Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Which tire size for 9J and 10J rims (Veemann VC359) on pre-LCI?
      04-23-2024, 03:05 PM   #1
danielvd
Drives: BMW E90 330i
Hey!
I have a 2005 pre-LCI 330i with Veemann VC359 rims. I’m currently running 225/35R19 on the front and 255/30R19 on the rear, however the rim sticks out quite far.
I’m looking for some new tires and want to change the tire size so the rim is actually protected by the tire.
I’m torn between 235 or 245 in the front and 265 or 275 in the rear. Does anyone have any advice or pictures they can share of their own setups (359, or any other 9J/10J rims)?
Thank you!
      04-24-2024, 04:02 AM   #2
wrevilo
48
Drives: 2010 E92 335i N55 6MT
Those are large wheels, and you are running the OEM spec tyres, which on those wheels are narrow and low-profile.
https://www.tyreleader.co.uk/tyres-a...ls-equivalence
235/35 and 265/30 might work.
      04-24-2024, 06:43 AM   #3
Malteser_wfj
52
Drives: BMW 335i 2012 Manual
Originally Posted by danielvd View Post
Hey!
Thank you!
I've got 235/35 on the front and 265/30 on the back of factory 313M 19"
      04-24-2024, 08:50 AM   #4
whyzee125
1704
Drives: Dinan stage 2 335i
Depending on the offset you could go 235/265 or 255/275
      04-24-2024, 02:25 PM   #5
danielvd
That looks very nice, but those are 8J and 9J right? Mine are 9J and 10J, so I don't think I can use those tire sizes for reference.
It's 9J ET35 in the front and 10J ET38 in the rear.
Last edited by danielvd; 04-24-2024 at 02:27 PM.. Reason: Properly quoted the messages I'm replying to this time
      04-24-2024, 03:16 PM   #6
335i54n
319
Drives: e90 335i, e39 m5
no tire is gonna protect the rim, with 19 your limited on sizes/pricey and cant go too wide as it will be also taller and cause issues rubbing. imo downsize to 18 or get better width/offset 19
235/265 , 245/275, 255/295 is how sizes correlate
      04-24-2024, 03:21 PM   #7
danielvd
What’s wrong with my width and offset? And yes, I am debating between 235/265 and 245/275. Don’t know which one to pick.
      04-24-2024, 06:24 PM   #8
mattanderson
210
Drives: 2007 E92 328i
You just quoted it:
If you go wide enough to "project the rim," you will likely be rubbing.
335i54n318.50
wrevilo47.50
      04-24-2024, 06:26 PM   #9
danielvd
So is 245/275 too much? 😨
      04-25-2024, 03:16 AM   #10
wrevilo
48
You might need to consider the tyre choice as well. Some have larger rim protection than others. For instance, Goodyear tyres generally offer more rim protection other brands I have had fitted. It might make sense to be conservative initially and go for 235/265 even though they will still be on the narrower side for your wheels.
This is also a good resource and might help:
https://apexwheels.com/fitment-guide...-fitment-guide
