01-11-2024, 03:15 PM | #1 |
Rep 12
Vanos issue S63tu
I just replaced all 4 solenoids and camshaft sensors after i found i had a vanos exhaust code. Car still saying vanos code also in limp mode. I was told the vanos gear needed to be replaced. Is there any other way to find out whats causing vanos issue without replacing the gear?
01-15-2024, 09:56 AM | #2 |
10
Rep 21
Let me guess. Also getting “cold start uncontrollable” and “lift values 2000%” ?
I’m chasing the same thing. Coils, plugs, solenoids, camshaft position sensors… all nothing. |
01-15-2024, 06:58 PM | #4 |
105
Rep 148
Drives: BMW's
Garage List 2020 G07 X7 [0.00]
2013 E70 X5 [0.00] 2003 E46 M3 [0.00] 2013 F10 M5 [0.00] 2009 E90 335ix [0.00] 2009 E90 M3 [0.00] |
Vanos is a relatively simple system. If the oil was changed and the solenoids were replaced it’s 90% chance a gear replacement is required.
01-17-2024, 07:29 PM | #6 |
10
Rep 21
I’m going to do the chain while I’m there, it’s a big/expensive job labor-wise so why not just do some extra parts while you’re there. I’m at 106k, so I’m going to do chain/tensioner and cam gear
01-20-2024, 07:21 AM | #7 | ||
105
Rep 148
Drives: BMW's
The gear can be replaced with just removing the valve cover and front drive belt/ crank pulley |
M5Rick61854.00 |
02-20-2024, 09:22 AM | #11 |
10
Rep 21
Not yet, have had some things pop up in life (lost my daughter to a brain tumor, 7yrs old). Car is on a battery tender in the garage. Been trying to keep my household together and figure out the next day as it comes. If you find a solution, please let me know. I’d like the answer or at least know what’s going on before I drop it somewhere for work.
02-24-2024, 04:01 PM | #13 |
10
Rep 21
05-23-2024, 08:01 PM | #15 |
10
Rep 21
So I haven’t done it yet, car has been on a battery tender and I run it every so often. But I did take it to a reputable Indy shop and they said it was the VANOS actuator. The electric motor that turns the VANOS gear in the head.
