03-28-2024, 11:17 AM | #1 |
Rep 7
Alloy wheels - lacquer peeling?
Hi all,
Looking for opinions on the following: Bought a 2020 330e recently, and have noticed that the lacquer on the alloys are peeling off - at least I think it's the lacquer. Where it is not peeling, it is smooth to the touch, and where it is peeling, it is slightly rough. Causing quite a bit of discolouration where the peeling is occurring as well (it is not surface dirt, tried wiping it away). Anyone have experience dealing with this, or how much it would cost, roughly, to repair? Is it a big job or can it be done DIY? |
03-28-2024, 11:33 AM | #2 |
63
Rep 175
You can try and DIY it. I followed the guide at https://f30.bimmerpost.com/forums/sh....php?t=1348407 to repair some minor scuffs on mine. It's not 100% perfect but it's also much cheaper than getting them diamond cut which would be about £100 per wheel.
03-28-2024, 12:36 PM | #3 |
285
Rep 799
Looks like a previous owner has done a DIY repair on some damage to the rim. These wheels are very susceptible to this type of damage, and it is possible to sand it out and relacquer - but clearly the new coat of lacquer has a limited life span, and dirt is getting under it.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
03-29-2024, 02:18 AM | #4 |
29
Rep 103
I 've had a couple,e of wheels on others BMWs replaced under warranty due to lacquer issues. But this was areas that went a pearly white colour and bubbled slightly. The dealer though did use a paint thickness measurement device to check the wheels hadn't been refinished.
I think I agree with above, looks like a previous repair failing. |
04-01-2024, 12:20 PM | #7 |
206
Rep 624
This was the place
https://maps.app.goo.gl/VyBAjMcxUaxQsgXq8 It's probably worth mentioning they used paint instead of recutting the wheel but they came out well and in some ways paint seems like a more maintainable setup. |
04-29-2024, 03:15 PM | #8 | |
Rep 5
Pain 'em black!
So, does anyone know if these might last longer originals now? However, on the downside, it just occurred to me that I need to tell the insurance - I hope this isn't going to cost me an arm & leg! And please, don't anyone tell me not to bother, I know the motor insurance industry better than most. |
04-29-2024, 05:25 PM | #9 |
100
Rep 221
I’d replace the grille with an all black one to complete the look
To the OP, £60 a wheel is reasonable, ask the dealer who they use, then approach them yourself |
