BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55: Spun hub, YAY
Extreme Powerhouse
      04-24-2021, 03:42 PM   #1
madrrio
Capable
madrrio's Avatar
Drives: 335i m sport
N55: Spun hub, YAY
Hello all,
I thought this was only a S55 issue, but after my car made a PFFF after getting on it, (luckily no metal rattling or oil everywhere) I was rewarded with alot of codes and the car turning off.
Used an endoscope and it appears i have the smallest amount of valve to piston contact. Pictures coming.
I am asking for recommendations on fixing this. I started by rotating the crank at the hub to see if it was seized completely or still rotated (which is when i was able to spin the crank bolt a few times before the engine started to turn over).
the engine rotated and the pistons look fine which gives me a little hope that perhaps a valve or two is bent and the fix is not as bad as it could be.
Here is my current issue. I need to time the car again to check for compression but i have a singlemass spec flywheel. I just purchased the tool for aligning cams and vanos, and the pins to hold the crank in place but not sure if this flywheel is going to have the timing holes I need. My question is: could i time this any other way or am i going to need to drop the transmission and put on an OE flywheel?
For checking compression i think i can ball park it, but ultimately would i think im going to need to find a DMFW since i threw mine away a few years back not thinking this would be an issue. I have a new DKM dual disc organic, but do not think those have timing marks either.
Here are the codes i recieved:
165011
165012
165013
165014
130f11
130e11
120408
164021
164031
      04-24-2021, 03:47 PM   #2
madrrio
Capable
madrrio's Avatar
https://drive.google.com/drive/folde...p4N6dxdmKA4Yzv
here's a few photos of the pistons where you can see valve contact, and the codes I was rewarded with.
      04-24-2021, 04:41 PM   #3
Munchi435i
Munchi435i's Avatar
486
Drives: 2014 Alpine White 435i M-sport
Originally Posted by madrrio View Post
Hello all,
165011
165012
165013
165014
130f11
130e11
120408
164021
164031
What year and mileage on the car?
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
      04-24-2021, 05:17 PM   #4
madrrio
Capable
madrrio's Avatar
2013, 75k.
N55 running ps2, e85 (w port injection kit), full bolt ons and tuned.
Think one of the extra injectors started getting leaky, as I was having wot issues wheree the car would sputter or break up. I been trying to diagnose w data logs n switching things out (spark plugs, coils, I jectors was next).
I ran the car after swapping the coils n though I had fixed the issue but then did a 4th gear pull down a hill to reduce load and the issue arrised.
      04-25-2021, 10:37 AM   #5
Boostedphil698
Boostedphil698's Avatar
453
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
I've never heard of this happening on the N55.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      04-25-2021, 01:31 PM   #6
madrrio
Capable
madrrio's Avatar
I've only read it one or two places as well, but I went to turn the motor and that bolt was loose.
If anyone in SD has a old dual mass I could use for a bit to time this thing 😂.
      04-25-2021, 02:01 PM   #7
F32Fleet
F32Fleet's Avatar
3637
Drives: 2015 435i
Ya, it's essentially unheard of at stock power levels.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      04-26-2021, 12:31 AM   #8
madrrio
Capable
madrrio's Avatar
"stock power levels"
Full ethanol ps2 is considered stock power levels right? ;p
F32Fleet3636.50
      04-27-2021, 07:03 PM   #9
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Happened to mines miss shift 2k15 335xdrive 6 speed . Spun crank bent valves, then spun bearings since oil pump stopped spinning. Bolt was also loose.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      04-27-2021, 07:57 PM   #10
madrrio
Capable
madrrio's Avatar
Sorry to hear that, there was no misshift on this one, happen during a 3rd or 4th gear pull around 4000.
      04-28-2021, 05:34 PM   #11
-Eidos
@lbb_kev
496
Drives: 2018 BMW M2 (LBB)
https://www.e90post.com/forums/showt...5#post20646755
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
F32Fleet3636.50
      04-29-2021, 01:42 AM   #12
harkes
harkes's Avatar
China
1092
Drives: M135i, E39 M5, NSX and AE86
Auch PWG? If you are and not running JB4 then I am very interested in seeing some of your logs
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      04-29-2021, 03:01 AM   #13
madrrio
Capable
madrrio's Avatar
https://www.bootmod3.net/log?id=6080f944d10b433b994b0f58
      05-02-2021, 02:41 AM   #14
harkes
harkes's Avatar
China
1092
Who did the tuning?
(A Dane in China)
      05-03-2021, 10:46 AM   #15
madrrio
Capable
madrrio's Avatar
Who did the tuning?
Cary, the car has always ran perfectly fine for the past 2 years or so. i think the recent issues i was facing originated form a leaking injector on the PI rail. I had ordered a new set, but after swapping in the OE coils i thought i had fixed it as it was pulling like it use to.
      05-05-2021, 01:35 AM   #16
harkes
harkes's Avatar
China
1092
Who did the tuning?
Do you know why target is flat and it is under boosting up top?
(A Dane in China)
      05-07-2021, 11:49 AM   #17
madrrio
Capable
madrrio's Avatar
i wasnt all the way down on pedal, i just flashed the map, and likely hadn't adapted yet.
plus up top the boost drops off a little.
      12-01-2021, 12:58 AM   #18
madrrio
Capable
madrrio's Avatar
So an update. Been forever but got the motor and started taking things apart. One connecting rod has a super small bend. Finally got the crank out and it looks like the thrust bearing failed. See photos... It ate right into the damn crank.
I doubt they cN weld and machine where the material is missing, so I'll probably be looking for a replacement. Getting a motor swapped directly might be a better option and then I'll sell my ps2 and all the bells and whistles.
      12-01-2021, 01:00 AM   #19
madrrio
Capable
madrrio's Avatar
I ran a spec stage 3+ clutch, idk if that played a roll into why this happened (or why my 2nd gear synchro gave me a middle finger) but it is what it is.
