04-26-2024, 08:00 PM | #1 |
54
Rep 194
Drives: 2024 X3 M40i, AW
Idrive Losing Iphone connection at least once a day or so
Hi All,
Upgraded to 2024 x3 M40i from 2020 one. 0 issues with idrive or airplay connection in 2020 and it NEVER Lost sync while driving. Have i13 pro with 17.4.1 ios and latest idrive software update now. Had the same phone with ios 17 on 2020. This pos 2024 loses connection about once a day and can't reconnect until you shut off the engine- exit and enter the car again- works perfectly fine after every time. Tried rebooting phone/restarting idrive with volume-no help.. It actualy sees iphone but can't sync with it. It tries to reconnect as well but can't seem to do so on the idrive srceen. My iphone can connect to BMW (says connected) but BMW unit can't connect to iphone.. Again, this is all until you shut off the car and start it again- works perfect like nothing happened. It is extremely annoying to drop connection as you are talking over the phone. It's very unsafe too... Is this bmw picking garbage covid chips due to shortage and filling their cars with this crap which works worse than a kia!? Any ideas besides most likely needing an idrive unit replacement? What a pain in the a**! Thanks! |
04-26-2024, 09:43 PM | #2 |
2208
Rep 1,367
Mine does it sporadically too, might go 3 to 4 months with perfect connections, then it drops a few times and all is back to normal. Not sure what it is, but it heals itself until the next disconnect on a '23 M40i.
04-27-2024, 06:36 AM | #3 |
Found the Search Button
1663
Rep 1,217
Drives: 2022 X3 30i xDrive
I’m about the same, once a day definitely isn’t normal.
2022 X3 xDrive 30i M Sport, Brooklyn Grey / Cognac
Previous BMWs: 2018 330i (F30), 2014 i3 BEV, 2007 328i (E92), 2013 X5 35i (E70), 2014 i3 BEV, 2006 325i (E90) |
04-27-2024, 07:34 AM | #4 |
1197
Rep 997
Drives: 2023 X4 M40i (G02)
It's probably a Bluetooth issue and specificlly it's probably on iPhone rather than iDrive.
2004 Toyota Vios | 2004 BMW X3 | 2007 Chrysler Town and Country | 2007 Ford Escape | 2008 Honda CRV | 2017 Nissan Versa Note | 2017 Toyota RAV4 | 2017 Toyota Yaris iA | 2019 Porsche 911 | 2023 BMW X4 M40i
BMWZ41914.00 |
04-28-2024, 09:47 AM | #5 |
Rep 9
Genius at local dealer taught me this and it helped a lot of my iPhone connection issues on my new M40. Unpair the iPhone from the car and remove it from your iDrive connections list (complete delete). Quick reset iDrive and phone. Go to re-pair and make sure the handshake comes from your BMW (e.g., select your phone from BMW menu, not your BMW from phone Bluetooth menu). Apparently making the BMW the primary initiator of the Bluetooth handshake matters.
YMMV |
X3rd Time Is a Charm2870.00 |
04-29-2024, 03:23 AM | #6 | |
418
Rep 862
I had a problem with my CarPlay connection every day on my commute when I boarded a ferry across a river. The person collecting the toll had a handheld device which connects to the ferry via wifi. Every time they approached my car the CarPlay connection dropped out, and reconnected as the person walked away. All I can work out is that their unit was on the same wifi channel as the BMW wifi, and that unit caused the car signal to be overpowered. Unfortunately you cannot change the wifi channel used by the car. I had a similar issue with GPS occasionally on the same ferry. The car's position on the satnav would freeze on the side of the river where the journey started. When I continued the journey, the car would move on the sat nav screen (using the car speed and direction to estimate change of position), but would be in the wrong place by about the width of the river. About 20 mins later it regained a GPS lock and positioned me correctly. This issue did not affect my TomTom GPS. Very strange. |
04-29-2024, 09:37 AM | #7 | |
1314
Rep 981
04-30-2024, 03:41 AM | #9 |
418
Rep 862
04-30-2024, 03:43 AM | #10 | |
418
Rep 862
Changing jobs helped. I no longer travel on the ferry. Since then I have not experienced the CarPlay or GPS issues!! |
04-30-2024, 05:50 AM | #11 |
1663
Rep 1,217
Well there’s your answer. If you have these issues: move, change careers, divorce, abandon your kids, dye your hair, and assume a new identity. 🤣
TXGrey1314.00 ContactPatch2208.00 |
04-30-2024, 10:04 AM | #12 |
1314
Rep 981
Ok - too funny…. So what happens to me this morning? I jump in the car (after using CarPlay on the way home yesterday… since you know, you all got me motivated to try it)… and my phone doesn’t connect… AT ALL. No CarPlay, no iDrive… nada. And it WON’T connect (while driving I mean), no matter what I tried, turned off, etc. So finally I get to work parking garage, delete everything on the car, and the phone, and reconnect. Seems to be working now. I’ll see how it performs on the way home.
Life is full of irony…. You just have to learn how to laugh at it. |
04-30-2024, 10:49 AM | #13 | |
418
Rep 862
Fortunately there wasn't any space on the programme for the wife and kids... |
TXGrey1314.00 |
