04-28-2023, 07:33 PM | #45 | |
995
Rep 668
Drives: 2023 X3 xDrive 30i
admranger2999.50 |
04-28-2023, 07:42 PM | #46 | |
Retired Curmudgeon
3000
Rep 4,075
I have a cold beverage waiting for you if you visit Vegas.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
mattsheng994.50 |
05-03-2023, 09:46 PM | #47 | |
Rep 12
05-04-2023, 12:22 PM | #48 | |
Retired Curmudgeon
3000
Rep 4,075
I'm heading out to run errands so I have also noticed the noise when backing up with full opposite lock on the steering. I'll do that a couple of times today and see. Regardless, the X3 drives much better now. More direct.
05-28-2023, 02:29 AM | #49 |
Rep 33
Drives: G02 3.0d Xdrive
@madshenriksen
Hi mate, I had the same issue on the previous G20 MY2020 and now present on the actual G02 MY2021 3.0d as well. Previously, the service replaced lots of parts on the suspension including the steering column till solved the issue with suspension arm replacement on G20. Link for the G20 noise, the same with G02 now. https://youtube.com/shorts/3sH6QtfeWoo Weird enough is that on my case it's always happening when I reverse to the right?! Perhaps due to my particular garage parking layout... Last week the service replaced on warranty the right suspension arm but the noise still there, awaiting spares for the left side now :/ It is disappointing since the car developed this at less than 13000 km though. I had to disengage the auto brake and perform lots of tests with dealer service , everything seems OK except of this noise. Thinking if one of the issues that leads into our problem is also the size of the wheels , mine 21" Individual forcing in exces our suspension in general ?! Now, I need to finish reading all the posts below to see if anyone gave a fix to this problem Cheers |
madshenriksen102.00 |
08-17-2023, 03:26 PM | #51 |
1197
Rep 997
Drives: 2023 X4 M40i (G02)
I usually have this crunching noise when reverse to either direction on my '23 X4 M40i, however, it doesn't happen every single time, so it's hard to intentionally replicate the noise. For instance, I heard it last night when I am backing up to my spot but today, there's no noise...
Do y'all think it's worth a dealer visit? Personally it didn't bother me too much since it only happen occasionally, but I am just wondering if there's any safety concern.
2004 Toyota Vios | 2004 BMW X3 | 2007 Chrysler Town and Country | 2007 Ford Escape | 2008 Honda CRV | 2017 Nissan Versa Note | 2017 Toyota RAV4 | 2017 Toyota Yaris iA | 2019 Porsche 911 | 2023 BMW X4 M40i
08-17-2023, 05:02 PM | #52 | |
1314
Rep 981
IAmSpeed1197.00 |
08-18-2023, 12:46 PM | #54 |
1314
Rep 981
That has been my philosophy as well. However- I have pondered whether or not it’s a “faulty” part, meaning perhaps it’ll wear out earlier than expected, that will somehow rear its head RIGHT AFTER my warranty expires… hence the thought “maybe I’ll try to get them to replace sooner than later”…. Just in case. But on a “bother me” scale, it’s basically non-existent for me.
ASAP10256.50 |
08-31-2023, 07:50 PM | #55 |
Retired Curmudgeon
3000
Rep 4,075
Mine was a bad thrust arm bushing. Those arms are not cheap. Have the dealer look at them under warranty.
09-03-2023, 01:59 PM | #56 |
995
Rep 668
BMW just revised the SIB and added new part numbers for the front tension strut. I don't know whether the new parts (31 10 8 854 993 and 31 10 8 854 994) are available yet, but they will probably supersede the old parts (31 10 8 854 989 and 31 10 8 854 990). Both the old and new parts are suitable for fixing the crunching noise issue though.
SIB 31 02 23 - Front axle noise when turning the steering wheel.pdf |
09-04-2023, 10:56 PM | #57 | |
145
Rep 491
That70sGADawg25.50 |
09-05-2023, 08:06 AM | #58 |
995
Rep 668
These bushings usually won't fail that early lol. I guess they torqued the bushing with the suspension fully extended so the bushing would fail prematurely...
09-06-2023, 06:41 AM | #59 |
145
Rep 491
09-06-2023, 01:03 PM | #60 |
Rep 50
My 2021 x3m40i is currently at the shop having the same issue fixed— mine started about 6 months ago with the “crunching” sound when backing out of the garage and turning the wheel near the limit in either direction… will be curious to see how things are when I get it back. As of now they claim they will have the parts within 24h but we shall see….
Definitely encourage others to get this issue looked into while still under warranty! |
10-02-2023, 06:12 AM | #61 | |
145
Rep 491
Hope this really fixes the issue once and for all. |
admranger2999.50 |
10-02-2023, 09:39 AM | #62 |
67
Rep 216
I have this EXACT noise on my G20 M340i. One direction only. I have searched far and wide for people with the same issue, but came up empty until now. Problem is both thrust arms have been replaced (and both tie rods, both upper strut mounts) and it's still there. Only thing left with a ball joint/bushing are the wishbones (i.e., lower control arms).
10-16-2023, 06:36 PM | #63 |
Rep 12
Well temps dropped into the 40’s last night and the noise is back. Only thing I haven’t replaced with bushings are away bar bushings and sway bar end links. One person mentioned it could be motor mounts, but I don’t think that’s what it is. I’m probably just going to live with the noise since I only hear it in the fall/winter months.
12-04-2023, 12:49 PM | #64 |
1197
Rep 997
I've been dealing with this issue in my 2023 X4 M40i since day 1, where I hear the crunching sound when backing up and turning the steering wheel to the right near the limit. Initially occasional, it has become more frequent, causing concern for safety. Despite multiple visits to BMW service centers, the problem persists.
On 7/12/2023 and 10/15/2023 at BMW Steven Creek, they couldn't reproduce the sounds. On 11/3/2023 at BMW Fremont, they claimed it's normal. Finally, on 11/18/2023 at BMW Mountain View, they acknowledged the issue but insisted it wouldn't be a warranty repair. Considering the safety aspect, should I continue trying different service centers or consider paying out of pocket for the replacements? Any advice on rewiring this situation would be greatly appreciated!
12-07-2023, 09:15 AM | #65 | |
67
Rep 216
12-07-2023, 03:19 PM | #66 | |
1197
Rep 997
Parts are backordered, I just took my car back as they said parts won't arrive anytime soon. They will call me when is ready to install, ETA 30 to 45 days.
