BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications M550 exhaust flaps open = much better sound
      04-28-2019, 01:07 PM   #45
BardG
213
Drives: 2019 M550xi
Originally Posted by ksoze View Post
Originally Posted by BardG View Post
Thank you. Two questions:
1. How do I know if the flaps are fully open? (Just by the sound?)
2. Should I do this on a fully cold start?
1 . After the cold catalytic warm up on start up, see if the exhaust is coming from both sides. The sound will literally and figuratively be twice as loud when driving or under throttle, IN ANY DRIVING MODE.
2. The car has to be put in Sport Mode, then while still running, get out of the car and pull the fuse.
I'll try it again, thank you.
By the way: the car is warm right now, in Comfort Mode, I can feel exhaust coming out of both sides, would this suggest the flaps are open?
      04-28-2019, 01:11 PM   #46
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Sounds like it. Try driving with windows open and give it throttle in Comfort and then Sport mode. Both flaps open is not going to be like open pipes, but it is clearly more rumble and sound.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
      04-28-2019, 01:14 PM   #47
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Just noticed something, are you driving an G30 M550iX? If not, this fuse thing won't work.
      04-28-2019, 01:44 PM   #48
BardG
213
Drives: 2019 M550xi
Yes, I'm driving a 2019 G30 M550. I'll drop the windows and give is good listen. Thanks
      04-28-2019, 02:32 PM   #49
NCMMichael
29
Drives: 2019 BMW 540i
I'm driving a G30 540i with the M-performance exhaust. Are you sure the fuse pull will NOT work for the 540i? I'd love to find a similar solution.
      04-28-2019, 05:24 PM   #50
Nickguyver
Baby Driver
Drives: 2018 M550i
If you take a flashlight and look up the exhaust pipe, you can see if the valve is open or closed. If you pulled the fuse with the car in sport mode and it worked, the valves will be open with the engine off.
      05-01-2019, 06:01 AM   #51
Morteng70
20
Drives: M5 E60/M6 GC/M550i/M850/M3 Com
Hi all!
Couldnt all this be solved by just buy an Exhaust Meister KIT..?
I did this on my M6 GC and it worked perfect, open/close asyou wish..
When I put on my Eisenmann Race mufflers with valves it worked perfectly also on this....
Considering trading in/selling the M6 and going with the M550, I will then just take the Exhaust Meister off the M6 and use it on the M550...as long as your car has a vacum system this would work with the OEM exhaust and aftermarked exhaust with valves.
      05-01-2019, 07:42 AM   #52
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Originally Posted by Morteng70 View Post
Hi all!
Yes, but taking 60 seconds and pulling a single fuse is cheaper and faster.
      05-01-2019, 07:54 AM   #53
AddyDaddy
AddyDaddy's Avatar
567
Drives: i5 M60, M5's, 535.335, M550i
Get bimmer link/bimmercode
I coded my flaps open lastnight for all modes. Was going to turn ASD off but I actually like it when in sport mode
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
      05-01-2019, 09:29 AM   #54
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Are you driving a G30 5 series and coded the flaps open? The ability to control flaps does not appear to show up as an option for the G30.
      05-01-2019, 09:45 AM   #55
AddyDaddy
AddyDaddy's Avatar
567
Yes, I sat behind the car and opened them up and closed with the app. Opens passenger side first then driver within 5 seconds
I can send screen shot later
2018 750M ,
      05-01-2019, 10:04 AM   #56
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Do you have a beta version of the app? That capability does not appear on options for the G30.
https://www.bimmercode.app/cars/g30/
      05-01-2019, 10:16 AM   #57
AddyDaddy
AddyDaddy's Avatar
567
This is the one I have on my iPhone.
2018 750M ,
clee1982799.00
      05-01-2019, 10:24 AM   #58
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Me too, but no flap control for a G30 (M550iX) visible. If you go to setting/cars, and click on G30, which option has the flaps control?
      05-01-2019, 12:05 PM   #59
AddyDaddy
AddyDaddy's Avatar
567
I'll do it tonight and send screen shots
2018 750M ,
      05-01-2019, 03:03 PM   #60
AddyDaddy
AddyDaddy's Avatar
567
This is it
2018 750M ,
      05-01-2019, 06:38 PM   #61
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
The app you showed earlier is BimmerCode, which I have and does not control the flaps. This latest one you just posted is BimmerLink, a different app.
Does the BimmerLink app let you make the flap changes on the fly, without the OBD adapter in place?
      05-02-2019, 04:06 AM   #62
Morteng70
20
But then its open all the time, right...?
      05-02-2019, 06:22 AM   #63
ksoze
ksoze's Avatar
376
Drives: 2018 M550iX
Correct.
      05-02-2019, 08:38 AM   #64
AddyDaddy
AddyDaddy's Avatar
567
I just set them open
I leave the adapter in as it doesn't use much or any of battery. But they stay open even when it's not connected I'm pretty sure
2018 750M ,
      05-02-2019, 11:33 AM   #65
modthispny
206
Drives: 2022 540i M sport
so this is an awesome "mod" with a non-modified exhaust, but I had my resonators removed (will post clips) and in comfort mode the car was too noisy for my liking, plus the cold starts were WAY too loud. Put the fuse back in, in comfort the car is quiet and in sport all hell breaks loose.
      05-12-2019, 01:38 AM   #66
bioman
175
Drives: E30
Is it possible to just unplug the electronic flap connector?
In my old F30, turn the car on -> put into sport + -> turn car off.
Flaps are still open, then go to underside and pull out the plug on the valve and ziptie.
5post
