03-07-2023, 04:01 PM | #22771 | |
Driver
2692
Rep 2,714
So if you tell them to brake at the ideal point for a low speed exit corner in a 400+ hp car, they are not going to be able to handle the amount of rotation that goes with that ideal braking point (aside from the fact that they will feel like they are going to go off and be semi-panicked). You need to bring them into the technique slowly, in almost all cases.
E90M 6MT Slicktop Single Humper in need of a diet
03-07-2023, 06:37 PM | #22772 | |
1581
Rep 8,077
Drives: 11 E90 M3 Individual
Maybe I misspoke earlier but there really isn’t an advanced technique but there certainly is an advanced way to apply a technique. Advanced drivers know when to apply a certain technique. If you’re slower on faster tires then that is most certainly a skill issue in applying all of the driving techniques. Trail braking more or less isn’t going to fix that.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
Tommysalami563.50 |
03-08-2023, 05:19 AM | #22773 |
11
Rep 19
These are 20+ lbs each, not 17. The NT03+M sacrifices weight savings for more structural integrity.
03-08-2023, 05:22 AM | #22774 | |
166
Rep 478
I agree with you esp on your previous post. Over here, it's even worse. All you need is 5 track days to get in "advanced". Yup, just 5 to be a mobile chicane.
But I'm not a coach. I can just read telemetry based on **shudders** extensive sim experience. I also believe a good coach articulation skillset converges with the race engineer. In modern times, this separates the fast from the ones a notch above; think Verstappen etc. There's a funny story about Mika Hakkinen complaining about understeer. So they threw increasingly more front at it. To which he complains it got worse. Poor guy was scrubbing the tyres out of habit to force the car into understeer because it was so nervous for him, lol. You would see a hint of it in the primary three inputs such as steering angle.
Bilstein CS | Rays ZE40 | Solid/spherical front / rear.
YouTube |
Bartledoo2691.50 |
03-08-2023, 05:53 AM | #22775 |
1573
Rep 2,871
all the discussions about driving techniques are a good topic with many good points and few simplistic suggestions. The main challenge is to convert a discussion into action plan a driver can execute. call it a procedure to improve. There are so many connected actions, but where to start?
When I look at someones data, I am not looking for the ultimate results. I am looking for low hanging fruit. What can I suggest that is easiest to implement? I will give specific example: I look at the relationship between steering angle and the throttle. If I see the steering angle increased and the throttle % also increase, I recommend that the driver FORCE themselves to NOT apply throttle before he can open the steering NO MATTER how slow they go. What I am looking for is for the driver brain to develop a vacuum. I want them to feel the agony of going too slow. Before, based on the data, the driver was compensating for slow entry speed with early application of the throttle. The problem is that the brain developed the wrong idea. The brain now feel that the car is on the edge, and the feeling of “I am going as fast as I can possibly go” sets in. Now if you feel that you are on the edge, to go faster you develop the habit of taking more risk. This I don’t like. I don’t want my driver to develop to habit of risk tolerance. My philosophy is that stepping into a track day, you assume a certain risk. My goal is to go as fast as I can keeping the risk constant. There is a lot more things like that that I do, but rather than a superficial list, I wanted to delve deep into one thing. As usual, comments are welcome. |
03-08-2023, 06:34 AM | #22776 |
1573
Rep 2,871
Some physics to concider when braking hard.
When we see Formula 1 cars braking hard and deep into the corner, we admire the action and want to do the same. But we want to concider physics before we immitate a race car with our road car. If you are on a relative, to a true race car, on soft suspension, with 200tw tires and ABS, braking hard as you can push the brake pedal may not yield the best results. First, the harder you brake on softish suspension the more the nose go down and the rear goes up, second your front 200tw tires may exceed their ideal traction profile (and overheat before the corner, where you need them to perform) and third the ABS will be activated. On the E92 M3 it happens around 1100psi. So looking at data, the optimim max brake pressure is about 1000-1100psi. Given that, it dectates when to start braking and how quickly to start releasing the brake pressure. I would suggest that at 1000 psi you only want to be at that pressure for a second before reducing the pressure gradully to 900-800..400psi. As the car slows down, you need less pressure for the same decelaration. Ideally you will not increase pressure ever coming into a corner. This helps you brake with all 4 wheels on the ground giving you the largest contact patch. It also create a stable platform coming into the turn. As an experiment, go in a straight line and brake at 400psi. You will be amazed at how much braking the car is doing at 400psi. Now go in a straight line at different speeds and apply the brakes at the same psi. Say at 400-500. You will develop the sense of how much braking you got in a relative “low” brake pressure. Now look at your speed trace at your last HPDE event and corrolate the pressure on the track at the same speed you practice on the road. Why do I like road exercises, because they are free and you can do it as many times as you need. While I agree that driving above 80-90mph on track is not the same as canion and public road driving, I would suggest that on the track below 80-90mph would be similar to what you can practice on the road. For example, I practice all winter left foot braking in my work car, and on the first trackday in the spring I was left foot braking and felt at home. I did not have to re-learn LFB at the track after it became second nature on the road. Another exercise at home is trail braking. While you can’t practice the technique per se on the public road, you can practice the release of the brakes without dumping the brakes at the end. Drive your daily car, soft car is good, and as you come to a stopsign, apply the brakes to a maximim pressure, start releasing the brakes at the same rate you closing the distance to the stopsign. Practice coming to a stop with such light brake that the car stop WITHOUT you applying more pressue and WITHOUT the nose of your soft car pops up. The goal is to practice the relationship between the brake force and decelaration. Observe that for the same decaration you need to brake less as speed decreases. There are more practices you can do on the public road in between trackdays. No, you can not drive like lunatic on public road to practice for your up and coming HPDE. |
jvictormp919.50 |
03-08-2023, 10:36 AM | #22777 |
Driver
2692
Rep 2,714
rhyary I have been bothered since I was a child by people (my parents) not trailing off the brakes when coming to a stop, so I started implementing the smooth stop practice when I started driving haha.
