What did you do to your car today?
05-08-2024, 11:27 PM | #24421 | |
1345
Rep 1,186
Unfortunately, my original CIC is having power related issues and has now developed MOST issues (will sometimes take down the MOST bus/stop transmitting a signal to the combox). I can’t seem to activate the replacement CIC I have fully with nav/connecteddrive, and traffic updates have stopped broadcasting in my area. Plus with a 300GB Apple Music library, the combox sometimes has issues parsing what track is playing. So for the CarPlay functionality (Maps/Apple Music/Podcasts) plus the backup camera ability, it was a no brainer. Mr12Volt is the only option for me, uses MOST for a fully digital input. Plus you get the graphic equalizer too. I have the Individual Audio speakers paired with a PP82DSP amp, don’t want to loose audio quality! |
mattanderson209.50 |
05-09-2024, 02:36 PM | #24422 |
210
Rep 169
Sweet! I'm planning to retrofit the Individual Audio speakers and power them with an MS-8 + JL amp for the under seat woofers. Like you, I want to make sure my source is the best possible quality.
05-09-2024, 04:45 PM | #24423 |
3558
Rep 3,062
I've had to replace four tires in nine years because of the Nashville potholes, the fourth being mounted this afternoon. Funny, I had zero issues living in the Atlanta area for twenty years.
StradaRedlands5029.00 |
05-09-2024, 04:48 PM | #24424 | |
1345
Rep 1,186
It’s just getting bad down here. Not nearly enough money spent on roads and schools… |
05-09-2024, 04:49 PM | #24425 | |
1345
Rep 1,186
The DAC in the combox is pretty good, but FYI it cannot handle super high-res lossless (above 48Khz sampling). That’s the other difference - the Y-cable used for the MULF system still passes audio through Aux, so while you’re using the device’s DAC (if on an iPhone, a damed good one), it’s still an analog source. The Combox makes that interface digital. |
05-09-2024, 05:45 PM | #24426 | |
3558
Rep 3,062
05-09-2024, 08:48 PM | #24427 |
207
Rep 156
Reached the 100k mile club on the 2006, celebrated the occasion with:
-Valve Cover Gasket -Rear Shocks -Mechatronic seals on ZF trans -Oil, Brake & Rear Diff Fluid -Front thrust arms -Alignment Always good when the car makes you smile after some repairs. |
colorado.e9x3121.50 Seattlesquash915.50 StradaRedlands5029.00 tcphoto3558.00 Runnin'Rich100.50 GavinE9124.00 |
05-09-2024, 09:08 PM | #24429 |
207
Rep 156
05-09-2024, 10:25 PM | #24430 |
86
Rep 233
Got a pair of fresh 275/30/19 PS4S for the rears. Although initial turn in is subdued vs 265’s in the rear, definitely feels more planted mid turn and in long sweepers paired with 245’s in front (almost like adding a slightly stiffer sway bar). The fresh 275’s also just grips and goes in a straight line!
05-10-2024, 01:32 AM | #24431 | |
5029
Rep 3,082
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Cheaper as well. |
05-10-2024, 05:48 AM | #24432 |
224
Rep 365
Drives: 2007 BMW 328xi E92 6mt swap
colorado.e9x3121.50 |
05-10-2024, 01:08 PM | #24433 |
30
Rep 60
New runflat after running over something on the highway and ordered another good ole OFHG and puller, idler and belt since it's starting to leak.
/// 07 3.0
05-10-2024, 02:13 PM | #24434 |
1054
Rep 762
Drives: E92 CT200h Cayman Boxster RC
Long Beach Blue E92 with Carbon Fiber Roof
Build Thread |
tcphoto3558.00 |
05-10-2024, 03:10 PM | #24436 |
3558
Rep 3,062
Just washed and waxed it. I'd compound the old paint then polish everything before ceramic coating it if we'd have four or five days without the threat of rain.
05-10-2024, 03:18 PM | #24437 |
315
Rep 279
Drives: Green '07 & Arctic '08 335i's
Blacklines
05-10-2024, 05:11 PM | #24438 | |
eBay Special
3122
Rep 3,042
Drives: E90 330xi
Edit: is it just me or did the app mess up the quote? Looks fine in edit mode. Odd.
Common sense is a flower that does not bloom in everyone's garden
05-10-2024, 06:18 PM | #24439 |
5029
Rep 3,082
05-10-2024, 06:22 PM | #24440 |
eBay Special
3122
Rep 3,042
Drives: E90 330xi
Replaced the blower motor on the 328. Finally I can have the vent on in peace
05-10-2024, 07:07 PM | #24441 |
147
Rep 108
Front hub kits. They were a pita, lots of heat and penetrant. Looks like they were due. Thought I'd see a different OEM but pretty sure these are original based on the date...
Some of my BMW E90 and 3rd Toyota Gen 3D printing projects here...
https://www.thingiverse.com/dylan77/designs |
StradaRedlands5029.00 Cal122206.50 |
05-11-2024, 10:17 PM | #24442 |
103
Rep 139
42cm euro spec warning triangle in my E90 LCI from aliexpress. DIY straps using velcro instead of forking $120 for plastic clips with a thin hinge! Velcro works even better. Looks great, and the triangle is of great quality too. Hopefully won't need to use it.
