Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What did you do to your car today?
      05-08-2024, 11:27 PM   #24421
Hoody007
Hoody007's Avatar
1345
Drives: 335i ZMZ LCI | 850i/6
Originally Posted by mattanderson View Post
I'm curious, what are your main use cases?
I'm about to try retrofitting the Combox in my non-iDrive car, simply to get good a good iPhone -> USB music connection, but I'm not yet convinced that I shouldn't have pursued an aftermarket solution.
Everyone has a different use case/priority, though.
The combox is a notable upgrade from the MULF system. If plugged in via USB, you can hear the difference between the two when using Apple Music Lossless. The iOS integration is nice too (text / iMessage in iDrive).
Unfortunately, my original CIC is having power related issues and has now developed MOST issues (will sometimes take down the MOST bus/stop transmitting a signal to the combox). I can’t seem to activate the replacement CIC I have fully with nav/connecteddrive, and traffic updates have stopped broadcasting in my area. Plus with a 300GB Apple Music library, the combox sometimes has issues parsing what track is playing.
So for the CarPlay functionality (Maps/Apple Music/Podcasts) plus the backup camera ability, it was a no brainer. Mr12Volt is the only option for me, uses MOST for a fully digital input. Plus you get the graphic equalizer too. I have the Individual Audio speakers paired with a PP82DSP amp, don’t want to loose audio quality!
      05-09-2024, 02:36 PM   #24422
mattanderson
210
Drives: 2007 E92 328i
Sweet! I'm planning to retrofit the Individual Audio speakers and power them with an MS-8 + JL amp for the under seat woofers. Like you, I want to make sure my source is the best possible quality.
      05-09-2024, 04:45 PM   #24423
tcphoto
tcphoto's Avatar
3558
Drives: E92 335i 6MT Coupe
I've had to replace four tires in nine years because of the Nashville potholes, the fourth being mounted this afternoon. Funny, I had zero issues living in the Atlanta area for twenty years.
      05-09-2024, 04:48 PM   #24424
Hoody007
Hoody007's Avatar
1345
Yeesh. If it makes you feel better, ATL roads have gotten awful - between my E46 and old E90, I replaced one rim and had 7! wheels straightened. Not too mention at least 5 tires (at that time, I ran exclusively Michelin Pilot Sport all seasons).
It’s just getting bad down here. Not nearly enough money spent on roads and schools…
      05-09-2024, 04:49 PM   #24425
Hoody007
Hoody007's Avatar
1345
You’ll love them! Very nice response curve, in my experience they need some taming in the 5-7khz range. Definitely on par with high end aftermarket stuff. They love power though (what speaker doesn’t), the JL-amp will pair nicely with them indeed.
The DAC in the combox is pretty good, but FYI it cannot handle super high-res lossless (above 48Khz sampling). That’s the other difference - the Y-cable used for the MULF system still passes audio through Aux, so while you’re using the device’s DAC (if on an iPhone, a damed good one), it’s still an analog source. The Combox makes that interface digital.
      05-09-2024, 05:45 PM   #24426
tcphoto
tcphoto's Avatar
3558
I lived in downtown Atlanta for fifteen years and those metal plates were everywhere but I never had an incident with potholes. I then moved an hour east to Madison and the worst road was Hwy83 heading up to Athens and still no pothole encounters. I have a set of VMR wheels on order and I stuck with 18" despite my desire to go with 19" for esthetics.
Appreciate 3
      05-09-2024, 08:48 PM   #24427
Cal122
207
Drives: 2006 325i 2011 328i xDrive
Reached the 100k mile club on the 2006, celebrated the occasion with:
-Valve Cover Gasket
-Rear Shocks
-Mechatronic seals on ZF trans
-Oil, Brake & Rear Diff Fluid
-Front thrust arms
-Alignment
Always good when the car makes you smile after some repairs.
Appreciate 6
      05-09-2024, 08:56 PM   #24428
mattanderson
210
Congrats! I hit 100k last month and the car has never felt better.
Cal122206.50
Hoody0071344.50
      05-09-2024, 09:08 PM   #24429
Cal122
207
Thanks, same to you! I don't ever remember the car driving as good as it does now.