03-08-2023, 11:32 AM | #22778 | |
564
Rep 465
I don't think it's advanced technique, but really just that advanced drivers use techniques more effectively. I guess I'm arguing about semantics here, which can be annoying so sorry My parents and lots of other people start out braking very soft and then brake way harder as you get closer to the stoplight or intersection. Drives me nuts! |
03-08-2023, 03:42 PM | #22779 | |
1581
Rep 8,077
Until those things happen I’m just keeping them on track. Certainly very little trail braking. I’m telling them to brake enough so I know the car can get through the turn. It it usually a little faster than the student is comfortable.
03-08-2023, 05:25 PM | #22780 | |
1581
Rep 8,077
The key is coming off the brakes. How quickly and how smooth can you do it? The smoother and quicker you are it, the more weight you keep over the front tires for longer. This is why most drivers complain about understeer at turn in. Its not the setup or the tires, its the driver and how they are applying the technique. Actually, those saying braking longer is faster are 90% wrong. Building max brake pressure for a shorter distance is faster than applying the brakes for longer. What makes threshold braking slower is the driver doesn't have the control, feel, and sense to be on and off the brakes quick and smooth. So what happens is the driver stomps the brakes, jumps off the pedal and overslows the car in doing so. Then tries to turn in. The car has lost the forward weight transfer so it understeers and you go slower through the turn. I know I don't threshold brake in some cases because I can't get off the brakes fast and smooth enough to keep the weight transfer forward and get the car to respond. Instead I brake for a little less for longer. And I probably lose at least .2-.3 seconds in those turns. Being below threshold braking is similar to maintenance throttle. Its slower but sometimes you have to do it but it is mostly because of a lack of skill and control.
03-08-2023, 08:19 PM | #22782 |
3998
Rep 3,416
That’s the exercise at hand. We each repeat each other in various ways and self congratulate. 😆 It’s a nice community
Not a Doctor, those are just my initials.
03-08-2023, 08:47 PM | #22783 | ||
1581
Rep 8,077
It's the very reason why adults will almost never become a professional driver. The quickness and smoothness of the inputs become naturally far better. Kids have a developing nervous system that learns those inputs. Adults do not, most probably have a degrading nervous system. We can be super smooth but then we'd devote so much of our focus on being smooth this one time that other things may suffer. It's that initial smooth input on any of the controls that makes a big difference. Did not see where it was talked about. If it was then I apologize.
admranger3001.00 |
03-09-2023, 11:48 AM | #22784 |
1550
Rep 1,751
i should give my beginners pov
bigjae19761581.00 |
03-09-2023, 07:09 PM | #22785 | |
166
Rep 478
YouTube |
03-09-2023, 09:48 PM | #22786 |
Driver
2692
Rep 2,714
I always preached how little work the 6mt is in the M3 vs the DCT…well, now I’m over here tipping the C8 on its side to fit two extra liters into the DCT lol.
Edit: why does m3post randomly flip images??!
hsaguirre72.00 |
03-09-2023, 09:49 PM | #22787 | |
1967
Rep 1,927
Drives: E92 M3
Motorsport Safety Foundation is trying to standardize instructor training material but it's not necessary achieving that goal at the pace some expect. However, it did result in a lot of HPDE organizers attempting to improve instruction and hopefully addressing the nonsense. So what you'll end up seeing as a novice now with some of those MSF "Level 2" HPDE organizers is that they'll start suggesting different things than what we're used from instructors years ago. An instructor working with a novice, having them learning about and practicing trail braking on their first day? Absolutely happening today. A novice that's triple braking into a corner and then braking again past the apex after they've been attending HPDEs for a decade? Also happens...
03-10-2023, 07:53 AM | #22788 |
1478
Rep 2,672
True dedication flipping the C8 upside down to properly top up the DCT
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
Bartledoo2691.50 bigjae19761581.00 |
03-10-2023, 03:24 PM | #22789 |
920
Rep 821
