      11-07-2021, 04:32 PM   #1
Brooklyn M240i
Brooklyn M240i's Avatar
281
Drives: 2023 BMW M240i xDrive
2020 BMW X3 30i  [0.00]
2023 BMW M240i  [10.00]
Is this safe?
The guy in the video used a screwdriver to force the valve open. Will this break the pin?
      11-08-2021, 07:09 AM   #2
cukeuk
cukeuk's Avatar
142
Drives: Series 2 GC M235i xDrive
Jeez no, you only have to unplug it when the flap is open.
Series 2 GC M235I xDrive, Snapper Rocks, Pro, Tech and Drivers Assistant Packs, 19" 557M Wheels. DTUK Tuning Box.
      11-08-2021, 07:40 AM   #3
Brooklyn M240i
281
But my valve doesn't open… it only opens when I drive and at kick down. My friend and I verified bc he drove behind me… and it won't open when I'm parked. If I unplug it when it's closed, will it open when I drive or will it stay closed.
      11-09-2021, 07:04 AM   #4
cukeuk
cukeuk's Avatar
142
Yes I think it should do with your engine you just need to get the engine into it's correct parameters.
The trick is to catch it on a cold start. For the first few seconds the valve should be wide open for catalyst warm up. During that time you can jump under and unplug the valve while it's open.
      11-09-2021, 07:25 AM   #5
Brooklyn M240i
281
So many people have said that, but I've even set up my phone recording on a cold start and it stays closed. So you think if I unplug the pin while it is closed. And if I drive it will open and stay open.
      11-10-2021, 10:45 AM   #6
cukeuk
cukeuk's Avatar
142
I have seen video's clearly showing the valve opening, so we beg to differ...
      11-10-2021, 05:14 PM   #7
Brooklyn M240i
281
I have a video I took this morning proving I am right I don't know to attach it but if you have Instagram I can DM it to you.
      11-11-2021, 11:10 AM   #8
cukeuk
cukeuk's Avatar
142
I avoid Instagram like it had the plague thank you. As I have seen videos of the valve opening I don't need to see yours as it seems you must be doing it wrong somehow.
As stated, we'll beg to differ and leave it at that.
It still is wrong to brutalise it with a screwdriver thus I have answered the op correctly..
      11-11-2021, 12:49 PM   #9
Brooklyn M240i
281
I do not plan to use the screwdriver…. But you can let me know if this is wrong. Starting my car after it being in a garage over night and setting up my phone in-front of the exhaust with the light, then starting it up. And the exhaust valve not opening.
      11-12-2021, 02:56 AM   #10
cukeuk
cukeuk's Avatar
142
This has worked in the past with all BMW models. Have you tried sport mode?
      11-12-2021, 07:04 AM   #11
Brooklyn M240i
281
Yes I cold started the car by putting it in sport first. I know my valve open as I drive bc my friend has drove behind me. But it does not open when I am parked.
      11-12-2021, 11:44 AM   #12
cukeuk
cukeuk's Avatar
142
What do you think would be achieved with the valve permanently open anyway? Can you hear a difference when it is open, if you can then surely just unplug it then.
      11-12-2021, 06:24 PM   #13
Brooklyn M240i
281
If I unplug it when it's closed will it even open?
      11-14-2021, 09:58 AM   #14
cukeuk
cukeuk's Avatar
142
Yes it won't open at all...
      11-16-2021, 04:47 PM   #15
Silverlining_m2
Silverlining_m2's Avatar
1747
Drives: 2023 M2, 2024 m235i
I noticed on my wife's 228ix that you can go in idrivw to adjust the exhaust volume. Is it possible that it will be open if you select "loud"?
2023 M2. ZB. Manual.
2024 m235i
      11-16-2021, 09:33 PM   #16
Brooklyn M240i
281
Some 228i's including mine does not have that option… are you running i drive 6 or 7
      11-16-2021, 10:06 PM   #17
Silverlining_m2
1747
I assume it's 7? It's a 2022 with bmw live cockpit pro.
2024 m235i
      11-16-2021, 10:14 PM   #18
Brooklyn M240i
281
Ok… and I'm not sure some say the fake ending noise that comes through the speakers is not correlated with the valve it's self. We'll some say it is. Just i think that is you put it to loud in comfort it'll just make the Cabin louder but not actually effect the valve. It in sport it will open on kick down no matter what the Fake noise is set as.
      11-21-2021, 12:04 AM   #19
c00lbeans
Drives: X5 40e
Just code it open with Bimmercode
