten but I look up TQ and hand tighten with TQ wrench.
      11-01-2020, 09:02 PM   #28
BzsBimmer
BzsBimmer's Avatar
3293
Drives: '23 G80 FO M3, M3 & MY Tezzy's
I’m with you. I like to use proper torque when at all possible.
Just because you can tighten with an impact doesn’t mean you should.
And I’ll argue that using a torque gun is not BMW spec...
I know the Bilstein kit I have specifically stated to not use an impact gun on that specific nut.
izzyM2749.50
      11-01-2020, 09:13 PM   #29
9M71
1235
You'll want this...
https://www.ebay.com/itm/232625900420
      11-02-2020, 06:20 AM   #30
Sahbatage
Sahbatage's Avatar
504
DIY Guide: How To Install Lowering Springs (F80 M3/F82 M4)
Originally Posted by 9M71 View Post
Thank you! Just purchased and will take everyones advice and hand tighten and only use the gun to loosen.
      11-02-2020, 11:01 AM   #31
audioMeth
BTC maxi
audioMeth's Avatar
222
Drives: F80
might want to grab a 10mm brake wrench too, makes using that strut nut tool easier.
Appreciate 2
Sahbatage503.50
JAI///M3528.00
      11-02-2020, 04:50 PM   #32
TopJimmy
TopJimmy's Avatar
5535
@audioMeth has a great suggestion using the brake wrench (I'll need one soon). You can also use a 10mm on a little quarter breaker since a 1/4 ratchet head doesn't fit inside the cutout.
Sahbatage503.50
      02-23-2021, 06:45 PM   #33
izzyM2
izzyM2's Avatar
750
Drives: 24’M2/21ID.4/21’MacanGTS
Thanks to this tutorial, I was able to diy my springs. First time doing it and was able to do it on my own. Just make sure you have the proper tools and take your time.
      01-06-2023, 04:33 PM   #34
gary1982
gary1982's Avatar
12
Drives: BMW F80 M3
Brilliant write up. Thanks for this!
      05-09-2024, 04:37 PM   #35
RsimmM4
Drives: 2015 M4 Conv.
rear a arm bolt removal and replacement.
When reinstalling this bolt.... If you are not on a lift... make sure when you go to reinsert this bolt that you can see the far side of the fork on the a arm... when using the jack or by hand to get it realigned to reinstall the bolt... if you just blast away, the other side may not be aligned and you will hit the a arm with the bolt and spread it apart..... Ask me how I know!
As the bolt starts to thread on the far side you will know quickly if it is aligned.
      Yesterday, 09:35 PM   #36
SteveYem
23
Drives: 2015 Audi S4, 2018 BMW M3 ZCP
Maybe a dumb question, but is it possible / advisable to replace the springs by jacking up one corner at a time in the front? Specifically I’m thinking about removing and reinstalling the sway bar end link fastener and whether the sway bar needs to be completely unloaded (both wheels off the ground) in order to do so.
f80post
