Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Just installed SSTT. My impressions.
      03-12-2008, 06:47 PM   #1
markymarc1979
272
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
installation - Piece of cake. I was having a bit of a problem in the beginning. I was attempting to jam my arm in on an angle, in order to reach the sensor. After several scratches and scrapes, I stopped and thought about it, I realized it was much easier to insert my hand from above and there was a lot more room to work with.
Took about 5 minutes with a dime so find and lift the clip. Snapped the SSTT in and mission accomplished.
One question: Is it possible to install the SSTT wrong? or can the connectors only go one way? If it's not done properly, should I expect a CEL?
Test drive - Running on 94 Octane 10% ethanol, I must say, it didn't feel like night and day. I was hoping to break traction in second, but I couldn't. I'm a tad bit dissapointed, but I hope my ECU still has adapting to do. I only went on a very short drive, maybe 5 or 10 miles.
The exhaust is definitely throatier then before and I really like it. You can also hear your turbos whistling a lot more. I like that too!!!
I'm really hoping that my ECU adapts more and I break traction in second.
      03-12-2008, 06:49 PM   #2
Mattscott
Mattscott's Avatar
108
Drives: 2007 335i E90
it takes a couple days to fully adapt, maybe friday you'll get in and floor it, and be
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      03-12-2008, 06:49 PM   #3
jaaz
CArbon BlAck
jaaz's Avatar
18
Drives: 2011 X5 35i SAV
Did you turn off DTC? (one brief push of the button)
2011 X5 35i SAV Carbon Black M-Sport / Tech / Conv / CA / Twin Recaro Kid-Booster Seats
      03-12-2008, 06:52 PM   #4
markymarc1979
272
2009 BMW E93  [0.00]
I hope your right!!
      03-12-2008, 06:53 PM   #5
markymarc1979
272
2009 BMW E93  [0.00]
No I forgot to disable DTC. Should I turn it off (push button) or completely disable it (Push and hold button for a few secs)???
      03-12-2008, 06:57 PM   #6
kalsha
kalsha's Avatar
Armenia
11
Drives: MY09 Space Gray E92 Coupe
push it all the way and hold it for a couple of seconds and the DCT will disable completely.
      03-12-2008, 06:58 PM   #7
Mattscott
Mattscott's Avatar
108
Originally Posted by markymarc1979 View Post
I hope your right!!
SSTT owner here.
      03-12-2008, 07:01 PM   #8
failsafe
pass the puck
failsafe's Avatar
Drives: E90 335i
2008 E90 335i  [0.00]
2003 Nissan 350Z  [0.00]
Just ordered one today. Should be here Friday
2008 E90 335i - SSTT, BMS intake
2003 350Z - lots o' stuff
      03-12-2008, 07:03 PM   #9
jaaz
CArbon BlAck
jaaz's Avatar
18
One push of the button disables DTC. Holding it down for like 5 seconds will disable DTC and DCS I believe. No need to do that to break traction, just push the button once. You should break be able to break traction easily in 2nd gear.
You did let the ECU go into sleep mode before installing the SSTT, right?
      03-12-2008, 07:06 PM   #10
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
As a past SSTT owner I can say that it'll take you a good few WOT's to get it fully adapted. You should also get a feel of improved throttle response.
Retired: 2005 N52 E90 330i Sport 6AT
Retired: 2007 N54 E92 335i Sport 6AT
Current: 2012 M57 E70 X5 xDrive35D
      03-12-2008, 07:07 PM   #11
XS4
slave to the dark side
XS4's Avatar
30
Drives: 2008 335i Sedan
Give it more start/stop cycles to adapt, and ditto on the WOT runs.
No need to push the button unless you like changing lanes sideways. I have 9 1/2" wide 19's in back and without touching the button the back end still goes every which way at the top of 2nd. Thats with DPs and upgraded intercooler however.
Two Turbos to Rulez Them All...
      03-12-2008, 07:08 PM   #12
kalsha
kalsha's Avatar
Armenia
11
what is WOT?
      03-12-2008, 07:09 PM   #13
Hunter399
Hunter399's Avatar
325
Drives: F90M5
wide open throttle
      03-12-2008, 07:09 PM   #14
bimdaddy
bimdaddy's Avatar
37
Drives: 911 Carrera & G01 X3
Two to three days after install, your butt will adapt to the new power, and you may think it's not quite as punchy like after the install. At least the case with me and a few members here...but trust me, it's all there bro. Enjoy
2020 X3 X-Drive 30i; Alpine White/Mocha
      03-12-2008, 07:10 PM   #15
ybbiz34
ybbiz34's Avatar
675
Drives: 2023 330i M Sport
Originally Posted by kalsha View Post
what is WOT?
Wide open throttle.
      03-12-2008, 07:11 PM   #16
BoostedE90
BoostedE90's Avatar
55
Drives: e90 335i 6MT
what is WOT?
Wide Open Throttle
      03-12-2008, 07:11 PM   #17
kalsha
kalsha's Avatar
Armenia
11
sorry kind new, what exactly is WOT?
      03-12-2008, 07:15 PM   #18
BoostedE90
BoostedE90's Avatar
55
I would suggest giving it a few days to adapt if it doesn't seem any better I would suggest disconnecting the battery. I had mine in for about 3-4 days (and it did seem to be much stronger) and then I completely unplugged my battery. I really think that did the trick cause after a day of adaption the car felt much better than when I first installed the SSTT.
Welcome to the club!
      03-12-2008, 07:15 PM   #19
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
Out of topic, but did you wake your baby out of the wintry sleep just for a test drive? Couldn't hold it any longer? Same here.
      03-12-2008, 07:25 PM   #20
markymarc1979
272
2009 BMW E93  [0.00]
You got it. I couldn't stand it sitting there anymore. I've been watching it collect dust all winter long. I hate Canadian winters.
      03-12-2008, 07:26 PM   #21
markymarc1979
272
2009 BMW E93  [0.00]
Thanks for all the feedback BTW. I'll keep you posted over the next few days. Does anyone else notice the throatier exhaust and whistling turbos?
      03-12-2008, 07:34 PM   #22
NRG
NRG's Avatar
Russian Federation
36
Drives: 2012 X5 35d
I did, especially with a drop-in filter.
Man, same picture here. Can't wait for spring to come in, so I can take it out and install a few of my new mods.
