05-06-2024, 11:21 PM | #1 |
167
Rep 599
I20 iX genuine brake upgrade. Low-key top configuration.
When it comes to upgrading the factory brakes, many owners opt for the sporty and vibrant red version. But there are also those who prefer to keep things low-key and avoid flashy colors on their vehicle, and so, like this iX (I20) pictured here, chose to upgrade their car with a blue version of the M Power high-performance system. While the blue M Power calipers may not grab attention like the red ones do, they exude a touch of understated luxury and a unique personal style.
I'd call them a sleeper brake. The iX originally came equipped with another blue version of the M Sport braking system, smaller 4-piston calipers at the front and a single-piston caliper at the rear. For an electric vehicle weighing over 2.5 tons, this braking setup was just "good enough" in terms of overall braking performance but felt a bit "soft". The upgrade, on the other hand, features 6-piston calipers at the front and a single-piston caliper at the rear, along with larger and better heat-dissipating 395mm front and 380mm rear semi-floating discs. Compared to stock, this upgrade offers stronger braking performance, and greater security. Additionally, the M Power 6-piston calipers feature pistons arranged in a progressively larger configuration, resulting in more linear braking and a smoother braking experience. Also, since it's a genuine BMW factory product, comes with a guarantee of easy installation and compliance with vehicle inspection. That's peace of mind right there. As far as I'm concerned, this upgrade has the iCARMIX seal of approval. Check out our comprehensive list of items, for your I20 iX: https://icarmix.com/?s=I20+ix&post_type=product And look at this beauty! |
05-07-2024, 07:31 AM | #2 |
1744
Rep 1,518
Drives: 2023 iX xDrive50
But why? Why cross drilled rotors on an EV?
Past BMW's
2020 M850i GC | 2020 X5 | 2018 M550i | 2017 X5 | 2014 535d | 2013 X5 | 2007 530i | 2002 X5 | 2000 540i/6 | 1999 M Roadster | 1989 535i | 1984 533i | 1983 533i | 1977 530i |
05-07-2024, 07:53 AM | #3 |
2540
Rep 1,999
exxxviii1410.00 deutsch1004109.50 |
05-07-2024, 10:23 AM | #4 |
2111
Rep 1,214
Brake disks and pads are very rarely used on iX, especially if the owner lives in an urban area and use 'B' mode...
I bet most people won't even need to replace brake pads for the life of the car.
11’ E92 ///M3
15’ F82 ///M4 18’ G30 540i ///Msport 21’ G20 ///M340i 24' i20 iX xDrive50 |
deutsch1004109.50 |
05-07-2024, 10:24 AM | #5 |
631
Rep 1,203
This ‘upgrade’ is purely for esthetic reasons alone, since the actual braking 95% of the time is done via regeneration, or a blend of regeneration and mechanical brakes. In the incredibly rare case of a true emergency stop when regeneration isn’t much in the mix, stopping the car is all about the tyres as the OEM brakes will work perfectly well. The only time the OEM brakes might be lacking is in perhaps fade after repeated high speed, high deceleration braking, but anyone using their iX on a road course is mental anyway.
LVBMW1623.50 |
05-07-2024, 10:57 AM | #6 |
1744
Rep 1,518
Right. So essentially a spam post for ~$5,000 USD cosmetic upgrades that only serve to increase unsprung weight at each corner.
Past BMW's
05-07-2024, 12:18 PM | #7 |
1410
Rep 972
Drives: ix xDrive50
This seller looks like it posts an ad in every forum every month or two. It has been happening for a while, so the moderators must be OK with it.
2024 iX xDrive50 Phytonic Blue on Mocha with DAPP, Premium, B&W, Ventilated & Radiant Heated Seats, Adaptive Headlights, and Luxury
05-07-2024, 12:35 PM | #8 |
701
Rep 872
Are these actual M compound pads? If so, on an EV, they're gonna squeal like crazy when used. In the M cars I've had in the past, you really had to regularly heat up the brakes to get to not squeal.
2023 iX M60
2023 i4 M50 2024 Wrangler 392 |
05-07-2024, 12:40 PM | #9 |
1744
Rep 1,518
Only if you or the iX uses the friction brakes. Not to mention the brake dust.
Past BMW's
05-07-2024, 04:03 PM | #10 |
2540
Rep 1,999
Now there's something I don't miss from my previous modern BMWs...
My 335xi, X4 M40i and X5 40i all had m-sport brakes and the brake dust was crazy. I eventually stopped caring but for those that are OCD about keeping their cars clean, this would drive them crazy. I lived with it because I traded the cars in before needing a brake job. I only had to replace pads on my X4 because they wore unevenly between the inside and outside pad, so one of them was almost completely gone while the other was still very thick but BMW didn't admit to it being an issue on their end... I went with a quality non-bmw pad through my indie garage, I believe it was a pad made by Bilstein. No dust in comparison to the OEM ones and I noticed absolutely no difference in braking. So if anyone is having that issue with another BMW, this is what I would suggest. |
05-07-2024, 09:47 PM | #11 |
167
Rep 599
Hi, thanks for the concern of the forum, and my posts. I've actually been around here a while, posting as a private individual. But in order for me to be able to use watermarks on my photos (which are taken from my garage, on the installs I do), I had to pay a sponsor fee. So I decided to go all in, and also change my name into my brand name
05-07-2024, 09:49 PM | #12 |
167
Rep 599
05-07-2024, 09:55 PM | #13 | |
167
Rep 599
05-08-2024, 07:38 AM | #14 | |
Generalissimo
691
Rep 1,468
05-08-2024, 07:59 AM | #15 |
1410
Rep 972
Drives: ix xDrive50
This does raise a curious question to me... EV friction brakes rarely get used. I go weeks at a time without every engaging the friction brakes. They last forever. So, the usage patterns are radically different from every other type of car.
Therefore, do BEV automakers use different brake pad compounds and disc designs given that they will last the life of the car and need to work perfectly when bone cold?
05-08-2024, 08:36 AM | #16 | |
2540
Rep 1,999
05-08-2024, 11:09 PM | #17 |
167
Rep 599
It's fine, I enjoy posting about what we do. I've had some people commenting that the photos are cool. Some even ask me for advice in PM. It doesn't have to lead to a sale (which by the way, we ship overseas). If it leads to a "thank you", and maybe even some extra clicks on my website, I'll be happy!
05-09-2024, 02:50 AM | #18 | |
167
Rep 599
Tags |
hong kong, icarmix, ix interior colour, m brake kit, m power |
