07-29-2022, 11:20 PM | #309 | |
Rep 19
Much of my driving is on city streets at normal traffic speeds. This is when it seems less responsive and I've also experienced low rpm lugging. Now, trying to pass a slow driver at 30-45mph on a busy street while my car is on 6th or 7th gear at low rpm, is a bigger adventure than it used to be. |
07-29-2022, 11:39 PM | #310 | |
Novice
316
Rep 697
mountaineer106.50 |
07-31-2022, 02:38 AM | #311 |
44
Rep 90
Stock shiftpoints work great for daily driving on stage 3. I would say that Sport+ mode in D is a bit rough though.
Main downside to stage 2 is slower shifts when manually shifting. It's very noticeable.
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E40 Mix Stage 2+ Tune | FX-150 HPFP
blacksapphire440i316.00 |
07-31-2022, 12:11 PM | #312 |
Novice
316
Rep 697
I vouch for this as well. Although I do not like how comfort mode rides the clutch as much compared to sport mode. Sport mode is nice for the healthy balance of both
07-31-2022, 04:52 PM | #313 |
1927
Rep 3,911
Not sure I follow!? Please elaborate.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
07-31-2022, 05:40 PM | #314 |
175
Rep 298
I have also noticed how slow manual shifts are in Stage 2 .... thinking I'll go Stage 3 with stock shift points and will be able to override in manual mode! Great idea ...
17 BMW 340iX / DAW UF/ DS2 HPFP
07-31-2022, 06:01 PM | #315 |
816
Rep 1,199
S3 is great. In comfort it's fine and if you don't like the new shift points you can change it. The sport+ shifts are fucking amazing. It's like driving a DCT at that point.
talontdone174.50 |
08-01-2022, 01:03 PM | #316 |
44
Rep 90
Sport+ shifts are insanely quick yeah. Paddle seems faster than the gear selector, but I dunno how accurate that is. Isn't the 8 speed auto w/ manual shifting basically the same as DCT anyways in terms of performance? Aren't modern automatic transmissions w/ manual shifting basically the same as a DCT?
08-01-2022, 01:06 PM | #317 | |
816
Rep 1,199
08-01-2022, 01:14 PM | #318 | |
44
Rep 90
---------------------------------------- To add on this thread, does anyone have tire slip when accelerating pretty aggressively from 2nd-3rd? I've noticed when my tires are brand new I don't really get this slip, but now that they've been used since January, I get a bit of a squeel sound / tire slip when I go from 2nd->3rd on XHP stage 3, contintental dws 06+ tires.
08-01-2022, 06:08 PM | #319 | ||
816
Rep 1,199
Chirp is pretty normal especially on all seasons. I have chirped through third gear as well in S+ on summer tires depending on the road. Totally fine.
08-05-2022, 07:11 AM | #320 |
Rep 8
Anybody knows why for F30/31's built before June 2013 can only use version Stage 3 1.1 and not 1.5? Is the hardware different? And if not, can the software be flashed first to a newer version and then flash xHP version 1.5?
08-06-2022, 01:41 AM | #322 |
1927
Rep 3,911
No, since I never intend to use it.
08-07-2022, 12:29 AM | #324 |
578
Rep 1,473
08-07-2022, 03:24 AM | #325 |
1927
Rep 3,911
My point exactly. As a general rule, none of the tuners really care much about wear and tear, since that is an implied risk and there is zero liability. When a tuner puts a special warning sign nevertheless advising to be cautious with a certain mode, that to me is a clear no-go zone and clearly not worth any performance gains.
I am very thankful to them for making us openly aware.
08-26-2022, 04:12 PM | #327 |
265
Rep 560
I'm using the Stg2 flash and wasn't happy with the OTS shift maps. So, I tried a few different custom variations of the stg2 shift maps, using the shift map editor, but wasn't quite happy with any of of those either. I eventually just went back to the stock shift maps. They're definitely better than the OTS Stg2 maps and my custom variations. I think I'll just stick with these OE maps.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
08-26-2022, 04:20 PM | #328 |
1927
Rep 3,911
What is it that you were unhappy with?
I drove with the default xHP shifting points for a while and was happy. Went for "relaxed" in D for fuel economy and am still happy. Just can't figure out what one could be "unhappy" about. It's simply different RPMs for upshifting and downshifting…
talontdone174.50 |
08-26-2022, 04:44 PM | #329 | |
265
Rep 560
I was happy with the stock shift maps before flashing xHP, so I thought I'd just go with those. And, although the "stock" shift maps are not necessarily my exact OE maps, they're close enough and 'feel' fine.
08-26-2022, 08:37 PM | #330 | ||
578
Rep 1,473
