Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 359M's on an E90 M sport
      04-10-2024, 12:37 AM   #1
HoonsE90
HoonsE90's Avatar
19
Drives: 2010 e90 335i M sport
Hi all,
Recently I cracked my 193M rim up front. Between being difficult to find a replacement and literally being dead in the water with no spare, I caved and bought a set of some 359's. These came with some brand new tires at a 245/35/19 in the front and 275/35/19 in the rear. Since I just needed to get to and from school and work, I mounted up the front passenger side wheel so I could at least commute. I notes some rubbing going over speed bumps but I wasn't too surprised. The tire/rim is essentially flush with the fender so I will get them rolled ASAP. As for the rear, using willtheyfit.com, I read that my rear tires would not be pushed out by 30mm. That seems INSANELY aggressive for the non-M fenders. Given that I love how meaty the tires look, I am sure that for these to work I will need a less-wide tire in order to stretch it a little bit. I've added a picture of how the front fits my car as well as the actual set... judging by the sidewall you can see why I REALLY want to make these work haha
Has anybody had experience with 359m's on the e90 chassis with the M sport suspension? I have done some reading but wanted to see if there was anything recent.
God I hate potholes...
2010 E90 335i M Sport// DP's, Chargepipe, DCI's, MHD Stage 1+
      04-10-2024, 03:28 AM   #2
wrevilo
45
Drives: 2010 E92 335i N55 6MT
What are the dimensions of the wheels and their ET?
As you say, those tyres are wide and have a really square shoulder.
      04-10-2024, 10:41 AM   #3
HoonsE90
HoonsE90's Avatar
19
I attached a picture with all the info, yep I’m thinking the fronts will be fine with a rolled fender, worried about the ear
      04-10-2024, 10:42 AM   #4
HoonsE90
HoonsE90's Avatar
19
Sorry for the insanely large rotated pictures, these are coming straight from my iPhone
      04-10-2024, 04:35 PM   #5
HoonsE90
HoonsE90's Avatar
19
Fitted the rear
Tried out the rear wheel… definitely too wide. Anyone think a fender roll and pull would clear it?
      04-11-2024, 12:27 PM   #6
AWD Addict
Chief Executive
AWD Addict's Avatar
304
Drives: 2008 335xi 6spd Coupe
2008 335xi  [0.00]
This is why I decided to run the 359 Fronts on both front and rear. 10" wide rears isn't going to work, even with a fender roll. Just looking at your picture shows that pretty clearly, but there are a ton of threads/posts on this. The M fenders those were designed for are quite a bit wider than even a rolled rear.
I'm running the 359 fronts without spacers and on coilovers (which should be roughly sport suspension height) and they're flush with no rubbing.
https://www.turnermotorsport.com/p-2...59-19x9-front/
      04-12-2024, 12:42 PM   #7
HoonsE90
HoonsE90's Avatar
19
I see, that’s smart. I bet that is an awesome looking setup.I may see about adjusting my camber for a slight negative amount and get an alignment/rolled fenders which I think may make these work. Love the way the fill in the wheel well
      04-12-2024, 12:58 PM   #8
whyzee125
1701
Drives: Dinan stage 2 335i
I think you can keep the wheels but may have to get a narrower tire or at least one with a more rounded sidewall + a little camber
      04-12-2024, 03:58 PM   #9
tcphoto
tcphoto's Avatar
3558
Drives: E92 335i 6MT Coupe
You're trying to fit a square peg into a round hole, the offsets are too aggressive and the front fender cannot be rolled because it's made of plastic.
Ali-E90383.00
      04-16-2024, 11:26 AM   #10
AWD Addict
Chief Executive
AWD Addict's Avatar
304
2008 335xi  [0.00]
That.
Stop wasting your time. Those rear wheels won't fit. There are plenty of people online who've tried. You're not cutting new paths here.
Do some searches, and either grab some fronts for the rear, or move on.
Just for posterity, I believe the fronts fit up front - at least, they do on the e92. No fender rolling or spacer required (at least, with my drop there isn't).
      05-06-2024, 12:09 AM   #11
dleccord
101
Drives: 2011 BMW 335i E90
Do you have the 359 square setup on an LCI? M sport suspension?
      Yesterday, 08:30 AM   #12
AWD Addict
Chief Executive
AWD Addict's Avatar
304
2008 335xi  [0.00]
