2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning First time BMW owner! Buying a used 2018 m240i, what to know ahead of time?
      05-09-2024, 01:45 AM   #1
noobbmw
Drives: BMW m240i
Hey everyone, buying a used 2018 m240i RWD automatic with 30k miles and wanted to run it by yall. It’s my first tuned car and BMW. It’s stage 2+ 93 octane custom tune with bm3. Getting a PPI done but would like to understand what these logs (the seller shared) indicate. https://bootmod3.net/log?id=64f7f41ec090c6b778de6307
Seller shared that a full kick down with acceleration close to 100% would yield best results.
Is there anything glaring that I may have missed? Most of it looks fairly standard from guides I’ve seen on YouTube. What resources do you guys recommend to learn about tuning? Appreciate any and all help!
      05-09-2024, 07:34 AM   #2
Dom147
103
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
These logs are great. The seller knew what he was doing when it came to producing these. I see nothing wrong everything looks great. Enjoy the new car!
      05-09-2024, 10:26 AM   #3
noobbmw
Drives: BMW m240i
Thanks for shedding some light here. Im in an area with 92 octane as best gas, would that suffice for this tune? or will i have to look at using a different map / dial down power?
      05-09-2024, 10:31 AM   #4
Dom147
103
I’d log it and see what the timing corrections are like. If they’re not more than -3 then it should be fine.
      05-09-2024, 12:38 PM   #5
JMcLellan
JMcLellan's Avatar
2135
Drives: 2024 M2
1 to 1.5 gallons of E85 per tank could also be your friend if you don't have access to high enough octane gas to align with your tuning settings. It helped me in the past when I was seeing larger timing corrections. But keep in mind the stock HP fuel pump can't support that much ethanol in your tank. Getting the TU HP fuel pump is an easy and cheap option if you go down the ethanol path and want to run more than a couple gallons of E85. My stage 2 M240i with the TU pump and running about 4 gallons of ethanol per tank was an absolute beast. **I did this for a few thousand miles with zero issues but I don't know what impact ethanol has on these cars long term. My two cents.
2024 M2
2019 M240i- Sold
      05-09-2024, 03:18 PM   #6
noobbmw
Drives: BMW m240i
Got it, that makes sense. Thank you Dom and Jmc. I’ll try 92 for now and understand what logs say with that. There is a TU pump on this car. If there are timing issues revealed in logs, from what I understand my options would be:
1. Add some e85 to each tank to see if that corrects it
2. Dial down power on custom tune
3. Choose a different map?
My goal is to preserve the car in its current state as it drives great (perfectly to my standards). Thanks
Dom147102.50
      05-09-2024, 04:47 PM   #7
JMcLellan
JMcLellan's Avatar
2135
Drives: 2024 M2
The easiest and most effective for me was to use E85 to remove the timing corrections. I even had timing corrections on stage 1 93 octane maps but that's the gas I'm dealing with here. I also found a gas station that had 93 octane and E85 all at the same pump so it was convenient.
If you don't want to rely on E85 you could try other maps and check the logs to see. However, I do like what Dom said that if the timing corrections are pretty slim then don't worry about it that much.
2024 M2
2019 M240i- Sold
Dom147102.50
2addicts
