Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Show me your painted calipers!
      07-05-2019, 04:51 PM   #1
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2682
Drives: 11' 335is DCT
I originally put my rears black didn't have time to do front. I'm having seconds thoughts on a different color though. Show me yours!
      07-09-2019, 10:26 AM   #2
Volasko
Volasko's Avatar
714
Drives: 06 330i E90, 18 530xe G30
I went with sapphire blue and had a local shop poweder coat them. Rebuild them with new seals and copper slide bushings. See below for all my pics. The spring clip looked a different colour, but it was due to the different material (I thought it was a mistake).
https://drive.google.com/drive/folde...xa?usp=sharing
      07-09-2019, 10:35 AM   #3
mweisdorfer
mweisdorfer's Avatar
1909
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I want to powder coat them in BMW Blue. I'm just a little skittish about the piston seal and getting it back on correctly.
Can't find a good/great DIY on how to do that.
Been down the G2 paint road. Great Stuff, but expensive and doesn't really last in a "salt" state. Paint holds up well, but nicks a lot and then salt creeps in.
      07-09-2019, 10:59 AM   #4
Volasko
Volasko's Avatar
714
The piston seal is the easy part, screwing around with the dust boot can be a total PITA if they don't properly tape off the surrounding lip it uses to hold itself in place. Before I did the powder coat route I did what you mentioned with some high temp caliper paint. Even went as far as getting them sand blasted. Even after a couple a coats of the high temp paint & clear, they still would nick up and start localized rusting. The PC was expensive but god damn does it ever hold up!
      07-09-2019, 11:00 AM   #5
mweisdorfer
1909
2008 bmw x5  [0.00]
That's what I meant the dust boot 🙈
      07-09-2019, 11:03 AM   #6
mweisdorfer
1909
2008 bmw x5  [0.00]
Let's just say, the lip is taped off. How difficult is the dust boot to get back on? Is there a special tool used or one could make?
      07-09-2019, 01:19 PM   #7
Volasko
Volasko's Avatar
714
Only real specialized tool is a compressor with an air blower tool with a tapered tip to remove the piston. Just shove the tip into the brake line hole after you remove it to push out the piston. I did use a flat head screw driver to push the dust seal into place around the areas I could not access with my fingers, but I would hardly call that a specialized tool.
      07-09-2019, 03:10 PM   #8
mweisdorfer
1909
2008 bmw x5  [0.00]
Hmm. I wonder if a thin piece of pvc pipe would fit in there and you could press the dust boot on using a brake caliper piston press on tool. The diameter of the pipe would have to really close to spot on though, in order for it to push the metal ring inside the dust boot over the lip.
      07-10-2019, 02:24 AM   #9
mikee5
Drives: 2007 e90 325
View post on imgur.com
Mike
6ixSpd6034.50
      07-10-2019, 07:18 AM   #10
Volasko
Volasko's Avatar
714
Super clean. What type of rotors are those ^^^?
      07-10-2019, 07:25 AM   #11
TheMidnightNarwhal
2682
I ended up doing mine black. Yellow may have turned out well.
Really wanted to do the M vinyl thing but would've been MRice IMO on stock brakes and no factory M option.
      07-10-2019, 11:16 AM   #12
Bavarian Tech
Bavarian Tech's Avatar
269
Drives: 335i
2006 330i  [10.00]
Blue M-Sport Brembo's
Volasko714.00
      07-10-2019, 11:42 AM   #13
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
Drives: '16 M3, '23 718 Spyder
That looks awesome. I've been too lazy to powdercoat and install my 335i front brake kit. Who did the work?
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      07-10-2019, 11:52 AM   #14
Volasko
Volasko's Avatar
714
Kingsman Kustoms, which really just sub it out to a specialist. The work was well done though, so even though they were $$ I'm happy with the finished product.
      07-10-2019, 11:56 AM   #15
TheMidnightNarwhal
2682
Hey I didn't know lifts like this existed. Wouldn't this be a better option for normal height sized home garage?
      07-10-2019, 12:30 PM   #16
Volasko
Volasko's Avatar
714
The entire length of the piston has to be installed below ground, I couldn't see this being added to a typical home garage without a crap ton of effort to make work.
      07-10-2019, 01:00 PM   #17
TheMidnightNarwhal
2682
Yeah I realised that after but still imagine in a new home construction with no garage yet. Imagine if like under the conrete it's all enclosed inside the box. Couldn't you plop in the box then pour around.
But yeah I guess it's not to practical to install if concrete is already there.... but man that lifts looks sick doesn't have posts in the way.
