      07-10-2011, 09:22 PM   #1
Southjersey128
Southjersey128's Avatar
43
Drives: 2008 128i
2008 BMW 128i  [10.00]
DIY 128i BMW Performance Brake Kit W/ Steel Hoses
This is my first DIY post, had trouble posting pics, so be gentle please...
Just got done install of BMW Performance Brake Kit from Turnermotorsports. Thought I would share some of the tricks that make installing this kit a little easier. First, the rear calipers do not come painted. A caliper paint kit from g2usa.com in their phoenix yellow metallic#445 to match the front does the trick. I painted a couple days before the install.
The kit comes with front and rear pads calipers and rotors, 2 sensors, and 2 backing plates with new bolts. I also ordered the steel brake hoses and dot 4 brake fluid from turner.
After removing the wheels, undo the brake sensor located on the drivers side in the little black box on the inner fender. The white connector is the one you want.
Next remove the caps from the calipers revealing the 7mm hex bolt. Remove the hex bolt. Remove the caliper and let it hang out of the way by the hose. If you are reusing the hoses don't let it hang by it, secure it out of the way with a hanger. Remove the 18mm caliper bracket bolt.
Remove the 6mm rotor retaining bolt. These like to strip the inside of the hex sometimes so I put the hex socket in and then shoot it with the air hammer a couple times to loosen it's grip in the hub.
Remove the rotor by gently hitting it on the hat of the rotor to loosen it.
Remove the four bolts holding the backing plate on.
Install the new backing plate using the new bolts. The backing plates will only go on one way.
Clean the paint off of the mating surface of the rotor with a whizzer wheel or another abrasive pad, then spray with a brake cleaner.
Install the rotor with the 6mm retaining bolt.
Install the new caliper reusing the 18mm bolts from the old bracket.
Install the brake sensor in the black box on the inner fender and into the slot on the top of the inner pad.
Remove the brake hose from the steel line on the inner fender using an 11mm line wrench. Take the old caliper and put it aside. Install the new hose into the caliper first, then to the steel line on the inner fender.
Repeat on the other side.
Move to the rear. Same basic settup but the caliper bracket bolts are 16mm's and the sensor connector is behind the passenger side rear inner fender. A 10mm plastic nut and 2 8mm bolts from the bottom hold the fender in place. Just pull it out of the way to reveal the connector.
Remove and install the calipers, bracket, rotor, and hose. Remember to attach the hose to the caliper first, before rear subframe.
Next remove the inner brake hoses that connect the brake lines from the body to the rear subframe. You can follow the steel lines to the front of the subframe. Install the new ones in the same fashion as they came out.
After the hoses are all hooked up crack the bleeders on all the calipers remove the master cylinder reservoir cap and let them gravity bleed. Once you see fluid dripping out, close off the bleeder. Make sure the master cylinder reservoir doesn't go too low, you don't want to add more air into the system.
With the car running, pump the pedal slowly only about halfway until there is resistance in the pedal.
Use a friend to bleed the system by pushing the brake pedal while you crack the bleeder several times till there is no air coming out at all. Start on the caliper furthest from the master cylinder then work your way to the closest. I.E. left rear, right rear, right front, left front.
Check the pedal feel. Should feel High and Hard. If it doesn't try bleeding again.
Install the wheels, test drive the car in a non populated area like an empty parking lot. Allow 125 miles before any hard braking to allow the pads to seat properly.
Hope this is helpful. This upgrade is easily done on jacks if a lift is not present. Should take no more than 4 hours to do at a slow pace.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
      07-10-2011, 09:32 PM   #2
ulrichd
ulrichd's Avatar
211
Drives: 128i M-Sport
Great post, thanks. What rotors are you using for the rear? I am about to change my pads to Cool Carbons and the front rotors to cross drilled Powerslots from Tuner Motorsports.
      07-10-2011, 09:36 PM   #3
Southjersey128
43
Drives: 2008 128i
Thanks, New rotors came with the kit. They are oem, slightly larger than the ones the 128i comes with. I'll get the part number and post it
      07-11-2011, 09:41 AM   #4
DriveHard
DriveHard's Avatar
Colombia
117
Drives: X1 and R58 JCW
nice job !!
I have these already and they are great !! espically since our cars ( 128's ) are a few hundred pounds less than 135's, espically mine that has no sunroof and manual seats.
p.s that Brake caliper paint is 99.00 BUCKS... wow, great find, but a little pricey, No?
p.s.s. you need a new calander
X1, R58 JCW, M2 in my future if planets align
      07-11-2011, 10:30 AM   #5
Satalite
Satalite's Avatar
166
Drives: 128i
2009 128i  [10.00]
Cool! Pricey paint though... I could always just paint my calipers performance yellow and call it a day?
