01-30-2019, 10:43 PM | #23 | ||
General
903
Rep 1,004
Drives: 2008 BMW 135i (E88 N54 6AT)
If you want to heat the air in your car, you'll want the heater on. It is entirely possible to have both the heater and air conditioner on at the same time, giving you warm, dry air in the car. It's often preferable to run the aircon & heater in winter so your breath doesn't fog up the windows, and so your wet boots can be dried while you're in the car - also drying your carpets and preventing them from going moldy. If you leave the BMW heater system on full auto and just dial up the temperature you want; you'll find it does all of this for you automatically. The air conditioner is powered by a pump attached to the engine, so it uses a little bit more fuel and takes a little bit of engine power away from the back wheels compared with when it's turned off. This was/is noticeable in cars with about 40kw of engine power, but you'll never notice the effect of it running all the time in your car. This also means you will have no air conditioning unless the engine is running (idling at least). Air is blown via an electric fan, which uses stuff-all power to operate; and will work even if your engine is turned off. Quote:
Use your heated seats when you first get in the car. They're heated by an electric element, and thus will provide instant warmth. |
shadowfax1289.00 |
02-03-2019, 04:45 PM | #24 |
General
17384
Rep 18,774
With the Auto climate control system, the A/C does not run at all times when the green light is illuminated. The green light just means the AC compressor is available when needed to condition the air (i.e. for the defrost function).
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
02-03-2019, 05:08 PM | #25 |
2896
Rep 3,480
I had the hardest time with this in my BMW because apart from the temperature select, there's also that temperature select on the vent itself, so when I was trying to get heat and it was cold outside, it would just send ice-cold air at me. Why the hell there's a secondary temperature select on the vent makes no sense to me, but it is what it is. The car wants to run the A/C all the time, most newer cars do, to keep from fogging. When i turn on a car in the winter though, I want heat as soon as possible....
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
Kyngofpop676.00 |
02-04-2019, 09:35 AM | #26 |
1339
Rep 1,603
02-04-2019, 04:01 PM | #28 |
1889
Rep 5,506
I turn it on if I need to defog my interior windows. Otherwise it is always off.
Driving manual transmission with the AC on takes getting used to. The AC draws power from the car and it changes your clutch engagement points. RPMs drop faster between gears with the AC on and there is noticeable throttle lag.
Auto Detailing Enthusiast!
02-04-2019, 04:22 PM | #29 | |
General
17384
Rep 18,774
shadowfax1289.00 |
02-04-2019, 05:51 PM | #30 |
247
Rep 466
08-04-2021, 12:59 PM | #32 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Cool and dry is the way to go. The drying factor is my favorite part, even in winter. When I lived in San Diego I would normally leave the air set at it's coolest with AC turned off. Anywhere where it's humid or snows, you will want to have AC most of the time.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
Almuliman507.50 |
08-04-2021, 01:37 PM | #33 |
452
Rep 252
Mine is set to A/C; Auto. Along with the lights, and windscreen wipers. That way my car knows when its raining/snowing and needs defogging/dehumidifying.
11-27-2021, 01:01 PM | #35 | |
sportscars only
3279
Rep 3,206
I know some spammer revived this thread, but anyway, I thought it was always good practice to make sure the A/C is off when switching the car on and moments before one switches it off? I use AUTO during warmer weather, don't use AUTO/A/C otherwise (unless it automatically switches on when I use the defrost).
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
lake_eleven37.50 |
11-27-2021, 02:44 PM | #36 |
6659
Rep 15,858
Got to ask. why? I see no technical (or user) benefit at all to switching on or off, separate to the engine start and stop.
11-27-2021, 03:15 PM | #37 |
sportscars only
3279
Rep 3,206
I think it's about alleviating stress on the engine when starting and something about clearing out the A/C sys before shutting the car off. I dunno if modern engines now address these issues so there's no need to worry about if the A/C's off or on but I still practice this since it doesn't bother me.
11-27-2021, 03:57 PM | #38 |
9731
Rep 6,092
I keep A/C on in order to prevent the windows from fogging. Will raise the temp to like 68 though.
Former
-2008 E90 328 black/brown -2012 Lexus IS250 black/black |
11-27-2021, 04:44 PM | #39 | |
2511
Rep 4,381
Low battery and A/C demands notwithstanding. |
11-30-2021, 11:16 AM | #41 | |
2091
Rep 3,007
Yes, you wan the A/C to run in the winter it will help remove condensation, e.g. windows fogging. |
12-01-2021, 12:10 AM | #43 | |
2896
Rep 3,480
