      01-23-2020, 07:22 PM   #89
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Just wanted to say thanks for putting this DIY together. Coded my battery last week. Was able to register via INPA, and then I tried with Winkfp just for fun and it worked as well. Manually coded the battery type via NCSEXPERT.
I also tried via Rheingold, and kept getting a blank screen when I went to register the battery. Anyone have any ideas what I can do to fix it? I can do a complete vehicle test and clear my modules, but when I click on the ABL to register the battery I get this blank screen.
      01-23-2020, 08:19 PM   #90
Chief_Bimmer_Fan
Drives: 2015 BMW F34 328i GT
When you register the battery.
From the 3 series service manual:
Current Mileage is stored
Stored values from old battery (charge status, current, voltage, temperature, etc.) are deleted
Power management is initialized
if you don't:
"[...] the vehicle power management may not run properly and this can lead to function limitations for example: reduction or deactivation of individual consumer functions."
      02-09-2020, 11:17 PM   #91
Tabarnak
Drives: 550i SAL
What a thread..
Please someone, I can't figure out from Option5 >>Step 28.<< What do I do exactly? ...Thanks
27. Select: File>save as>FSW_PSW.MAN (be sure to select “save as type” to all files so that it will accept the “.MAN” extension. If you fail to do so it will just save it as a text file .TXT)
>>28. CLEAR THE FILE (CTRL + A > back*******
29. Select: File >Save
ThanxAgain for the share bud
      02-10-2020, 05:46 PM   #92
bbnks2
1213
Drives: 135i N55
Originally Posted by Tabarnak View Post
What a thread..
Uh I pretty clear instruction. Empty all file contents so it's blank.
      02-10-2020, 05:48 PM   #93
bbnks2
1213
Drives: 135i N55
You can register with inpa if tool32 is giving an issue.
      02-12-2020, 05:54 PM   #94
Tabarnak
Drives: 550i SAL
Thanks man. Sincerely!
I have a E60 2007, does NOT have CAS/FRM, it has CAS/LMA
I want to change -B110 to -B090 and then register the new battery.
Can I follow Option5 and select LMA instead of FRM,
and after I would register the battery with Tool32 a/p instructed in Option 3 ?
*I can confirm there is a -B110 value in both CAS and LMA.
MuchAppreciated -
      02-14-2020, 09:12 AM   #95
bbnks2
1213
Drives: 135i N55
MuchAppreciated -
Sorry I can't help much with that. Sounds correct, but, I only have first hand experience with doing this on E8x/E9x vehicles. The 5 and 7 series get a bunch of extra goodies.
      02-26-2020, 02:15 PM   #96
Tabarnak
Drives: 550i SAL
Thanx again for your invaluable input ..
In case this help a fellow DIY, I can confirm that I have followed the protocol from my last post and it worked flawlessly.
" I followed Option5 and selected LMA instead of FRM,
after, I've registered the battery with Tool32 a/p instructed in Option 3 "
Car charging a/p expected and battery registered properly.
bbnks21212.50
      11-04-2020, 04:11 PM   #97
live4speed
Drives: bmw f10
Hey guys, so i just replaced my battery from AGM 90ah to AGM 95ah. I registered it with bimmerlink, tried expermode in bimmercode to tell it its a 95ah but there was no option for that so i used 90Ah. The car feels different no more vibrations, everything is great EXCEPT the auto start-stop stopped working, and shows a "/" over the start-stop logo on the dashboard when its supposed to go off. Any ideas why?
The errors i got (not sure if they have anything to do with the battery)
Junction Box:
-002031 VSM_EVENT_VEHICLESTATE
-0020040 PDC: reset due to watchdog timeout
Central Gateway module:
-101008 non resolvable ambiguous routing- SG not in the SVT target value
-100104 HW weckgrund ZGW
100204 Message monitoring: no system context signal
Integrated chassis management:
-48276E Autosar- standardcore- non volatile memory- interdity
-482651 slip angle estimator inputs not valis SBS
-482656 slip angle estimator internal degradation due to SBS.
I would appreciate any advice
      07-16-2021, 05:19 PM   #98
raysbmw
Drives: 2006 525i
Post
Thanks for sharing this great resources.
I found that this can be done with other less complicated scan tools as well.
This guide on youcanic includes the instructions for various scanners.
https://www.youcanic.com/wiki/bmw-ba...ming-procedure
      07-16-2021, 05:53 PM   #99
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
That site only shows you how to register the battery. This diy shows you how to code your battery as well which is required if you change the specs.
      01-01-2022, 09:34 AM   #100
dlay35
Drives: BMW 335i
So instead of going through a huge step process like one of these or buying something overpriced, does anyone know if I can just reset the ECU instead? An ECU reset can be done pretty easily I've read and it is costless as well. Someone let me know
      04-09-2022, 02:24 AM   #101
bishopmarkjohnson
Drives: 2009 128i convertible
bNks334. Great post.
I just bought an 2009 e88, knowing it needed a new battery and the footwell (FRM) module replaced. I like to pay the dealer for things I can do myself, but I knew almost nothing about how to code/program a car. I found this guy's video on how to download the standard tools invaluable.
And your post walked me right through how to change the battery from a regular wet cell to an AGM. (No a lot of batteries to choose from on the Big Island.)
I've got the footwell module and am about ready to put it in. But thought I'd see if you have any advice or insight before I start in on that project.
This video is the best I've found on how to do the coding.
But it does not inspire quite the confidence your DIY does. Any thoughts on how to do it or on whether this video has it right?
Thanks much.
      05-23-2022, 08:07 PM   #102
Mandinca
121
Drives: 2008 E88 and 2016 F85
Hi all,
Wondering if anyone can help. My E88 2008 forgets the time and trip mileage all the time and the guys at Autozone tested the battery and said its fine. Also, the battery has the spot on top and it's black so it looks ok. I read somewhere that disconnecting the blue IBS cable from the battery cover might help and sure enough the car has stopped forgetting the time and trip miles. Question is.....what do I do now. Is it the IBS that's toast or is it possible that the battery that's in the car wasn't coded properly or even at all ? How can I tell ? I just downloaded INPA but haven't tried connecting it yet - a little nervous if I'm honest. I also have protools on my phone but only the coding license, not the diagnostics license. So, does anyone think it's likely that if I code the battery as if its a new one and reconnect the IBS my issues will be resolved or is it more likely that I have to replace the IBS and if I do how much more will I need to do as far as coding etc is concerned. Hope someone can help. Thanks in advance.
2008 E88 N54 135i / Cashmere Silver / Beige leather / VRSF catless DP's / BMW Performance Suspension / Whiteline inserts / Aluminum charge pipe and aftermarket BOV
      10-22-2022, 11:15 AM   #103
The-Traveler
139
Drives: E92 M3 & G30 530e
You guys might find this software bug interesting.
Heads up. Just because you code 60_agm doesn't mean CAS will accept it.
      07-16-2023, 05:43 PM   #104
FoxKhan
Drives: BMW E91 320D (M47)
Does a conventional 85AH need coding or just registering?
Hi,
Thank you very much for this thread!
I need to replace an original BMW 80AH, 640A (61217604816) on my old BMW E91 M47 320D. If I buy an 85AH 800A battery (Varta for example), do I need to code it or just register it?
What if I buy a 80AH EFB, would that need coding? (And would it be worth it to buy one instead?)
Tags
agm, battery, code, register, replacement
1addicts
