04-19-2024, 03:53 PM | #353 |
10543
Rep 41,215
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-23-2024, 05:34 AM | #355 |
Rep 4
I've got fsc code for my car f11 , uploaded and car accepted . I didn't find anything else to do. Only seen settings in some ecu . HU and KOMBI is ok but can't edit kafas ecu settings.is there any other way
04-23-2024, 08:55 AM | #356 |
10543
Rep 41,215
PM sent.
04-23-2024, 08:58 AM | #357 |
10543
Rep 41,215
Add 8TH to FA, and remove 8TD is present, and then VO Code Kombi, Head Unit, and KAFAS with modified FA.
04-24-2024, 02:51 PM | #358 |
Rep 4
Thanks , it's not working on my car ,but I found the solution . Don't accept 8th , need code manually. I did it on headunit and kombi, but can't on kafas. At the end I addded 5as to FA and code only kafas . It works fine without dtc or any issues
04-24-2024, 03:38 PM | #359 |
10543
Rep 41,215
For Gxx car, you must manually FDL Code KAFAS, KOMBI, and Head Unit for SLI. I would not be VO Coding car for 5AS unless I had everything required of 5AS Driving Assistant.
04-24-2024, 04:08 PM | #360 |
Rep 6
I have 530e 2017 with 2 camers (not sure what KAFAS level it is) but i have ID6 with navigation. been trying to activate the speed limit info using bimmercode but no luck, only get "---" on display. any suggestions please
04-24-2024, 04:11 PM | #361 |
10543
Rep 41,215
What is car VIN (last 7)?
04-25-2024, 12:17 AM | #362 |
Rep 4
04-28-2024, 05:43 PM | #364 |
10543
Rep 41,215
For SLI you need an 11F SLI FSC Code and Coding. PM sent.
05-07-2024, 08:42 AM | #365 |
267
Rep 336
Is it possible to code SLI with bimmerutility? Also im guessing third party carplay must be deactivated before tyring to code SLI. my last 7 digits of my vin are G461638
Pure800, Dorch DS2, VRSF sports cat, MST intake, MHD ECA, XHP, Pureboost.de custom tuned
05-07-2024, 12:00 PM | #366 |
10543
Rep 41,215
Yes, you can code it with BimmerUtility. No need to deactivate CarPlay beforehand. You need an 11F SLI FSC Code though before it can be coded. PM sent.
buddyboy266.50 |
05-14-2024, 06:01 PM | #368 |
10543
Rep 41,215
Need a AppID 331 (14B) -> MID SLI FSC Code. No way to get as far as I know.
05-15-2024, 10:10 AM | #369 | |
Rep 33
not possible buy certificate, but possible to code SLI see this car G31 LCI 530d xDrive Touring RHD B57P 15.07.2022
if I helped just click Like for me in main post