      05-09-2024, 10:25 PM   #24430
Shoooter_j
86
Drives: 07 e92 335
Got a pair of fresh 275/30/19 PS4S for the rears. Although initial turn in is subdued vs 265’s in the rear, definitely feels more planted mid turn and in long sweepers paired with 245’s in front (almost like adding a slightly stiffer sway bar). The fresh 275’s also just grips and goes in a straight line!
      05-10-2024, 01:32 AM   #24431
StradaRedlands
StradaRedlands's Avatar
5031
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.25]
2009 BMW 328i Touri ...  [8.00]
2013 BMW X5 35i  [7.80]
2011 BMW 528i  [8.70]
2006 Mazda3  [5.50]
They don't look as good, but 16" tires will sure fare better from a pothole hit.
Cheaper as well.
      05-10-2024, 05:48 AM   #24432
Leucosticte
Leucosticte's Avatar
224
Drives: 2007 BMW 328xi E92 6mt swap
2007 BMW 328xi  [0.00]
Cheaper as well.
They won't clear 335i brakes though.
      05-10-2024, 01:08 PM   #24433
SF07e70
30
Drives: 2007 X5 3.0
New runflat after running over something on the highway and ordered another good ole OFHG and puller, idler and belt since it's starting to leak.
/// 07 3.0
      05-10-2024, 02:13 PM   #24434
RealJ22
RealJ22's Avatar
1054
Drives: E92 CT200h Cayman Boxster RC
2007 BMW 335i  [0.00]
Re Parked her in the garage and my wide body showed up at the same time.
Long Beach Blue E92 with Carbon Fiber Roof
Build Thread
tcphoto3558.00
      05-10-2024, 02:40 PM   #24435
Nando_e90
El Salvador
111
Drives: 2006 E90 330i
Originally Posted by RealJ22 View Post
That e92 looks gorgeus in that color and with those wheels.
RealJ221054.00
      05-10-2024, 03:10 PM   #24436
tcphoto
tcphoto's Avatar
3558
Just washed and waxed it. I'd compound the old paint then polish everything before ceramic coating it if we'd have four or five days without the threat of rain.
      05-10-2024, 03:18 PM   #24437
BRG_N54
BRG_N54's Avatar
315
Drives: Green '07 & Arctic '08 335i's
2008 BMW 335i  [0.00]
Blacklines
Picked up a slightly used set of Blackline taillights from Reddit, of all places. The Arktik looks good, but the green looks great!
Appreciate 3
      05-10-2024, 05:11 PM   #24438
colorado.e9x
eBay Special
colorado.e9x's Avatar
3122
Drives: E90 330xi
2007 BMW 328xi  [9.50]
2006 BMW 330xi  [10.00]
[img]"]"]"]https://i.ibb.co/vmpkVkj/Green-Blackline-01.jpg[/img]
blackline 🔛🔝
Edit: is it just me or did the app mess up the quote? Looks fine in edit mode. Odd.
Common sense is a flower that does not bloom in everyone's garden
Appreciate 4
      05-10-2024, 06:18 PM   #24439
StradaRedlands
5031
2006 Mazda3  [5.50]
The more you know!
      05-10-2024, 06:22 PM   #24440
colorado.e9x
eBay Special
3122
Drives: E90 330xi
Replaced the blower motor on the 328. Finally I can have the vent on in peace
Appreciate 3
RealJ221054.00
Cal122206.50
      05-10-2024, 07:07 PM   #24441
MidWillamette335d
MidWillamette335d's Avatar
147
Drives: 2009 335d
Front hub kits. They were a pita, lots of heat and penetrant. Looks like they were due. Thought I'd see a different OEM but pretty sure these are original based on the date...
Some of my BMW E90 and 3rd Toyota Gen 3D printing projects here...
https://www.thingiverse.com/dylan77/designs
      05-11-2024, 10:17 PM   #24442
codeterrorist
103
Drives: 328i
42cm euro spec warning triangle in my E90 LCI from aliexpress. DIY straps using velcro instead of forking $120 for plastic clips with a thin hinge! Velcro works even better. Looks great, and the triangle is of great quality too. Hopefully won't need to use it.
Appreciate 3
