07-03-2023, 05:07 PM | #111 | |
100
Rep 150
Maybe oldbmwtech had a clear picture from memory. For now, I am just hoping the rear braces are where majority of the load sit, then I can think about the use of mesh. As a side note, I am surprised that the factory did away with the thin plastic cover found on the F series. I tried looking to see if such a piece was ever intended, but couldn't locate a current parts diagram. |
07-03-2023, 05:16 PM | #112 |
201
Rep 272
I would use rivets instead of a nut and bolt, then you wouldn't need to worry about clearance.
This is only my opinion as I'm a retired professional ASE master grease monkey technician, now instructor. Your best teacher is your last mistake. Use what I post at your own risk as you know teachers only know book knowledge.
07-03-2023, 05:24 PM | #113 | |
1828
Rep 1,966
I need around 3/16" clearance for the hardware I bought Can anyone educate me on how rivets are installed? Do they make them with a wide base to avoid needing a washer to grab onto the mesh? I need them around 1/4" long. I spent $30 on SS hardware that I may now return if I can make rivets work. |
07-03-2023, 07:35 PM | #114 | |
201
Rep 272
07-03-2023, 08:04 PM | #115 |
1828
Rep 1,966
07-04-2023, 09:20 AM | #116 |
332
Rep 265
Put the mesh on the bottom of the skid plate (road side) so the washers are on that side as well, you will have less clearance issues. Sure it's not as pretty but who's going to see it.
2023 M2
2014 Triumph Trophy |
07-04-2023, 01:44 PM | #118 |
291
Rep 195
Just spotted this online https://www.radiatorgrillstore.com/p...esh-protection
07-04-2023, 02:40 PM | #119 | |
1828
Rep 1,966
07-04-2023, 02:41 PM | #120 |
740
Rep 706
What about laying a narrow bead of jb weld along the screen perimeter? Solves the clearance issue.
It's some pretty awesome stuff. I once cracked a metal oil pan on an Audi. Didn't want to wait for shipping and it was mucho $$. Removed the pan, cleaned very good with degreaser and then burned any remaining oil in the pores away. JB weld fixed it until the car got totalled 4 years later. I was doubtful due to expansion/contraction of hot oil, but it never leaked/failed. |
MPR1828.00 |
07-04-2023, 02:45 PM | #121 | |
1828
Rep 1,966
07-06-2023, 04:23 PM | #122 |
1828
Rep 1,966
I reduced the space needed by a lot with the rivets idea, thanks again.
07-06-2023, 06:57 PM | #123 |
287
Rep 1,291
I have good news to share. Got the oil cooler replaced today and the engine seems to be OK! I'm so relieved! I appreciate everyone for your support during this ordeal. So excited to have my car back!
10
~Barn~109.50 MPR1828.00 Houdre7.50 apez678.50 liondog2.00 LivingInSalt1980.00 ZeusHorkios107.50 stvward134.50 Ravenseal2904.00 Jonesymx29217.50 |
07-06-2023, 07:05 PM | #124 |
Neophyte
110
Rep 54
Drives: 2023 BMW M240i xDrive
Garage List 2023 BMW M240i xDrive [10.00]
2007 Aprilia RSV 10 ... [0.00] 2013 MV Agusta F3 [0.00] 2007 Acura MDX [0.00] |
mblaucoupe135286.50 |
07-06-2023, 09:06 PM | #126 |
201
Rep 272
Wonderful news. I know you are relieved. Now get a skid plate and use mesh with rivets and your worries will be no more. Life is solved.
07-06-2023, 09:15 PM | #127 |
201
Rep 272
This looks great, might do this too. Thanks for posting pics and updating us. We get great ideas from everyone here. When I bought my skid plate I was told I was the third person that bought it. Not to brag, but I bet there will be updates to this skid plate. I wonder how much this plate reduces air flow and with the mesh. I track my car and wound like air flow as well as protection.
MPR1828.00 mblaucoupe135286.50 |
07-06-2023, 09:29 PM | #128 | |
1828
Rep 1,966
liondog2.00 mblaucoupe135286.50 |
07-07-2023, 08:57 AM | #129 |
287
Rep 1,291
I forgot to mention in my earlier post, I'm also going to send bmw of north America a letter about this oil cooler issue. I doubt it will do any good, but if there are others out there who have contacted them about this issue whether on the g42 or on other bimmers, perhaps it will help push them to consider adding a protective cover to these coolers in the future.
07-07-2023, 10:08 AM | #130 | |
1828
Rep 1,966
07-07-2023, 10:17 AM | #131 |
287
Rep 1,291
07-08-2023, 10:24 AM | #132 |
206
Rep 349
How about installing the steel mesh only? I think that should be enough protection. Going through the posts in this thread I think it is really irritating to have to consider spending hundreds of dollars on a brand new (and already pretty expensive) car to protect its power-train.
