10-23-2018, 10:29 PM | #397 |
10539
Rep 41,185
Drives: 2018 Alpina B6 650ix GC
Use E-Sys FA Editor, and change FA back to it's original factory condition.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-23-2018, 10:31 PM | #398 | |
96
Rep 302
When I set back to original configuration, I assume I would need to go through the normal VCM / CODING steps such as Write to FA FP and then code DCM and the other ECUs individually? The deviation would be to also to do this: Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE. |
10-23-2018, 10:36 PM | #399 | |
10539
Rep 41,185
10-23-2018, 10:50 PM | #400 | |||
96
Rep 302
Even when I tried to Read Coding Data, it throws this error: Quote:
negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: DME2_12_ETHERNET severity: ERROR Looks like entity DME2_12_ETHERNET can't be accessed or not found: Quote:
10-23-2018, 10:52 PM | #401 |
96
Rep 302
I also find it interesting that when I "Detect CAF from SWE" and select the latest I-verion (F020-18-07-547), within the SVT window, the coloring of the DME went from blue target state to black, Actual State.
10-23-2018, 11:25 PM | #402 | |
10539
Rep 41,185
dawei21395.50 |
10-24-2018, 05:45 AM | #403 | |
2376
Rep 8,364
If engine does not start, you will need to supply power via charger or jumping to another vehicle as ShawnSheridan wrote. |
dawei21395.50 |
10-24-2018, 07:47 AM | #404 | ||
96
Rep 302
Bad news is even with the car hooked up to another running car, it returned the same error. So when you say leave ignition on, do you mean hit the on button once so the dash and MMI display is on and with the radio, just no running engine? if so, that's what I did last night when I initially coded it. after Shawn's comment that the car cant be running, I was trying to code with nothing on (everything off). what's the correct method? |
10-24-2018, 12:04 PM | #405 | |
96
Rep 302
I found an older thread with the same issue: https://www.bimmerfest.com/forums/ar.../t-875162.html
That user mentioned this: Quote:
Appreciate all your assistance! |
10-24-2018, 05:14 PM | #406 | ||
96
Rep 302
10-25-2018, 02:02 AM | #407 | |
2376
Rep 8,364
Start/Stop + Brake Pedal = Engine On Start/stop without pedal = ignition on With Engine on: 1. Read & Activate FA 2. Read ECU 3. Check status of DME 4. If CAFD missing or corrupt, inject (Detect CAF For Swe) 5. Press start/stop --> car left in accessory mode 6. Right Click DME Folder --> Code |
dawei21395.50 |
10-25-2018, 09:36 AM | #408 | ||
96
Rep 302
Now have to figure out what happened to the coding to ICM and EKPM2. What are those two units? Quote:
10-26-2018, 12:40 AM | #409 | |
2376
Rep 8,364
Integrated chassis management. Electronic fuel pump control. Process is only used if CAFD is missing or corrupt. Anything is possible, but could not say based on information. |
10-30-2018, 07:56 AM | #410 | |
96
Rep 302
Since I encoded the rest of the ECUs and I didn't change any FDL parameters and if they show up as "Identical" state as the below EKPM2 and ICM units, does that mean then I'm back to my original configuration? EKPM2 State After Read SVT EKPM2 State After Detect CADF for SWE, hit ok, but not Encoded EKPM2 Read from Coding ICM State After Read SVT ICM State After Detect CADF for SWE, hit ok, but not Encoded ICM Read from Coding |
11-02-2018, 12:21 AM | #411 | |
2376
Rep 8,364
11-03-2018, 11:15 PM | #412 |
320
Rep 248
Drives: 18' BSM F80 M3
I tried unlocked Video in Motion via Bimmercode and Vgate wifi adapter but it didn't work. I've set it all to active. Am I doing something wrong?
Also, changing 'Enable SPORT+ driving mode' in ICMQL and KOMBI L7_MID put the car in limp mode (Power steering errors, traction error, TPMS error, and airbag error) I've used the back up to restore the car and it is fine now. Not sure if anyone else had this type of issue. |
01-22-2020, 07:44 AM | #413 |
Rep 2
[QUOTE=blaccm3;23942285]I tried unlocked Video in Motion via Bimmercode and Vgate wifi adapter but it didn't work. I've set it all to active. Am I doing something wrong?
Hi, I just coded this last night and was given an extra set off instructions for my F83. It asked me to move the i drive knob forward and keep it there. On my iphone a progress bar was displayed and when that was complete a menu popped up on screen where I could activate the video in motion. Hope that helps,,,,,,,,,,,,,,,,,,,, |
