smoke under heavy braking only
04-27-2024, 05:53 PM | #1 |
Rep 5
car Does not smoke on accel or decel or idle at operating temp. I noticed it only smokes after braking really hard or slamming the brakes. never any smoke on regular decel without brakes or in any situation. the smoke smells awful any clue to what it might be?
04-27-2024, 07:43 PM | #2 |
17
Rep 35
I had something similar, turned out to be water in the mufflers running back up to the hot cats. Take a 1/8" drill bit and make a hole in the lowest part of each muffler. You will be surprised at how much water will come out.
DCT, MHD 2+, MMP DP, ETS 5", ER CP w/ Turbosmart Dual Ports, Whiteline RSFB, RB PCV, Kohlefaser Luft-Technik Intake, R1 Concepts Drilled/Slotted w/ Akebono Ceramics
APEX EC-7 18x9 245/40 Alpin PA4 (winter) 313M 19" 235/265 PS4S (summer) |
n54Newb0.00 |
04-28-2024, 09:00 PM | #3 |
Rep 5
YES!! i believe my mufflers are full of water.... i drove the car for 2 hrs no smoke at all and did a couple wots when i had space that wont force me to heavy brake. and when i got home after the drive im able to touch the bottom of my mufflers barehand and it felt cold make sense it would stay cold if there's lots of water pooling.
05-06-2024, 12:14 PM | #4 |
17
Rep 35
I genuinely surprised there's no seep holes in the mufflers from the factory. This is something I've seen on almost all the other vehicles I've had.
05-20-2024, 06:13 PM | #5 |
Rep 5
question i put a small hole thru my mufflers and the left side had like a whole water bottle in it if not more. the right side dripped black watery soot for a while too. Before i would drive for hrs and i would touch the exhaust mufflers it would be cold. now after making a hole and getting some of the water out. the muffler isnt cold but its still touchable and part of is still cold i have bought a borescope and tried looking at my turbo lines. and my rear turbo feed line is leaking and i can trace the oil down to the bottom of my catless downpipes from the outside. would that cause smoke at all.... now on cold starts i get no smoke i drive for 10 secs and stop i get small puff of smoke. but after 2-3 mins of driving no smoke at all. i still get smoke when i brake heavy and lets say i got the car to operating temp and i shut it off for 1 hr or 2 and i start it first couple mins of driving boosting idling anything with car on it would smoke but after the car is slightly warmed up no smoke anything.im guessing there bunch of gunk build up thats burning off or maybe because im missing my secondary o2s...... not sure i recall with my previous n52 e90 i wouldnt be able to touch the muffler if it ran for more then 5 mins and i accidently burnt my self on it years ago. by touching it for split second. doesnt seem like my current muffler is getting any where near as hot
my parking spot is on a incline where the front of my car is lower then the back. Last edited by n54Newb; 05-20-2024 at 06:16 PM.. Reason: added |
