LOGIC7.. Finally, Optimal EQ Settings for E90, E92
05-14-2018, 09:32 AM | #331 | |
Rep 5
"Concert Hall" (or, on mine, "Music" haha) is better suited for wider stuff that should be less colored by the space it's in. That's what mine seems to do...take out some of the coloring of the car's interior, among other things. I find "Cinema" to center and almost box the sound in, as if you're in a movie theater. I don't have a DVD player in my car, but some E90 owners do indeed! Seeing as Logic 7 is the same DSP tech that's in some 7.1 home theater systems, with some of the same settings carried over, having a Theater setting makes sense. I'm probably wrong about 100% of this. |
04-26-2019, 09:20 AM | #333 |
Rep 2
First, I appreciate all the info provided in this thread. As a previous owner of 2 5 series and a 6 series, I must say I'm really enjoying this 335i.
Regarding the settings, I initially used an iPod with the cable and found the initial settings in this tread to work great. Since I moved to an iPhone XR, the connection shows my phone as "not supported". I worked with Apple and BMW but basically chalked it up to newer technology not supporting older technology. Since I decided to go with the Air Enabler, I chose these settings and I must say, they have brought my stock system alive. I"m an olderl guy and still love my music so I've got stuff from the 60's to today and a wide range of genre. I will say if you want to know if your system is really reproducing bass, even though you think you can't get enough, the song "The Embrace" from Al Dimeola's "Kiss My Axe" will give you the results you are looking for. If you are not familiar with the song, there are thunderous bass notes in the song that I believe to be kettle drums. Anyway, thanks again for loving the music and all the feedback that users like me were able to find on this website. |
yuyuyuyu67.50 |
04-26-2019, 09:25 AM | #334 | |
Rep 2
Air Enabler
These are the settings I was referring too!!
10-01-2019, 02:17 PM | #336 |
Rep 45
10-02-2019, 11:39 AM | #337 |
eBay Special
3120
Rep 3,042
Drives: E90 330xi
I'd use the E90 settings and adjust the fader to -4 or -5, and tweak the rest of the settings to your preference if that's even necessary
Common sense is a flower that does not bloom in everyone's garden
10-03-2019, 06:11 PM | #338 |
Rep 45
10-03-2019, 06:26 PM | #339 | |
eBay Special
3120
Rep 3,042
Drives: E90 330xi
10-03-2019, 07:36 PM | #340 |
Rep 45
It sounds like maybe you're saying that lower=rear. It's actually the opposite. Positive (higher) is more rearwards. So in that case I would agree with you 🙃
10-03-2019, 08:52 PM | #341 | |
eBay Special
3120
Rep 3,042
Drives: E90 330xi
10-30-2019, 12:43 PM | #342 |
72
Rep 381
What logic7 EQ settings would you recommend for E92 non i-drive, for ppl who like bass?
First post settings seems to be with bass only at high volume. Update: I decided to use these settings which gives a little bit more but still reasonable amount of bass (E92 NON I-DRIVE): 80hz 0 200hz 0 500hz +2 1khz +2 2khz -3 5khz -1 10khz +4 BASS +5 TREB +1 FADER +2 LOGIC7 = MUSIC So far I like it, suggest your settings. Last edited by Hotter; 11-06-2019 at 12:01 PM.. |
06-07-2020, 06:50 PM | #345 |
eBay Special
3120
Rep 3,042
Drives: E90 330xi
E91 drivers I'd start with the settings for the E90 and just keep tweaking it until you like it, everything's trial and error
11-05-2021, 04:31 AM | #348 | |
72
Rep 381
04-01-2022, 11:41 AM | #350 |
Rep 5
Drives: BMW 335i E93
jeez 10 years?
12-30-2023, 08:40 PM | #351 |
Rep 1
E92 Individual Audio 752 option EQ Settings with Spotify
Hey guys I know im about 14 years late here but if anyone has 752 packaged BMW 3 series speakers, here's the best EQ to have with Spotify HI-FI. Bless your ears guys!
i-Drive EQ: Spotify EQ: If the links don't work I attached the files below. |
