TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > I cloned my MSV70 DME
      06-16-2023, 07:41 AM   #2377
pRoxxxDD
Drives: BMW x5
Originally Posted by Terraphantm View Post
Try setting lc_var_sof_swi to 01 (0x423FF in MI20S; I can find it in other program versions if you're on something else)
CONF_SOF_SWI is a RAM address, but the above should be the constant that controls it.
You will need to correct or disable the MO3 checksums to change that value.
Yes, you are right, for me, 0x423FF is the correct address. There is lc_ad_clr_sof for init this thing but, it didn't work for me. By disabling MO3 do you mean c_ctr_diag_tcc_can_max_veh_mod and c_ctr_diag_cks_max_veh_mod? Am using Kess v2, and for coolant temperature, I didn't fix any checksums (Kess fixes it by himself at 0x40304)
      07-05-2023, 06:04 AM   #2378
J_Motorsports
Drives: E90 325i
Can someone provide me with the important fuel / injection map names on the MSV70?
Found the ignition maps (ZWGROUND and ZWOPT) but still could not figure out the injection maps
      07-09-2023, 12:39 PM   #2379
808AWD325xi
Ballin' out of control.
808AWD325xi's Avatar
No_Country
521
Drives: 2009 335i
I don't know if this helps, but there is a XDF here:
https://www.ms4x.net/index.php?title...L921S_128K.xdf
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
      07-10-2023, 11:49 AM   #2380
rjahl
rjahl's Avatar
998
Drives: Z4 35is
2012 Z4 35is  [0.00]
This looks like Hassmachine's work.
Correction, I managed to look at this file in more detail and it does not have his signature. It's probably from someone else. In any case Tunerpro is limited and can not import all of the folders found in this ROM. It may or may not have all of the maps you are looking for.
      07-13-2023, 12:18 AM   #2381
Terraphantm
253
Drives: E46 M3 Coupe
I don't know if he's on this forum, but there's a member sda2 on other bmw forums, he's the one who generated this xdf.
Apparently the tunerpro limitation is no longer an issue as of 5.00.9816​
      07-15-2023, 02:07 PM   #2382
edmak
Drives: e82 125i
Hi, i know that there is no damos/xdf for msv80, but maybe someone have his own custom? Even partial would be great, i wana to increase throttle response and maybe some temperature settings.
      10-29-2023, 09:19 AM   #2383
bmw335coding
Drives: 435d xDrive
hi guys,
after crashed my original msv70 i bought a used one and flashed it with winkfp to right zusb 7518220 (ecu hw was same). Winkfp was successfully flashed the module and updated AIF. The ZUSB before was 7559500.
Now i get these "2AB4 - DME, interner Fehler, RAM-Checksumme".
Anyone has an idea to fix it? I think i have all tools (tools for reading/writing bdm mode too).
      11-15-2023, 03:00 PM   #2384
Benjamino4946
Drives: 2006 BMW Z4 3.0i 6spd
Question
Originally Posted by diedvdijk View Post
He guys,
Thanks you all for your way of thinking about my problem. I was not able to trigger the MIL again with the file with changed settings regarding to the cluster. I think it's indeed the problem with driving and driving since for now, the files I used yesterday only gives me a fault once during driving.
I didn't try the EU file. I tried the stock version and the first 3.0si US file. that last file gives me the error more than 5 times. The adjusted file from yesterday only give me once during driving. for now it looks like it fixed. But I don't know how end why.
What will I noticed with the more aggressive EU map. hoger torque at lower rpms? better fuel consumption? I know that EU cars are less emission cars that US variants.
I still want to try the files if that helps. The file I am running now looks fine.
How come this error is disappeared now? Anyone have an explanation?
I am having the exact same errors as you, but I have used the 7623588 3.0i to 3.0si file on Bimmerlabs. I get the same errors, but everything seems perfectly fine otherwise. Would you be able to share the file used that fixed your kombi and fuel level codes? I also have an early 2006 model so it looks like the hunch about earlier models being affected is correct. It looks like Bimmerlabs is down and has been for a while or I'd try other files myself.
      11-22-2023, 12:48 AM   #2385
Johnny05
Drives: BMW E90 328i N62
What an awesome thread! After reading it all there’s still something missing (or maybe I missed it), the power class byte location for both MSV80 and MSD80/81. Could you guys share them please? Much appreciated!
      01-29-2024, 06:59 AM   #2386
sda2
Drives: E46 M3 Touring & Sedan
He is now
What could be interesting is a solution for the 1024kgh limit on MSV70 and MSS70.
In theory we came up with a solution to make use of 2048kgh which is basically the same on all MPC petrol ECUs from MS45 to MS*70.
That does not solve the 510nm hardlimit though.
      02-25-2024, 08:01 AM   #2387
atheodor
Drives: 2006 E90 330i
thank you hassmaschine and everybody else for contributing to this post.
It is a great resource for MSV70 tuning. congrats
      03-30-2024, 05:48 PM   #2388
wojt0320
Drives: e60 525i n52b25
Guys do you know what i need to modify for a proper decat msv70 ???
      04-19-2024, 12:55 PM   #2389
TIMO373
Drives: bmw e90 325i
i got my ecu cloned its msv70
i got my ecu cloned because it was water damaged but i put it in still doesnt start just cranks do i need to do something with the cas module or anything i would need quite a bit of help can anybody tell me the full procedure how to clone it fully and make it start
