2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Anybody else with "Increase Battery Discharge"
      05-06-2014, 12:48 PM   #67
crmgr
Drives: 2011 BMW 535XI M-Sport
I took delivery of my new 2014 M-Sport end of March. It has about 1,000 miles. I've seen this message twice. Both times when I had the car out in the drive to wash. All I did was back it out. Also had the doors open to clean the interior. The message came on when I pulled it back into the garage. Haven't seen it any other time. No rhyme or reason to it really. Just sounds as if the car sensed a power drain with a short start/off cycle and turned off some systems to prevent a drain.
I did have a battery problem back in January with my 2011. The message however, was stronger and referenced a discharged battery. Ended up being a bad cell and I had the battery replaced.
My SA says the computer monitors functions and in his opinion is conservative in sending out this new message. Find it hard to believe I would have a battery problem after only 1,000 miles. I don't even use the auto start/stop.
Right now I'll just monitor and see what happens.
Originally Posted by dbs600 View Post
After having my battery replaced for "increased battery discharge" less than one year ago, I'm now getting this new never before seen message. I didn't leave anything on and I've gotten it multiple times thus far. Why!? Why!? Why!?
      06-01-2023, 09:41 AM   #68
mechatony11
Drives: toyota
I apologize for bringing up this old thread. I had a similar issue with my car, it turns out that I had a poor battery cable connection, the negative terminal was loose, so it caused the error message to appear. Cleaning the battery post from corrosion and re-tightening it made my car work properly. I did a lot of searches on this issue and came on in depth article which may be worth reading, search for " BMW Increased Battery Discharge on YOUCANIC" and you will see an article that goes over common causes and possible fixes, you can read about it yourself. I hope this information can assist someone else with a similar issue.
      06-05-2023, 07:52 AM   #69
Surly73
544
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
"Discharge while stopped" means that the IBS system in the car detects that other electrical systems in the car are drawing more than acceptable power when the vehicle electronics are supposed to be asleep. Tools like ISTA will show you stored logs indicating which circuit branch violated the rules and sometimes even the exact module.
It may very well be that the act of you working on the battery and disconnecting it long enough to do all that cleaning rebooted a module with a software problem and that was the true fix.
There should not be corrosion on your battery posts, and you should potentially investigate that all on its own. Typically this means that acidic gases are being expelled by the battery around the post seals. This is not normal. The battery spec for the F10 is AGM - gas production should be minimal and the seals should keep it in.
Is your F10 fitted with an aftermarket or improper specification battery? Has the battery been physically damaged or lifted by its posts? Have you checked that your system voltage is not too high (it should be between 13.5VDC and 14.8VDC while the engine is running, depending on many factors)?
      06-13-2023, 11:10 AM   #70
Johnkwick
24
Drives: F10 LCI
also dash cam, if you connect your dash cam to a fuse that always delivering power all the time your car will throw battery discharge warning after hours
mine always do this and I just shut the dash cam off whenever I park my car in a closed garage
      07-06-2023, 04:18 PM   #71
mozaah685
Drives: 2014 bmw active hybrid 5
im having this issue right now in my active hybrid. does anybody know if it is due to being on comfort access? because i feel like it is. sometimes my fob key wont work at all sometimes ill walk away from car after pressing lock on fob key and itll lock and about 10 seconds itl unlock it self as im walking away. do i code comfort access off?
      07-06-2023, 04:44 PM   #72
TuunedF10
TuunedF10's Avatar
30
Drives: bmw 535i
If it’s a comfort access issue you can test it by disconnecting the comfort access door handle where you hear it locking or unlocking itself on its own..you want to slide out the door handle and unplug the comfort access connectors and then slide the door handle back in it’s pretty simple to do there is a rubber grommet inside the door jamb you take that off revealing a torx screw then use a torx bit with a long handle to turn the screw and the handle will pull out
      07-08-2023, 09:48 AM   #73
ctcarbonari
ctcarbonari's Avatar
306
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
CA is a common culprit to cause the "Increased Battery Discharge While Stopped" message. For me, it would occur when the car sat idle for ~2 days AND there was significant rain (handle was shorting out on the circuit board solder points).
