M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      05-04-2017, 05:17 PM   #23
SapphireM5
SapphireM5's Avatar
711
Drives: 2013 M5 Sapphire Black
Any help with install you can share I would greatly appreciate. I want these so bad, worried about the coding etc, how did you make out with that? Thanks Bud!
      05-04-2017, 11:19 PM   #24
epiphanyray
124
Drives: 2003 E39 M5 + 2013 F10 M5
Originally Posted by naiza3k View Post
Originally Posted by epiphanyray View Post
Nope. I have not.
Did you get yours through Umnitza?
I believe there is a video on youtube on how to get these on. Essentially you have to remove front bumper, and remove headlights. Open them up and pull out the "board". Its the electronic computer board. Then insert into umnitza lights and plug them in. Harness is plug and play.
Connect both lights and then turn on car. Test them out. Then you need to code a couple things out. (Cornering faults and something else like active headlights)
Pretty much it.
      05-05-2017, 06:18 PM   #25
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Hi guys.
I need to code these two lines.
LWR_AHL_TYP = ohne (removes adaptive feature)
FLC_AKTIV - to nicht aktiv (fixes cornering fault)
I have DCAN Cable, and NCS Expert (used it on my e60). Have never touched my f10 m5 with any software. Is it true I can use NCS Expert to do this? How do I know if the version OF NCS expert will work.
BMW Chassis Codes
Complete Software & Interface Overview
For your F010, you will need the following:
  • ENET (OBDII to RJ45)
  • E-sys
  • E-sys Launcher
  • Psdzdata
If you still need software or assistance, let me know.
      05-05-2017, 07:23 PM   #26
epiphanyray
124
Originally Posted by Almaretto View Post
BMW Chassis Codes
  • E-sys
  • E-sys Launcher
  • Psdzdata
Thanks! But I already got everything coded out.
      05-05-2017, 10:58 PM   #27
Almaretto
Almaretto's Avatar
2376
      05-05-2018, 09:28 AM   #28
Johnnym123
Drives: F10
Hey i Need Jep please
I install my halogen version lights into led headlights but I need coding it with esys
Can someone help me which coding information I need ?
They flicker on both sites if I’m start the engine
Thanks
      05-05-2018, 10:45 PM   #29
epiphanyray
124
They flicker on both sites if I'm start the engine
Thanks
Contact adrian at s f bmw coding Maybe he can help
A.dot236.00
      05-06-2018, 06:25 AM   #30
Johnnym123
Drives: F10
Ok thanks
      05-08-2018, 11:45 PM   #31
Almaretto
Almaretto's Avatar
2376
Thanks
I am curious. Why did you switch to halogen lights?
Which bulbs did you switch? There is separate coding for each component. Most change in the opposite direction, but you will need to modify so correct voltage is supplied.
      04-06-2019, 09:29 AM   #32
boomerang.e92
boomerang.e92's Avatar
369
Drives: E92 M3
Have you had success fixing the cornering issue?
      04-18-2019, 12:59 PM   #33
naiza3k
176
Drives: 2013 M5 6spd | 2023 m8cgc
I will be tackling this and install the Headlights this weekend.
Will be coding out the codes as well.
Question: I have my car flash tuned with OFT. Will the coding be erased everytime I flash the car?
BMW Chassis Codes
  • E-sys
  • E-sys Launcher
  • Psdzdata
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill |
Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive
      04-18-2019, 01:00 PM   #34
naiza3k
176
Did you code yourself yourself of you had Adrian do it?
      05-20-2021, 03:06 AM   #35
treble20
Drives: F10 5 series
BMW Chassis Codes
  • E-sys
  • E-sys Launcher
  • Psdzdata
Hi,
Could you confirm where LWR_AHL_TYP is found please? Need to code out the Headlight vertical control arm failure after replacing the TMS module in a pre-LCI F10. I've successfully coded out the Adaptive Headlight Failure warning but not having any luck with the vertical arm as I can't locate it. This is what's showing in the FRM:
Thanks
      05-20-2021, 01:17 PM   #36
Almaretto
Almaretto's Avatar
2376
Originally Posted by treble20 View Post
Hi,
Thanks
Have you tried searching?
FDLs can move around in CAF so best to search for it.
m5post
