BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Issue installing E90 rear carrier ball joint.
      04-22-2024, 04:39 PM   #1
pbinpb57
Drives: 2003 E39, 2008 E90, 2011 E92
2011 328i E92  [0.00]
2008 328i Sedan  [0.00]
2003 525i  [0.00]
Hello everyone. Long time lurker and first time posting.
To the point, I'm replacing the rear carrier ball joints on our daughters 08' E90 Sedan. I've already replaced the passenger side ball joint with no issues. This morning I pressed out the drivers side, it came out very easily. The issue is, when I went to press in the new one, it slides into the mount (yolk) with no resistance. It's seems as if the whole has been previously enlarged. The replacement ball joint is correct (33326792553) Lemforder 364260.
Any ideas? I'm at a loss.
      04-22-2024, 06:53 PM   #2
335i54n
319
Drives: e90 335i, e39 m5
try a cheaper joint (less precise/larger maybe?) and retaining compound for sure if u find one to fit
      04-22-2024, 07:21 PM   #3
pbinpb57
2003 525i  [0.00]
Possible but the ball joint needs to be 1-1.5 mm wider. I'm hoping that it doesn't turn into a full on MacGyver solution.
Here are a few pics.
      04-22-2024, 09:13 PM   #4
335i54n
319
i think u will have luck with a cheaper unit and high strength retaining compound. gl