And yes, my car would do crazy stuff like unlock itself while I was walking away in a crowded parking lot.
A good scan tool will give you the error codes to tell you where the circuit problem is.
I used Bimmerlink and it dialed me in to passenger rear door circuit faults.
      07-08-2023, 06:03 PM   #74
Jasonlaw
Drives: F10
It was your door handle for comfort access (keyless)..lock the car by remote and try to walk toward your car from all 4 corner..the one you walk toward with unlocking all door is the faulty handle..disconnect the faulty handle wire and retry to confirm
      10-24-2023, 12:27 AM   #75
razfrankel
Drives: 2013 bmw 550i xdrive
I got this message yesterday and today what does it mean do I need to charge the battery or buy a new battery? What does the message mean for me the interior lights are not on when I open the car.
      12-22-2023, 11:26 AM   #76
razfrankel
I have a penny inside my car front console cigarette lighter I got it when I had the car and I think thats what’s causing the battery discharge or it’s the battery I think it’s the penny inside the cigarette lighter. How do I get the penny out of the cigarette lighter I need plastic or wood to get out. Please tell me what to do?
      12-22-2023, 07:30 PM   #77
cdmulders
cdmulders's Avatar
331
Drives: 2013 535xi
Gum on a stick.
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      12-22-2023, 09:15 PM   #78
razfrankel
I have a penny inside my car front console cigarette lighter I got it when I had the car and I think thats what’s causing the battery discharge or it’s the battery I think it’s the penny inside the cigarette lighter. How do I get the penny out of the cigarette lighter I need plastic or wood to get out. Please tell me what to do will that fix the issue buy a new fuse as well?
      03-15-2024, 03:05 PM   #79
Riley Jo
Riley Jo's Avatar
Drives: 528i
I own a 528i 2012 drive. I was driving my car just fine then I get the “increased battery discharge” sign on my idrive. Then all of a sudden, my steering wheel stiffs up and I can’t steer easily no more. Then the abs light pops up so I pull over and try to restart the car after shutting it off and no go. After jumping the car, it turns on but shuts off after I unplugged the charging cables. I’m wondering if it’s the battery or alternator. Please someone help !
      03-15-2024, 03:52 PM   #80
JAYDOG3621
18
Drives: 13 528i 13 535i 19 x5 19 230ix
I would say it is most likely your battery, not alternator.
      03-15-2024, 09:51 PM   #81
ChiltiCoatl89
ChiltiCoatl89's Avatar
1780
Drives: 2016 F10 BMW 535i M Sport
+1 on battery, Get that checked out first.
      04-29-2024, 02:11 PM   #82
MICHAELKNIGHT
Drives: 2014 535xi Modern Line
Exactly what my car does! I just found out that my car has the original battery from 2014! I'm going to start there first and replace the battery. But I also noticed the Comfort Access on left front door does not work but car will lock with remote
      04-29-2024, 10:44 PM   #83
ctcarbonari
306
It does amaze me how long these AGM batteries combined with the BMW IBS smart charging are able to last. Mine is 9+ years old as well. I monitor the state of charge and state of health frequently and values are good. It has been on my PM list of things to change out for a long time.
If you are getting an Increased Discharge While Stopped message then it's more likely that you have a power draw somewhere that is preventing a module from going to sleep. A code reader should dial you in where that is occuring. (At least it did on mine when it was a CA handle). Of course, it could be an aging battery too and swapping out a 9 year old battery is always a good idea, imo.
Check out OE Batteries from your local BMW Dealer Parts Department. I was surprised at how competitively priced my local Dealer offers the 105 Ah AGM battery. After my experience with this battery, I'll stick with Genuine BMW Batteries.
Also, many of the aftermarkets on the H9 size are not rated for 105 Ah so it's something to watch for but by no means a deal breaker.
Good Luck!!!
      04-30-2024, 09:13 AM   #84
smokinu454
50
Drives: 2016 535i
I get this every time I leave my MHD adapter plugged in without driving the car for a few days lol.
2016 BMW 535i, MHD stage 2+, XHP stage 3, VRSF charge pipe, VRSF down pipe, VRSF intercooler, ECS turbo inlet pipe
5post
