      11-11-2021, 12:10 PM   #133
cukeuk
cukeuk's Avatar
142
Drives: Series 2 GC M235i xDrive
Originally Posted by judiobava View Post
Hello,
Is it possible to code the horn to sound when opening/closing the car?
Thanks
I am sure this is in my car settings within the idrive menu.
      01-05-2022, 08:05 AM   #134
fiche335
11
Drives: F40 135i
I started a new post, had loads of views but no responses.
Does anyone know if it's possible to code in the M-Display rev counter in the HUD of the F40? There seems to be success over on the G20 and G01 pages but little info here.
I have bimmercode installed which I used on my F80 but will need to get a new cable/dongle or should I move to Esys?
Thanks
      01-05-2022, 09:23 AM   #135
Simmo44
Drives: 1 series bmw 118i M Sport
Anyone coded the active air flaps to stay open?
Please share how
cheers
      01-23-2022, 02:04 PM   #136
Akzg
Drives: Bmw M135i
Please share how
cheers
Are you on about the exhaust valve? If so, you can code this to add sporty mode to engine sound in the menu. It will keep the valve open in comfort mode instead of sport only.
Sport mode in ASD
HU_MGU
- CAFD_00003E52
- DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND - Ausgelesen = enabled (was disabled)
- DISPLAY_CONFIGURABILITY_ENGINE_SOUND - Ausgelesen = aktiv (was nicht_aktiv)
      01-24-2022, 03:14 PM   #137
cukeuk
cukeuk's Avatar
142
I think he meant the front kidney grill active flaps...
      02-14-2022, 08:44 PM   #138
MugatuJag
17
Drives: 2022 BMW 228I XDrive GC
F44/F40 BimmerCode Angel Eye Brightness Coding
Hey everybody, the F44 forums are not as active as the F40 so I apologize that I’m posting here about my F44, but regardless I have a 2022 228 I XDr., full version of BimmerCode, and an enet cable. I have always coded my angel eye brightness on my previous BMWs and my mini coopers to 100% when the low beam is on, default is like 49%.
It is such a drastic difference and it really improves Visibility and looks badass, however under lighting in the body domain controller that option is absent. Does anyone know how I could go about this, is there a setting under expert mode perhaps? Thank you everyone I sincerely appreciate it👌💯🙏
      06-30-2022, 09:27 AM   #139
cjn
99
Drives: 2021 F40 M135iX
A small change that may remove a minor irritant for somebody. When you open the rear hatch it goes to a position that can be set to one of five heights in the MMI. I found that position 3 was just about OK, except that the door would be stopped by my extending ladder suspended on hooks above the car, and I had to wrap a towel around the ladder to protect the door. The real solution is to recode the height, using BimmerCode Expert or E-Sys.
In the HKFM ECU, section 2004, there are five settings HKL_MMI_POSITION1 to 5. These are assigned hexadecimal values representing the % of total motion, from x0D (13%) to x64 (100%). I reset my POSITION3 from x57 (87%) to x52 (82%) and the door now stops just short of the overhead ladder.
To avoid confusion, this is for my F40 M135i Xdrive with electrically operated tailgate.
      07-11-2022, 07:34 AM   #140
BeemerGimic
18
Drives: M5
Originally Posted by orusama View Post
Hi I need some help coding my F40. I searched around don't seem to find enough information on it so I 'm thinking to follow the G20 walkthroughs I found since both seem to have the same arcitecture. Any ideas?
Contact your local auto shop ,i did mine back in maine
      07-15-2022, 02:19 AM   #141
Bimmer5566
7
Drives: X5
Mine is also doing the same.
      07-20-2022, 10:14 AM   #142
DachiM4
41
Drives: M4GC
You need to get a compactible adapter to the obd
Mosset0.00
      12-08-2022, 04:51 AM   #143
dedons
Drives: f40
Hello, I codified the instrument panel of my f40 with bimmercode, I put the M series, but I don't know why the 3.0 csl writing appears to me. Has this happened to anyone else?
      12-08-2022, 05:52 AM   #144
Erebor
Erebor's Avatar
Switzerland
1150
Drives: M4 Competition (G82)
Isn't there a separate setting where you can choose what kind of logo is displayed?
2022 G82 M4 Competition xDrive in indiv. Sunset Orange
Incoming: 2023 F40 M135i xDrive in indiv. Tansanite Blue
      12-10-2022, 04:34 AM   #145
dedons
Drives: f40
yes, but whatever logo i set doesn't work
      12-10-2022, 04:43 AM   #146
dedons
Drives: f40
Originally Posted by MrFoxy View Post
This is my setup now mate
May I know the steps you did? I have set the same display as yours, but instead of the M logo I see 3.0 cls
      01-07-2023, 01:29 PM   #147
Sans_S1
Drives: Bmw F40
Hi guys!
Does anyone know how to coding F40 so that the button to turn off the lights works?? It is always activated automatically with engine start.
I refer to this video but with satisfactory result:
Thanks!
      01-07-2023, 04:00 PM   #148
cjn
99
Originally Posted by Sans_S1 View Post
Hi guys!
Thanks!
No idea what that video is all about, but you can try this:
BDC 3501
OFF_IN_PWF_ERFAHREN_ERLAUBT
nicht_aktiv ==> aktiv
Allow exterior lights to be turned off when engine is running
      01-08-2023, 10:16 AM   #149
Sans_S1
Drives: Bmw F40
BDC 3501
ok!
I'll try to find that way with BimmerCode in expert mode for bmw F40.
Thank you!
      01-08-2023, 11:56 AM   #150
cjn
99
ok!
Thank you!
This may save you a bit of time. I just noticed that BimmerCode basic mode has:
"Exterior lighting switch-off allowed"
(Allow the exterior lights to be turned off when the engine is running.)
It's probably the same as the expert mode I quoted.
I have never used this feature so I can't guarantee that it works.
      01-09-2023, 12:21 AM   #151
Erebor
Erebor's Avatar
Switzerland
1150
I have and this is exactly, what is asked for here. That works.
      01-09-2023, 02:19 AM   #152
Manboy
Manboy's Avatar
Sweden
448
Drives: 2020 M135i Misano Blue
Do the angel eyes come on or do the headlights go completely dark?
      01-09-2023, 05:10 AM   #153
Erebor
Erebor's Avatar
Switzerland
1150
On my G82, it only affects the headlights, the angel eyes stay on.
      01-09-2023, 09:24 AM   #154
Manboy
Manboy's Avatar
Sweden
448
I just tried it and it worked. Basically, now the "Off" button works as intended
