05-09-2024, 06:24 AM | #1 |
151
Rep 113
F31 jacking points
I'm sure it's been covered before, but a bit confused having watched several YouTube vids.
I want to get the front of my F31 up on stands; online videos show a reinforced jacking point central under the front of the car, but having had a look, I can't see anything but plastic covers. I could of course jack it on the sill jacking points, but then where do I put the jack stands? |
05-09-2024, 07:18 AM | #2 | |
2017
Rep 2,195
That's the front jack point on the F3X range - use a puck between your trolley jack and that point and you're good to go... You might find the cars too low to get your jack under; so small riser ramps like these, which are what I have, will be spot on: https://www.amazon.co.uk/Laser-5669-...22&sr=8-6&th=1 Rear jack point is the body of the diff itself; again use the rubber puck https://www.amazon.co.uk/Hilka-82998...4&sr=1-29&th=1 Hope that helps
05-09-2024, 07:23 AM | #3 |
384
Rep 254
There's a metal jack point in the center just rear of where the soft splash guard splits. I have to get my jack almost completely under the car to reach it. There are jack stand points probably a foot or more rear of the front wheels. They hang down a bit and are made of hard plastic. They aren't meant to be used with claw type jackstands as they'll beat them up, unless you have adapters. Take a look and you'll see what I mean. There's a good chance they're already a bit mangled.
EDIT: Just saw the post above. Since you have xDrive, the front jack point won't look like the picture in the link (at least mine doesn't, 2014 F31). You'll see a small area of exposed metal. Last edited by Dagstar; 05-09-2024 at 07:31 AM.. |
M80151.00 |
05-09-2024, 07:35 AM | #4 | |
151
Rep 113
Thanks for the responses - much appreciated!
danb19792016.50 |
05-09-2024, 07:54 AM | #6 |
2017
Rep 2,195
Nope; my low clearance Sealey jack can't reach it, so I use those risers
05-09-2024, 02:59 PM | #9 |
2017
Rep 2,195
I've got this Draper jack:
https://www.amazon.co.uk/Draper-3148...c-d11b6e3d217f It still won't get to the central front jack point; I'm on Eibach pro kit springs; but they've not lowered the car that much...
05-09-2024, 03:20 PM | #10 | |
222
Rep 416
1995 E34 525td auto • 2016 F30 320ed auto
05-09-2024, 04:38 PM | #11 |
2017
Rep 2,195
It's about 160mm when I measured. But as said my F31 is lower than factory
It's not a biggy as I use those risers anyways. They make life a bit easier for seeing what you're doing under neath |
05-09-2024, 06:03 PM | #12 |
376
Rep 1,433
Apologies if slightly off-topic, but I wanted to share in case it meets your needs:
https://www.raceramps.com/
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
05-09-2024, 11:20 PM | #13 |
222
Rep 416
Got you. If my F30 was about 15mm lower it would have been impossible to put jack under for this middle point, and I'd had to use something to lift it be it pieces of timber or ramps
danb19792016.50 |
05-10-2024, 02:23 AM | #14 | |
897
Rep 1,126
danb19792016.50 |