      07-11-2011, 06:41 PM   #6
JimD
JimD's Avatar
369
Drives: 128i convertible
I don't know if they have a compatible color but I painted my stock calipers with a kit I got from JEGS. I think it was made by duplicolor. Seems like it was about $30. It included a large aresol can of brake cleaner you wouldn't need for new calipers. The paint has held up well (I painted mine red).
Nice DIY. When I did the M school, the brakes of the M cars impressed me at least as much as the engines. My 128i has good brakes but not as good as an M.
Do you need 18 inch wheels for these calipers?
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      07-11-2011, 06:47 PM   #7
Southjersey128
43
Drives: 2008 128i
The kit will work with 17's and up.
      07-12-2011, 10:21 PM   #8
SaviorXi
SaviorXi's Avatar
21
Drives: 2009 335i xDrive coupe
Those are some bad ass brakes. The color match is worth the $99. You spend $1400 on the brakes the least you could do is spring for the matching paint for the rear calipers. Thanks for the DIY
Mtech/M3Skirts/335isDiffusor/BBSrgr/PSS/OFT/Alpina/LCItails/LuceAngelEyes/OsramXenarc/ZKWRlenses/
FlowmasterHFC/vibrant/VRSFdp’s/Helix/Mr5CAI/M3rearBushings/M3StrutBrace/RearSway/UUCfrontSway/Meyle/
KoniTCKlineAdjFront&Rear/EibachPro/ECSbrakeLines/ECS2pieceRotors/Akebono
      07-12-2011, 10:48 PM   #9
SaviorXi
SaviorXi's Avatar
21
Southjersey128 here are some pics of the brake kit after you completed the install. Thanks for the help with my wheels, tires, and suspension.
      05-24-2014, 03:07 PM   #10
Bimmer-Bob
Bimmer-Bob's Avatar
708
Drives: 2010 128i
Quick question on the rear calipers - any indication that they are an improvement over the stock rear calipers, or are the identical? As near as I can tell, the rear rotors are the same as stock. Trying to decide if I should just go with the cheaper front axle kit or spring for the whole deal.
____________________________
      05-24-2014, 03:33 PM   #11
Southjersey128
43
Drives: 2008 128i
I remember reading that the piston inside the caliper was larger than the stock 128, but don't really remember if I had checked. It's been a while now.
      05-25-2014, 02:43 PM   #12
Fidiman
Fidiman's Avatar
France
116
Drives: BMW 120d e82 M Sportpaket
2010 120d E82  [10.00]
Have you had any brake issue (bad pedal feeling) due to a smallest master cylinder than the 130/135i ?
I heard about a longer course of the brake pedal after the half of the brake pads ...
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ...
French community of 1 and 2 Series: One-Two-Bimmers
      03-09-2015, 07:52 PM   #13
Eins Suchtig
Eins Suchtig's Avatar
61
Drives: 2011 SGM 128i MSport
The rear pistons of the BMWP brake kit for the 128i are 1.650" dia.
Stock rear pistons are 1.570" dia.
      05-06-2015, 10:53 AM   #14
Booey1979
Drives: 2010 128i m-sport BBK 2piece
Wow old thread but i just ordered the ecs performance brake kit for my 128i. Can't wait.
      10-05-2015, 07:42 AM   #15
Ben20
Belgium
Drives: 116 dA M Sport Hatch
No coding is necessary ?
The brake force is piloted by the master cylinder, which is piloted by the DST, etc..
Thanks for your answer
      10-05-2015, 11:36 AM   #16
Bimmer-Bob
Bimmer-Bob's Avatar
708
Drives: 2010 128i
The car needs coding afterwards. Just add +SPBR to the VO and reflash the DSC. I just did mine yesterday - took <5 minutes.
      11-06-2015, 01:50 AM   #17
Suhb
Suhb's Avatar
119
Drives: 2010 128i Coupe 6-Speed
What are the part numbers for the rear calipers? I bought the fronts used off of a 135i and I'm looking to buy the rears to keep bias in check.
      11-06-2015, 07:30 AM   #18
Bimmer-Bob
Bimmer-Bob's Avatar
708
Drives: 2010 128i
These should be the part numbers you're looking for: http://www.realoem.com/bmw/enUS/show...diagId=34_1691
1addicts
