F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
Studio RSR
      04-28-2024, 07:43 PM   #4159
BryanB58
Drives: 2016 340i
Can someone take a look at these logs for me the second one is me just cruising first is a proper log, Im concerned about the timing delta being so high in the second log.
https://datazap.me/u/elb58/4th-gear-1?log=0&data=5-25
https://datazap.me/u/elb58/timing-de...og=0&data=5-25
Im on a daw flowmax+ on shells 91 might be a bad batch of fuel as I went to a different shells location but regardless doesn’t seem right.
      04-29-2024, 10:41 AM   #4160
MCAMPOS
MCAMPOS's Avatar
27
Drives: x3 m40i
Can someone take a look at my logs? Running BM3 stage 2+ 93 tune. Current set up is TU pump, new injectors, new NGK 94201 plugs gapped to .028, VRSF catless downpipe. I was running the stage 1 93 map and was getting quite alot corrections and knocks. I put a couple gallons of e85 in and it cleared everything right up. Over the weekend and flashed to the stage 2+ 93 map and I'm getting some minor corrections again but no knocks. Worried they will only get worse when the weather warms up.
https://bootmod3.net/log?id=662e4fe296d1b127238d2100
      04-29-2024, 11:59 AM   #4161
Cytoplasm0671
Armchair Aristocrat
Cytoplasm0671's Avatar
331
Drives: 340i 6MT
Still getting engine knock
Tune: BM3 OTS Stage 1 E30 map
Mix: E38 using 93-octane Shell gas (see log flexfuel sensor)
Equipment: Active Autowerke downpipe, TU HPFP, Pennzoil Plat Euro 5w40 oil, new NGK plugs (stock gapped)
Have had engine knock at low-RPM in the past. On advice of this forum am running E38 on the E30 tune to try and clear up the knock.
2 logs still have engine knock
Log 1: https://www.bootmod3.net/log?id=662f...7ee711b7e3d41b
Log 2 (knock): https://www.bootmod3.net/log?id=662f...7ee711b7e3d47a
Log 3 (knock): https://www.bootmod3.net/log?id=662f...a8bf21c558e861
Log 4: https://www.bootmod3.net/log?id=662f...a8bf21c558e869
Any ideas what to try next?
**EDIT**
I think it might be something on cylinder 5. For both knock logs, it seems cylinder 5 that is knocking. Also see this E30 Stage 1 Map w/E43 from September: https://www.bootmod3.net/log?id=6502...90c6120936bbcd this Stage 2 map: https://www.bootmod3.net/log?id=6502...0b435ca6e0a8cc and this Stage 2+ map: https://www.bootmod3.net/log?id=6502...729b152462c3f5
It is always cylinder 5 that is most affected. Already replaced plugs so it might be time for some new coils or injectors? Anyone have any thoughts?
      04-29-2024, 09:30 PM   #4162
WrxToBeamerGuy
WrxToBeamerGuy's Avatar
498
Drives: BMW 340i xDrive
Brian that cruising log looks terrible and I'd be very concerned if a fresh batch of gas does not fix it. If it doesn't fix it then check your spark plugs. The proper log looks okay... but not great either.
Dustin Braun @ Braun Performance Tuning
      04-30-2024, 11:59 AM   #4163
Krisztian93
Drives: Bmw 540i g30
**EDIT**
Hi im no expert in fact i know very little,,, but for me im on Mgflasher Ots stg2 and on 98 ron map (98ron fuel) i have knock, on 95 ron using 98 fuel no knock! I sent my logs to tuners they said knock is actually a throttle knock… they said nothing to worry but for me The timing is consistent, for you is not compared to mine… I think its best to spend extra money for custom tune, i will do that also we will
Get more power and more safety… by the way Kern417(Kevin) also told me he not really cares about knock He looks The ignition and the correction thats what matters according to him…
I double checked where i have knock timing is all
Over for me as well!! Best to get custom tune 🤷
      04-30-2024, 06:14 PM   #4164
SimonO
12
Drives: 340i
Hi guys,
I've recently flashed my Gen1 with MHD Stage 2 HPFP and run on 99 Ron fuel. Would you mind having a quick look and let me know if these look OK? Are the timing corrections OK? There's a little bit of overboost there too and a throttle closure.
