04-29-2018, 07:11 AM | #1 |
727
Rep 1,760
Oil temperature gauge on 16-17?
So I am not sure if I got this right or not, but I've read there is no oil temp gauge on the 16-17 M2. I was surprised because there is a digital one on my '18. Was this a part of the LCI? Does the 16-17 at least get a coolant temp gauge? (We don't in the '18)
2016 428ix, r, 2018 430iC, 2018 330it
04-29-2018, 07:57 AM | #4 |
727
Rep 1,760
Thanks for setting me straight there. I wish we had a physical colored representation of the red line on the tach though.
04-29-2018, 03:25 PM | #5 |
33
Rep 47
04-29-2018, 03:36 PM | #6 |
10949
Rep 4,554
Drives: 2015 328d xDrive
The pre-LCI gauge is a combination of Oil and Coolant Temps with no numbers displayed. It will just say "Cold" or "Okay" and the little bar will move left to right.
The LCI gauge is oil temp only. It has oil temp numbers displayed but no coolant temp display. Hope that clears things up. |
04-29-2018, 08:00 PM | #7 | |
5873
Rep 6,638
I never seen the blue and red bar "needle" go beyond the middle in street driving. I'm under the impression with those with after market temp gauge that by the time the needle is in the middle the oil is up to a high enough temperature you can start giving it some higher revs. you can use an aftermarket gauge or use a phone app and OBD reader like torque to see oil temp. Why BMW didn't show oil temp I don't know... probably just didn't wanted to make the base 2 series not desirable as a driver car and felt no point in updating m2 dash when the LCI was coming soon enough. |
04-29-2018, 08:17 PM | #8 |
10949
Rep 4,554
04-30-2018, 01:13 AM | #10 |
33
Rep 47
You'd presume BMW think it's OK to start using an extended rev range but it's not clear. Safest way is to stick to the centre position as that is fully warmed up. It also mentions in the book that if you have a DCT car and want to use launch control, to drive for about 6 miles. In my experience this is a similar distance (unless stood in traffic) that it takes to warm up fully ( so they're referring to it warming up fully again).
AndrewC198910949.00 |
04-30-2018, 01:17 AM | #11 | |
487
Rep 2,197
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
04-30-2018, 08:43 AM | #12 |
The deuce gets loose
290
Rep 499
04-30-2018, 11:05 AM | #13 |
10949
Rep 4,554
120C/250F would be ideal if you plan on redlining it because you want the car to be fully warmed up to minimize risk of premature wear/damage.
If you wanted to, you could probably start being a bit more aggressive around 100C/220F but I wouldn't go crazy. You should let the car warm up for 10-15min and go nice and easy before doing any spirited driving. Cold engines do not like high revs. |
Who?486.50 |
04-30-2018, 12:06 PM | #14 | |
5873
Rep 6,638
04-30-2018, 07:49 PM | #15 |
197
Rep 430
Drives: 2017 M2 LBB 6MT; 2012 328i 6MT
I was experimenting with this briefly today.
The temperatures were in Centigrade. Anyone know how to display them in Fahrenheit? BMW M2 pre LCI built in Oil temp in hidden diagnostic menu https://www.youtube.com/watch?v=rsNOublzEKM UPDATE: The video above is no longer available. https://www.youtube.com/watch?v=GYSJIsrq-ho The code you enter is the sum of the last 5 digits of the VIN Dedicated gauge: http://www.p3cars.com/bmw/bmw-1-seri...2-multi-gauge/ Last edited by RAM_F30_F87; 03-10-2019 at 02:46 PM.. |
Fabreezy13.50 |
03-10-2019, 11:53 AM | #16 | |
88
Rep 93
You’re the best! I was wondering why the BMW product manual shows a colour gauge but my LCI gauge is white. Thanks! |
03-11-2019, 04:15 PM | #17 | |
193
Rep 228
180F is hot enough for you to start redlining the car. |
windnsea00446.50 |
03-12-2019, 08:07 AM | #18 |
3689
Rep 2,956
Gents. Take a look at any oil viscocity vs temperature curve. At 50C most oils are already over 90% towards minimum viscosity. Basically once you see the needle move past 70C on your M2 you are good to go as the viscosity changes as temperature increase from there are minimal at best.
https://wiki.anton-paar.com/en/engine-oil/ |
03-19-2019, 09:37 PM | #21 | |
Member
458
Rep 1,517
I'm not sure if they still do it but my old JB4 on my 135i would limit boost until 160F. You would get 2 blinks of the hazards and that meant you were good to go. I did 50,000 hard miles with a JB4, downpipes, and e85 all without issue like this. If I had an e9x m3 I might wait till it heats up a bit more.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
07-10-2020, 02:39 PM | #22 | |
278
Rep 558
