06-02-2020, 06:58 AM | #1 |
300
Rep 543
where to put jack stands?
So I've versed myself in the jacking points, but where exactly do I put the stands once I have it jacked up? I thought about the side points, but with the (possibly) awkward way the stands would mate up to them (load being on part of the side of that piece, not the center), I was afraid they'd break. Do people have stands where the curved top is small enough to fit inside that piece?
06-02-2020, 09:42 AM | #2 |
74
Rep 122
I personally wouldn't put the jack stands anywhere other than the lift points. I believe the official manual states only the lift points and the front subframe plate can be used to lift the car. Many people report using the rear differential cover without issues, but I'm hesitant to do that. I ended up getting a QuickJack lift for the house and it's been great, but it is also super expensive.
Here is what I recommend or would do if I could go back: https://safejacks.com/collections/rennstand It basically is a jack pad that you convert to a jack stand after lifting the car up first. You attach the stand arms for raising, then remove them for lowering. |
TinCanSailor645.50 |
06-02-2020, 09:50 AM | #3 |
74
Rep 122
Just realized I didn't really answer your question. Sorry.
I'm not aware of any jack stands that will fit inside the BMW lift point, but the Safe Jack I mentioned earlier has a pad adapter for BMW, Mercedes, etc. I think that in combination with the Safe Jack would work. |
06-02-2020, 12:51 PM | #4 |
300
Rep 543
Thanks, but ~$290 for a pair w/the pads? oof. I wonder if the pad alone would be usable with a regular stand. Probably too wide. Maybe I need to just hit up a friend with access to a lift, lol.
edit: actually, those Rennstand pads are 2.5", which would fit just right into my stand. I'd have to cut off the base tube that goes into the Rennstand though, hmm. I do already have a regular jack pad, but annoyingly it's 2.75" wide, which won't work. I wonder if the powerflex branded one or one of the others would be 2.5" Last edited by vafan13; 06-02-2020 at 01:48 PM.. |
06-02-2020, 09:41 PM | #5 | |
74
Rep 122
I saw the Rennlist stands after and thought it was a pretty innovative ideas, if it can clear your car. They seem popular with the Porsche guys. |
06-03-2020, 07:14 AM | #6 | |
300
Rep 543
06-05-2020, 08:35 AM | #7 |
300
Rep 543
I read in an e9x DIY thread that someone put hockey pucks in the jacking points and that worked like a charm with jack stands. who would have thought!
06-16-2020, 12:44 PM | #8 |
King of NYC
118
Rep 177
Some interesting ideas on these threads:
https://www.bimmerforums.com/forum/s...tand-placement https://www.e90post.com/forums/showthread.php?t=727131
2014 BMW M5 Competition
MCB on Silverstone |
06-16-2020, 03:55 PM | #9 | |
300
Rep 543
06-17-2020, 02:24 AM | #10 |
King of NYC
118
Rep 177
I see. So basically something like this.
I'm considering this as well. Maybe even considering keeping them permanently epoxied in there. I have side skirts to help hide them a bit. This is a good idea whenever you have a flat or have to go to a tire shop. Those guys rarely have a jack pad. And even if they do, they're too lazy to use them unless you push them to. I always keep a jack pad, wheel hangers and torque wrench in the trunk. They're usually looking for the quickest way to get things done so it's on to the next one. Most of them think the plastic shrouds at the jacking points are rubber and can support the weight of they car. If they crush them they can care less, it's under your car and they will assume you'll never notice. Only the dealer jacks up the car correctly without you having to tell them. So addressing this jack point issue is good thing for everyone to consider.
06-17-2020, 07:37 AM | #11 |
300
Rep 543
That looks to be more of an adapter for a jack/life (although it might work), whereas I'm talking about an adapter for a jack stand. Basically you just hacksaw part of the puck off, put that end up into the jack pad and the remaining curved portion is what rests in the U-shaped top of the jack stand.
Creating what's in the video is a bit more involved, but if one has spare pucks lying around and the tools, certainly cheaper than $20 a pop for ones off FCPeuro or whatever. Last edited by vafan13; 06-17-2020 at 07:50 AM.. |
06-17-2020, 11:57 AM | #12 |
King of NYC
118
Rep 177
Oh ok. I see what you're saying.
I just found a guy who did the exact idea I was thinking about. I'd probably use anodized aluminum ones instead just to prevent deformity issues. Just more ideas for everyone out there.
06-17-2020, 01:47 PM | #13 | |
300
Rep 543
Also: one of the related videos gave me a good idea for how to get the jack under the front bumper: get the front wheels up on 2x4s. my current one might still be too tall, but a low-pro would then fit. |
06-17-2020, 02:21 PM | #14 |
King of NYC
118
Rep 177
Yup, wood is always a quick easy way to buy you a couple inches. Any of us who have had a lowered car in the past know all the tricks. Haha.
