Sockets 335i build
12-11-2016, 05:12 PM | #2289 | |
162
Rep 1,175
12-12-2016, 01:48 AM | #2290 |
4552
Rep 11,908
12-12-2016, 04:49 PM | #2291 |
Rep 79
I am after some PS2 actually, anything to get rid of that rattle and get real response back + powaaa, not one controlled by WG rattle fix by jb4 or mhd. Need inlets and stage 2 pump and im good to go to next level.
12-12-2016, 11:30 PM | #2292 |
4552
Rep 11,908
Sweet, inlets and stage 2 pump def needed for aftermarket turbos as is a bigger FMIC and DPs
12-13-2016, 04:30 AM | #2293 |
Rep 79
12-13-2016, 07:27 AM | #2294 |
4552
Rep 11,908
12-13-2016, 02:52 PM | #2295 |
251
Rep 1,582
12-14-2016, 12:23 AM | #2297 |
4552
Rep 11,908
12-14-2016, 12:25 AM | #2298 |
4552
Rep 11,908
12-14-2016, 12:53 AM | #2299 |
4552
Rep 11,908
Mod 77 - Sub Woofer Install
Have not been that happy with the audio upgrade (mod 73) Lacked bass and the tuning was a mess Ended up buying an E93 sub woofer system and listed it in the forum, but no one was interested in it so, I installed it myself Main bits that went in were an Alpine pdx 1.6 amp, an Alpine type R 10 sub woofer in a sealed custom made E93 box and a mess load of heavy duty stinger cabling lol Spent hours trying to work out why the SW amp would not power up, figuring out how the speakers were bridged and getting the tuning right. Still need it to be tuned professionally and to get the sub woofer properly mounted. But everything is in, operational and now 30 - 175 Hz range is filling out the sound stage Doof doof doof Pic 1 - Step 1 - Strip out boot lining Pics 2 to 4 - Step 2 - Connect power and test, then hit the internet when it wont fire up Pic 5 - Step 3 - Find out you need a rem-in line to tell amp to wake up (face palm) Pic 6 - Step 4 - Run tuning software 30 times until to you get it right Pic 7 - Step 5 - Unplug and re-route because amp wont fit where you were planning to mount it Pic 8 - Step 6 - Mount amp in new location and reinstall all the boot trim Pic 9 - Step 7 - Strap down sub woofer with ocky straps as a temp mounting solution Done |
Boganian Rubes161.00 |
12-14-2016, 03:01 AM | #2300 |
Lieutenant Coal Burner
161
Rep 1,639
Lol where did you get those blue battery adapters?
And the audio input?
2008 Titansilber 320d E90 Auto | K&N High Flow Pod | Ecotune DPF Delete + Performance Tune | 2.5" Custom Exhaust | 19" Mars Concave Alloy's | Matte Black Front Splitters and Grille | Mars Tinted Monochromatic Tail Lights | Carbon Fibre Wrapped Door Trim + Interior Trim
12-14-2016, 03:07 PM | #2301 |
251
Rep 1,582
Interesting.
I currently run a precision 6266 (Gen1 BB) on my GTR which is only a 2.6L (albeit a built 2.6L) and it has better response (approx. 500rpm better) compared to the old twin setup and makes 430kw at all 4 wheels only on 21psi and 98ron pump fuel (getting it setup for e85 and a flex tune very soon ). With the 335i being a 3 litre, if you go a 6262 in the newer Gen2 version (which is supposed to spool even quicker then the previous gen), then it is going to come on boost pretty hard and fast Should make for a fun drive |
12-14-2016, 08:09 PM | #2303 |
4552
Rep 11,908
12-14-2016, 08:12 PM | #2304 | |
4552
Rep 11,908
12-14-2016, 08:13 PM | #2305 |
4552
Rep 11,908
12-14-2016, 08:30 PM | #2306 |
251
Rep 1,582
12-14-2016, 08:44 PM | #2307 |
4552
Rep 11,908
Mod 78 - P3 Vent Gauge
While some peeps say you don't need one, I like boost gauges First guage was the JB4 gauge hijacking of the oil temp on the dash. Not really very accurate and not having the oil temp displayed was a pita Next was a ECS boost gauge from the US. It only came in LHD and it annoyed the hell out of me that the dial was always facing the passenger side So ripped it out and went back to the JB4 until I removed the JB4 when I switched to MHD Looked seriously at an Adwon in vent system, but the price is insane and there is some doubt if they work properly with heavily modded E92 Finally got around to fitting the P3 I got from Will a couple of weeks back (thanks Will ) which provides a digital gauge, as well as coolant temp and a few other handy readouts.... While I realize, you can get the same displays on a phone, I prefer the clean look of the integrated solution thanks Pics below Pic 1 - P3 kit including useless instruction manual Pic 2 - Boost line routed into engine bay Pics 3 to 6 - Installing the screen in vent Pic 7 - Feeding wiring harness through the dash Pic 8 - Plug harness into port Pics 9 & 10 - Install complete |
12-14-2016, 09:47 PM | #2308 |
900
Rep 6,285
12-14-2016, 09:59 PM | #2309 |
4552
Rep 11,908
12-14-2016, 10:21 PM | #2310 |
1496
Rep 3,148
Great looking gauge, also has water temp which is a really handy
