BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > How to reset rear windows on 2014 f30 335 please help!
ARMA SPEED
      04-23-2015, 12:00 AM   #1
Dim718
17
Drives: 335xi sedan
I had my battery disconnected after reconnecting it my rear windows go down auto but don't go back , I have to hold the switch for them to go all the way up , I tried every method I came across on Google . Couple of guys I read have same issue on the newer cars is there a new reset trick?
      04-23-2015, 07:23 AM   #2
TMD29
Don't care
TMD29's Avatar
117
Drives: 17 SO M3 ZCP
This is the method I use:
1. clean the window of any residual coatings such as glues etc from the windwos. use an approved window cleaner for window tint. (as for me windex cause i dont care if the tint gets affected I want them clean)
2. press and hold the window down button on the window affected.
3. after is completely rolls keep the button held down for 10 seconds.
4. release the button.
5. pull and hold the window button so the window rolls up.
6. after it completely rolls up continue to hold the botton for 10 seocnds.
7. you have jsut reset the window limits and told the vehicle this is what you should expect when you roll up.
8. test the window to see if that corrects the issue.
9. repeat for other affected windows.
      04-23-2015, 08:15 AM   #3
Dim718
17
Drives: 335xi sedan
Thanks will try
      11-06-2015, 01:18 PM   #4
franzzz
franzzz's Avatar
Italy
144
Drives: BMW M4
UP
Same problem on my F30 ?
any solution ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      11-06-2015, 09:57 PM   #5
Adamr916
Adamr916's Avatar
133
Drives: 2014 328d
Take it to the dealer if it's still under warranty, had this problem with my front windows, had them reset everything, and everything works like it did.
      11-06-2015, 10:15 PM   #6
HFW003
HFW003's Avatar
5718
Drives: 2024 M340i xdrive
Originally Posted by franzzz View Post
UP
any solution ?
Did you actually read post 2 which tells you exactly how to do the reset
      11-07-2015, 01:27 AM   #7
franzzz
franzzz's Avatar
Italy
144
Drives: BMW M4
yes.
does not work
      07-02-2022, 05:22 PM   #8
HH1815
20
Drives: '15 BMW 335i 6mt
Have this issue too. Windows only move 1 inch increments. Removed the regulator/motor, tested it and it spins, replaced the whole assembly (had one lying around) and still does it. Tried every manual reset/initialization I could find on the forums, nothing
'15 335i x-drive 6MT.
Catless DP, CP, Intake, IC - BM3 STG1 93
      04-05-2023, 10:54 AM   #9
Grateful_Newt
13
Drives: 2015 BMW 320i
Anyone ever find resolution to this problem? I didn't have any luck with the cleaning/reset method either. I bought Protool intending to re-initialize the window myself, but there is only an option to do that for the front windows.
Sure would love to fix this so the one-touch function work for up and down again, and so I can look cool rolling my windows up/down with my key fob!
      12-15-2023, 03:39 PM   #10
navid0308
40
Drives: 2012 BMW 335i
Long shot but I recently ended up in this situation. Fronts worked fine but the rears would roll down with one full push but the auto roll up with full pull didn’t work. What I did was fairly simple:
1. Engine running
2. All windows rolled up
3. Pull up the rear window buttons halfway and hold
4. Keep holding. I think it was 20-30 seconds
5. Keep holding! Rear window will then roll all the way down and up by itself two times. Keep holding till it rolls up 2nd time and stops.
6. Auto up down for rear will work as expected
      02-27-2024, 05:36 PM   #11
rlesko
243
Drives: F30 335i
2012 335i  [0.00]
1. Engine running
Bump!! Fixed my issue!!
      05-10-2024, 10:53 AM   #12
JayPixelF33
86
Drives: 2018 430i
This is also possible with ISTA. You can recalibrate windows.
When I had the issue ista saw it in the fault code and I was able to follow the repair instructions which basically rolled the windows up and down several times to calibrate Afterwards problem was fixed.
