M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Low boost pressure compared to boos target pressure and tick noise when warm
      02-03-2024, 07:24 AM   #1
NoahFR
Drives: BMW M2 F87 370
Hello fellow car enthusiasts,
I hope this message finds you all well. I'm reaching out to the community with a peculiar issue I've been experiencing with my BMW M2 N55, which is currently running a Stage 2+ tune by MHD.
The concern arises when the engine reaches operating temperature, at which point I notice a distinct ticking noise. Additionally, during acceleration, there seems to be a noticeable hole in power accompanied by what sounds like a pressure leak.
Here's a breakdown of the modifications I've made to the car:
Downpipe: MARSHAL catless
Boost and Charge Pipe Kit: FTP Motorsport
Air Filter: Sport BM
Intercooler: do88 Performance
I'm reaching out for any insights, advice, or experiences you may have had with a similar setup. If anyone has encountered a ticking noise or experienced issues with acceleration after similar modifications, I would greatly appreciate your input.
Thank you in advance for your time and expertise. Looking forward to hearing your thoughts and suggestions.
LOG : https://datazap.me/u/noahf/bmw-m2-st...=0&data=4-6-18
SOUND : https://youtube.com/shorts/Jo3w1HbgdGw?feature=share
      02-03-2024, 09:20 AM   #2
TheHaze
154
Drives: '18 M2
Not sure about the ticking noise, but a 2-3 psi difference in boost target and actual points to a leak somewhere. Check connections at the turbo to boost pipe, boost pipe to IC, IC to charge pipe, and charge pipe to throttle body.
      02-03-2024, 10:37 AM   #3
NoahFR
Thank for you message, I'm going to lift the car to recheck all the connections, but it seems to me that I already had this feeling while driving before installing the charge pipe / boost pipe, I had carried out the replacement after the original one exploded
I read on some posts that the problem could come from the wasegate and it was recommended to add this part: GFB DV+ T9357
      02-03-2024, 02:37 PM   #4
TheHaze
154
Drives: '18 M2
Hmm, it's odd that you were experiencing loss of power even before changing anything. Maybe it was the charge pipe starting to fail.
Have you checked to make sure the car isn't throwing any codes? I would think if the diverter valve was malfunctioning there would be a code associated with it. Either way the GFB DV+ is a quality item, I have the same one in my car.
      02-03-2024, 03:43 PM   #5
NoahFR
Yes, I checked the codes and it's ok, no codes come back. I think the noise is affecting my problem but I can't identify it
      02-04-2024, 05:24 AM   #6
NoahFR
I have made a new test; the first acceleration is in mode comfort, and the second acceleration is in mode sport.
LOG : https://datazap.me/u/noahf/m2-test-2...4&tmax=1492.44
      02-05-2024, 03:38 PM   #7
TheHaze
154
Drives: '18 M2
Just going off your logs, it certainly looks like you have a boost leak. Boost actual psi keeps falling below target and wgdc goes up to rebuild pressure.
I'm not sure about that ticking noise, but the two issues could absolutely be related. Does the ticking speed up if you rev the engine?
      02-06-2024, 04:21 AM   #8
NoahFR
The ticking is always regular, if the engine is idling after 1 minute the ticking stops and if the engine is off and very hot the ticking lasts 10/30 seconds.
This guy have a same sound : https://www.youtube.com/shorts/gjdYXMqwvyw
The sound is slightly different from a heat expansion sound. The intensity and interval do not vary.
      02-06-2024, 06:14 AM   #9
TheHaze
154
Drives: '18 M2
Might be something with the diverter valve like you said. The noise is coming from that side of the engine and would explain the boost issues.
      02-07-2024, 02:07 PM   #10
NoahFR
After 6 hours of work to remove the valve it's good... I confirm that it is this part responsible for my problem after disconnecting the noise disappears
You think I need change part or if a plug a new gfb dv+ on the old part it's good ? The electromagnet does not hold, it releases every second
      02-07-2024, 07:20 PM   #11
TheHaze
154
Drives: '18 M2
Glad you were able to pinpoint the issue! I reused the old portion of my diverter valve when I installed the GFB, but mine wasn't broken. I'm not sure if there's a way to bench test the diverter valve to make sure it's functioning correctly, may be possible in ISTA or something. Guess you could use the old one as long as you're okay with it possibly not working and having to take it back off to replace again.
      02-08-2024, 06:15 AM   #12
NoahFR
Good : Ticking disappear and acceleration is continuously
Not good : I have boost leak (He have power but not full)
      02-08-2024, 08:56 AM   #13
TheHaze
154
Drives: '18 M2
These are the joys of owning a modified car haha, at least you're making some progress. I would check all connections from air filter to throttle body. The FTP boost pipe (turbo to intercooler) wasn't a great fit with my CSF intercooler, could be something there. Good luck and report back!
      02-13-2024, 11:52 AM   #14
NoahFR
I check all but I see nothing. I took everything apart and put it back together I still can't reach the target boost pressure.
      02-13-2024, 01:24 PM   #15
TheHaze
154
Drives: '18 M2
That's a bummer. Have you tried pressure testing to check for leaks? Check out the link below:
https://f30.bimmerpost.com/forums/sh....php?t=1621695
      02-14-2024, 09:58 AM   #16
NoahFR
I make a leak test and I have a leak on the boost pipe.
I removed and replaced the hose clamp.
My boost is on my boost target and WGDC is at 60%. I wait many days for confirm it's ok
      02-14-2024, 10:21 AM   #17
TheHaze
154
Drives: '18 M2
Yeah, I'm not a big fan of the FTP boost pipe fitment. I almost wish I just kept the stock one. Glad you were able to find the leak! Did you make a test kit like the one in that thread I linked?
      02-14-2024, 01:26 PM   #18
ericlr1225
ericlr1225's Avatar
138
Drives: 2018 M2 LCI 6MT
Running this set pair with CSF since day one without issue but I agree with that the fitment is kinda PITA
      02-15-2024, 10:02 AM   #19
NoahFR
Yes I following tutorial, I used tire valves as caps for the hoses, size is perfect and for the air inlet I used a pot.
I also changed a seal at the intercooler inlet
      02-15-2024, 11:45 AM   #20
TheHaze
154
Drives: '18 M2
Very good. I may try doing this on mine sometime too just to make sure I have no leaks. Congrats and enjoy the car!
      03-30-2024, 06:22 AM   #21
NoahFR
Hello, I'm back ��
The problem persists, as it seems to be an electronic fault. I've replaced the diverter valve, but the issue remains. Interestingly, when I disconnect the valve, the boost leak disappears.
When Diverter valve is connected the boost leak only occurs after the engine has been running for 5 to 10 minutes.
Is it risky to drive with the diverter valve disconnected? I believe not, especially since I have a DV+. What are your thoughts?
Edit : when valve is disconnected I have this fault : 1D2404 - Thermostat cartographique, commande: Coupure de cāble. (Characteristic map thermostat, activation: Line disconnection.)
It's possible two reversed cables ??
I've conducted a pressure test, and it seems to be fine. Additionally, I've performed a smoke test, and that also appears to be fine.
      03-30-2024, 10:39 AM   #22
NoahFR
Problem solved, two connector is inversed, diverter valve with water thermostat.
the previous owner must have done strange things...
m2
