Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Bad timing chain?
      04-29-2024, 10:14 AM   #1
bimmerbroken:(
bimmerbroken:('s Avatar
Drives: 2011 328xi but it's black :D
Bad timing chain?
I have a 2011 328xi and have had it for almost a year and I’ve put money into it. However it is still being worked on for a valve cover and valve gasket, I just think the timing chain is going too because when it idles it shakes, and after I drive it a bit and go to a stop for a light, the engine cuts and I have to restart it and it starts perfectly fine and drives fine until that happens again. The engine also cuts sometimes when I turn corners. There was also a high pitch whistling that was figured out as the valve cover but I’m just not sure if the timing chain is going and I should just get rid of the car because it’s a very expensive fix. FYI the car has 210,000 miles on it and there is very little wear and tear on interior and exterior just engine wise.
      04-29-2024, 03:04 PM   #2
335i54n
319
Drives: e90 335i, e39 m5
not common but with vc off you can check the chain tension and timing, more likely other neglected issues
      04-30-2024, 02:40 AM   #3
Phil325i
Phil325i's Avatar
624
Drives: E92 325i MSport Coupe
Why not replace the timing chain tensioner? Easy and cheap DIY job that might fix it...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
