BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > N55 PWG VTT Stage 1 Not Hitting Boost Target?
Extreme Powerhouse
      05-03-2024, 01:56 AM   #1
witty
witty's Avatar
16
Drives: 2010 BMW 335i M-Sport
I've had this issue for a while now, but I've exhausted all of my options and am genuinely confused.
Things I've tacked:
Adjusted wastegate arm
smoke tested/pressure tested to 25 psi
no codes
mods
afe intake
bms inlet
wanger tuning evo 3 fmic
vrsf chargepipe
vrsf downpipe
vtt stage 1 turbo
m2 diverter valve
on bm3 ots 2H 93 Map
Two 4th Gear Logs:
https://datazap.me/u/tochez/log-1714718776?log=0&data=6
https://datazap.me/u/tochez/log-1714718785?log=0&data=6
From the logs, I can see my wdgc is not high.
my hpfp and lpfp are good
afr is good
I am hitting some weird ignition issues (either fuel or need to reset adaptions due to adjusting wastegate)
Im not sure why but boost hits, goes down, comes back up, and then its a steady decline down.
At this point I feel like its a tune issue, but if anyone can chime in, that would be great.
'10 354 E90 335i - Wedge Performance - 1K FMIC - ARM DP - Injen CAI - TD04L 19T Turbos - Stage 2+ LPFP
      05-04-2024, 12:02 PM   #2
witty
witty's Avatar
16
anybody?
      05-06-2024, 06:20 PM   #3
Wires
1666
Drives: 2016 340i xDrive
Not an expert tuning the BMW platform, but APR's look really rich for direct injection. Are you running methanol with this setup?
On straight gasoline, the B58 runs close to stoic (14.7:1) (yeh, sounds scary lean) vs the typical 12-12.5:1 for power like you are seeing.
Dropping aside, eating popcorn until those that spend more time tuning this platform chime in.
      05-06-2024, 10:54 PM   #4
witty
witty's Avatar
16
I'm not too sure but I'm n55 and usually the afr is about 12.5 on wot.
Wires1666.00
      05-07-2024, 07:36 AM   #5
Wires
1666
Are you running the flex fuel kit? What type of fuel are you using?
Have you tried dropping back to their OTS 91 maps? Maybe it's a fuel quality issue.
      05-07-2024, 10:17 AM   #6
Orion4
491
Drives: 2013 335i Sport Line Sedan
Have you tried resetting to baseline to see if it clears up?
      05-07-2024, 06:50 PM   #7
witty
witty's Avatar
16
I'm running 93 oct, I'm east coast so they only have 93. No flex fuel kit.
      05-07-2024, 06:51 PM   #8
witty
witty's Avatar
16
if you mean resetting adaptation it helped with the timing corrections, but boost is still an issue.
      05-07-2024, 07:11 PM   #9
Wires
1666
I'd still try 91 octane maps. You can go lower with no issues, going higher than the maps for the fuel gets you knock retard.
      05-08-2024, 11:16 PM   #10
witty
witty's Avatar
16
here's another log, it seems like the psi is holding better than before after I had reset the log, it also seems like bm3 is asking for more boost all a sudden which I don't understand why.
https://datazap.me/u/tochez/log-1715...log=0&data=4-6
      05-09-2024, 07:19 AM   #11
Wires
1666
The boost at the end is due to the load target change when you shifted gears.
It is odd that it can exceed the boost level before that point, yet it slowly drops below the target pressure up to the gear change.