https://datazap.me/u/simonocr/mhd-st...og=0&data=3-17
Thank you
      04-30-2024, 07:58 PM   #4165
BryanB58
Drives: 2016 340i
I filled up fresh batch of 91 same station I would go to prior then added 1.75 gal of E on this log
https://datazap.me/u/elb58/added-175...36-37-53-66-68
      04-30-2024, 08:02 PM   #4166
WrxToBeamerGuy
498
Looking way better
      04-30-2024, 08:35 PM   #4167
mr.almeida
60
Drives: F97
Is turbine power something controlled by tuner? I changed tuners because the car was running horrible with this log. New tuners log keeps it at 60 "turbine actual" in the same boost and fuel. It goes to nearly 80 RAM Turbine actual in this log.
https://datazap.me/u/mralmeida/pure8...&data=32-59-60
      04-30-2024, 09:13 PM   #4168
WrxToBeamerGuy
498
Yes it is controlled by how the tuner creates the compressor map and a few other factors.
      04-30-2024, 09:15 PM   #4169
mr.almeida
60
Drives: F97
Thanks, reaffirms my thoughts.
      05-01-2024, 07:53 AM   #4170
Michalt
Michalt's Avatar
Drives: 340i
Stock car with highflow catted dp, ron98, st2 MHD
Should I worry about these corrections?
https://datazap.me/u/black340i/log-1...og=0&data=2-22
      05-01-2024, 08:01 AM   #4171
DieselDuck
DieselDuck's Avatar
94
Drives: BMWB58
Not looking the best, looks like low quality gas. Try some premium fuels like Total or Shell and see if it improves. If not you could flash the 95 ron map.
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
      05-01-2024, 01:51 PM   #4172
mr.almeida
60
Drives: F97
Are tuners able to see all my data logs in BM3 or just the specific ones to their map?
      05-01-2024, 07:26 PM   #4173
SimonO
12
Drives: 340i
Originally Posted by SimonO View Post
Hi guys,
Thank you
Anyone?
      05-01-2024, 08:01 PM   #4174
BryanB58
Drives: 2016 340i
Looking way better
By any chance do you know why when datalogging sometimes it will glitch and skip rpms as if it doesn’t register it example this log i just took; it cut off at 3600 rpm no data then at 6000rpm starting registering the data once again.
https://datazap.me/u/elb58/4th-idk?log=0&data=5-25
I didnt check until i got home now that log is null gotta wait take another log tomorrow
      05-01-2024, 10:35 PM   #4175
WrxToBeamerGuy
498
All
      05-01-2024, 10:35 PM   #4176
BryanB58
Drives: 2016 340i
Anyone?
looks normal to me mate few bit of corrections but nothing crazy boost is hitting target fuel rail pressure is smooth timing good nothing alarming from those logs my opinion
You have xhp?
SimonO11.50
      05-01-2024, 10:38 PM   #4177
WrxToBeamerGuy
498
No idea. It has happened to me too.
      05-01-2024, 10:40 PM   #4178
WrxToBeamerGuy
498
Anyone?
Timing does not look okay. I would try another gas station, adding ethanol, or flashing a lower map.
      05-02-2024, 01:59 AM   #4179
Skyhigh
Skyhigh's Avatar
1923
Drives: BMW F36
Used to happen up to 4 out of 5 times with the black MHD adapter! It was absolutely terrible as most of my logs were unusable!
Tried with a second one - same/similar thing.
Since I moved to the MHD Universal one - the problem disappeared completely.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
Appreciate 2
      05-02-2024, 09:28 AM   #4180
WrxToBeamerGuy
498
Im using the Kies adapter.
f30post
