I cloned my MSV70 DME
06-16-2023, 07:41 AM | #2377 | |
Rep 9
07-05-2023, 06:04 AM | #2378 |
Rep 1
Can someone provide me with the important fuel / injection map names on the MSV70?
Found the ignition maps (ZWGROUND and ZWOPT) but still could not figure out the injection maps |
07-09-2023, 12:39 PM | #2379 | |
Ballin' out of control.
521
Rep 1,289
https://www.ms4x.net/index.php?title...L921S_128K.xdf
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
07-10-2023, 11:49 AM | #2380 | |
998
Rep 2,287
Correction, I managed to look at this file in more detail and it does not have his signature. It's probably from someone else. In any case Tunerpro is limited and can not import all of the folders found in this ROM. It may or may not have all of the maps you are looking for. Last edited by rjahl; 07-10-2023 at 05:50 PM.. |
07-13-2023, 12:18 AM | #2381 | |
253
Rep 775
Apparently the tunerpro limitation is no longer an issue as of 5.00.9816 |
07-15-2023, 02:07 PM | #2382 |
Rep 1
Hi, i know that there is no damos/xdf for msv80, but maybe someone have his own custom? Even partial would be great, i wana to increase throttle response and maybe some temperature settings.
10-29-2023, 09:19 AM | #2383 |
Rep 5
hi guys,
after crashed my original msv70 i bought a used one and flashed it with winkfp to right zusb 7518220 (ecu hw was same). Winkfp was successfully flashed the module and updated AIF. The ZUSB before was 7559500. Now i get these "2AB4 - DME, interner Fehler, RAM-Checksumme". Anyone has an idea to fix it? I think i have all tools (tools for reading/writing bdm mode too). |
11-15-2023, 03:00 PM | #2384 | |
Rep 6
11-22-2023, 12:48 AM | #2385 |
Rep 4
What an awesome thread! After reading it all there’s still something missing (or maybe I missed it), the power class byte location for both MSV80 and MSD80/81. Could you guys share them please? Much appreciated!
01-29-2024, 06:59 AM | #2386 | |
Rep 1
What could be interesting is a solution for the 1024kgh limit on MSV70 and MSS70. In theory we came up with a solution to make use of 2048kgh which is basically the same on all MPC petrol ECUs from MS45 to MS*70. That does not solve the 510nm hardlimit though. |
Seattlesquash915.50 |
04-19-2024, 12:55 PM | #2389 |
Rep 1
i got my ecu cloned its msv70
i got my ecu cloned because it was water damaged but i put it in still doesnt start just cranks do i need to do something with the cas module or anything i would need quite a bit of help can anybody tell me the full procedure how to clone it fully and make it start
