10-30-2018, 08:02 PM | #111 | |
1865
Rep 3,661
Thanks.
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
10-30-2018, 08:09 PM | #112 | |
6586
Rep 5,305
- The knob separates from the lower ring via two tabs. You will see them after you pull off the knob. - The boot is glued to the lower ring which is sandwiched to the knob when fully installed. - Just gently peel away the boot from the ring. You can choose to glue the new boot onto the ring if you want a seamless install. I just tucked the boot in between the ring and knob before jamming the knob on the shifter which forced the boot to be sandwiched. My methods are not for the OCD. |
10-30-2018, 08:19 PM | #113 | |
1865
Rep 3,661
Thanks. Few questions. When you say ring you mean the silver one just below the knob. Correct? I looked at this IND video and I think the first step would be to remove the complete assembly (knob with the boot) and then work on it off the car? How did you attach the Alcantara boot to the square bottom portion? Thanks.
10-30-2018, 08:35 PM | #114 | |
6586
Rep 5,305
10-30-2018, 08:52 PM | #115 | |
1865
Rep 3,661
Also can you answer the 2nd question I had above regarding the lower square portion of the boot? Did you just wrap that Alcantara around it or staple/glue it? Thanks again.
10-30-2018, 09:05 PM | #116 | |
6586
Rep 5,305
You don't need to use glue to attach the bottom of the boot to the frame. The boot has cutouts along the perimeter that latches onto hooks on the frame that line up to the cut outs. The stock boot also has staples (overkill imo) that are easily removable. You can choose to staple the new boot. I chose not to. |
///M///1865.00 |
10-31-2018, 10:06 AM | #117 | |
399
Rep 852
When you mention thin and cheap (which I can understand with the price of the shifter boot) do you think it would be a obvious difference if I were to get the OEM alcantara ebrake boot+handle to add later? I'd like to hope at least the color and darkness of the alcantara's match |
10-31-2018, 10:26 AM | #118 | |
4999
Rep 4,139
10-31-2018, 10:26 AM | #119 | |
231
Rep 238
Not being the most confident in my DIY skills I dropped it in to a local Auto Upholster to do the swap. I'll post pictures when it's all done. I do agree that the material is a little thinner than the handbrake alcantara but it doesn't appear to differ in how it will sit. |
10-31-2018, 10:59 AM | #120 |
399
Rep 852
saveywil1
Thanks for the response, yeah I guess I wouldn't really be handling the alcantara bits that much but if it isn't the texture/weight that matches, I def want the color to match. Looking forward to your photos when you post. G35POPPEDMYCHERRY I want to retain illumination and the Mperformance one is too small and does not illuminate. Ive seen the zhp one in e46's and they visually look beefier but look oem. And it's more weighted and shorter. |
11-03-2018, 04:58 PM | #121 |
231
Rep 238
Lacking confidence I went to an auto upholsterer, I wish I had not. They cut the supplied boot off and then unsuccessfully tried to glue it on the inside of the new boot. They also managed to break the two smaller tabs. Unsure that it is salvageable.
11-06-2018, 01:01 PM | #122 |
11
Rep 33
For anyone with the M-Performance shifter, I just bought mine and once installed it looks slightly out of line (the shift pattern does not look to be sitting perpendicular with the car). Has anyone else notice this. Hopefully this makes sense. I will post a photo when I get a chance to take one.
11-06-2018, 07:57 PM | #123 | |
110
Rep 253
JOEY | '18 AW M3 ZCP 6MT | '18 Raptor |
11-06-2018, 09:50 PM | #124 | ||
11
Rep 33
11-06-2018, 10:12 PM | #125 | |
110
Rep 253
11-07-2018, 08:27 AM | #126 |
11
Rep 33
Definitely turned out to be my eyes playing tricks. Sat in the middle back seat and the lines were dead straight. I'm thinking it's because the M Sport knob doesn't really have any pattern lines for gears 1-4 where as the M Performance knob has more of a pattern since the "M Performance" is much thinner than the "M" logo on the sport knob.
joegie110.00 |
11-09-2018, 08:40 AM | #127 |
1397
Rep 3,152
I just LOVE the regular shifter
12-25-2018, 10:42 PM | #128 |
561
Rep 442
Drives: 01' E46 325i / 16' F80 M3
I went back to the factory knob but stayed with iND's tri-stich boot. I love how it lights up. I knew I was going to go back. You can't go wrong with either one. I'll be going from one to the other you guys watch. 😂
mr.paulo.dias
07-19-2019, 04:35 PM | #129 |
Rep 42
Dont mean to revive an old thread. But I was gassed by what people are charging for these shifter setups (HIGHWAY ROBBERY).
You can get the same thing here: https://www.ebay.com/itm/28355266415...m=283552664151 Genuine, from BMW, fits perfect in F80 |
09-16-2020, 01:53 PM | #131 |
693
Rep 834
reviving this thread because i want the m-performance knob but im getting confused. It seems like the f-series m-performance knob with the white stitching does not fit on an F80 m3 only the other 3-4 series?
https://www.ebay.com/itm/BMW-Genuine....c100903.m5276 https://www.buybmwpartsdirect.com/oe...ob-25112222534 Is there a different one for the m3?
2016 M3 6MT, Yas Marina Blue/Silverstone - Sold
2023 X3M Competition, Brooklyn Grey |
05-13-2024, 09:04 AM | #132 |
23
Rep 66
Resurrecting this old thread to see if there are any aftermarket (or genuine BMW) replacement options for the F80 shift knob that light up? MY shift knob could use a refresh due to the leather looking and feeling a bit tired, but I don't want to sacrifice the illuminated shift pattern graphic if I can avoid it.
