Vibration at highway speed (doubtful related to wheel balance) - please help
07-27-2021, 09:39 PM | #199 |
Art Collector
2427
Rep 3,450
Just to follow up:
Replaced my steering rack but am still hearing a kind of grinding/whining noise that I’m positive is coming from the steering. Oh well lol… I guess some things you just have to let go. To recap, I’ve had two new LuK pumps (and a used one before that) and have changed fluid and reservoir multiple times now. Running car without serpentine belt = no noise. Running car with shorter belt to bypass AC = same noise. Alternator also new. Sooo, that leaves only power steering. Anyway, this is kinda a separate issue to this thread, but I did post a few back about replacing steering shaft (worthwhile) and rack (probably not).
When I'm dead, just throw me in the trash.
09-25-2021, 12:10 PM | #200 |
Rep 34
Did you ever find out wht three things?
Just bought an F10 2015 with seat wobbles from 65mph thru till 80 Anybody solve this?
2015 520d F10 Saloon B47 351 Alloys
09-25-2021, 12:21 PM | #201 | |
Rep 34
04-30-2022, 02:35 AM | #202 |
Rep 9
Sorry for resurrecting the old thread guys.
I found the cause of vibrations in my case so wanted to share it in case someone will search in the future. Story: I have intermittent vibrations (at speeds over 60 - 70mph) on my e92. I have read this whole thread and was ready to diagnose everything listed here. My main suspicion was towards rear brake calipers intermittently sticking. So I took the spray bottle and after my trip to work (around 35mins on motorway) I've sprayed all brake discs with water - aaand nothing. After my commute back home I decided to repeat the test and after spraying the rear nearside disc it greeted me with generous amount of steam and sizzling sound. The other 3 corners were barely warm. So now I'm 95% sure I found the culprit of my problem. The reason why I was suspecting my brakes is because sometimes in the mornings when reversing back I could feel some resistance, I thought I was hitting a curb or something. I hope this helps somebody in the future! And remember - if they are sticking intermittently the problem may not reveal itself every time when checking this way with spray bottle. |
06-02-2022, 12:05 PM | #203 | |
2371
Rep 3,560
06-18-2022, 06:23 AM | #204 | |
Rep 34
Vibration FIXED!
I changed tyres, all the brakes, suspected buckled wheel so I bought refurbed wheels but nothing solved it. Then, last week, the lower coil snapped on the rear spring. I had them changed for BMW original parts at my local indi for £375 including the springs and the wobble has dissappeared. The car drives sublime again. Rear has firmed up too. The road force thing is junk, don't waste your money. I've been searching for a solution to this issue for a year now and hundreds of people seem to be having this issue please spread this solution.
Wolf 3352370.50 |
09-15-2022, 11:51 PM | #205 | |
Rep 6
Drives: BMW X5 X40i
09-16-2022, 09:30 AM | #206 |
166
Rep 429
Drives: 2008 BMW 335i Coupe
After changing to BC Coilovers the issue has mostly gone away. I think maybe a new set of tires road force balanced & maybe an alignment will get everything perfect.
